Question about Dryers
Tdc30 start switch doesnt stay
My hotpoint tdc30 tumble dryer, start button doesnt stay when it is pressed. It keeps coming off once the hand is removed from the start button. Is it a start button problem or thermostat problem?
    Top Expert:
  • Dryers Master
  • 9,472 Answers
It is the door switch that is the problem.
Posted on Nov 09, 2012
  • 1028 Answers
SOURCE: Start Button will start dryer but won't stay on!
pull end caps off just grab at top of plastic and pull towards you remove the 2 screws underneath lift console up and roll back next to timer is a small control bd to right of that are 2 relays 1 with red wires for element and 1 with blue wires for motor first try switching the relays they are identical and will work for either 1 ..try if works replace relay ..if still not working suspect control bd
Posted on Jul 01, 2008
  • 209 Answers
SOURCE: Tumble Dryer won't start
assuming what you say you checked is correct and working then the next place to look is the start relay, located behind the front timer control panel, this sis more often than not a cubed shape box made of clear plastic with about 6 spade connectors on it, look for burn marks inside it, replace if looks damaged, do not attempt to bypass or short out to test, as you will blow the timer or and control circuit board and cause extensive damage
Posted on Sep 26, 2007
dididsaythat
  • 291 Answers
SOURCE: Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Posted on Oct 14, 2007
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
  • 1462 Answers
SOURCE: The tumble dryer appears to
check the lint filter and check venting clear
Posted on Nov 04, 2008
NO DRUM ACTION ON MY TDC30 BUT DO GET HEAT
When you start the dryer does it sound as if it is running but it does not tumble? Or does it make a humming noise?
If it sounds like it's running I'd check the belt first,
Humming noise and burning smell Dan indicate a bad motor or something stuck in blower wheel.
Oct 18, 2014 | Hotpoint Dryers
Trips electric after a few seconds tdc30
your dryer has problem with the heater.to confirm the same u just switch of heater and start dryer.solution is u have to replace tha heater.
Jan 13, 2014 | Hotpoint TDC32 Electric Dryer
My hotpoint TDC30 dryer is cutting out after 3 mins ,the drum is warm inside and wont restart till its cold inside the drum
Hi joanne balla...
Sounds like the cyclic thermostat, thermostat, fuse (differnet names for the same part)..is faulty...replace it.
You will have to remove the back from the machine, look for the air tube going to the vent of your dryer and located on it will be the thermostat/s.
To test it, remove the wires fromthe two terminals and tape them together, then try running your dryer again and if it runs and heats ok then replace the cyclic thermostat/fuse.
Go to the following webpage to see the thermostat
Please take time to rate me
http://www.espares.co.uk/parts/tumble-dryers/thermostats/hotpoint/p/1587/808
Sep 13, 2011 | Hotpoint Dryers
Hotpoint ctd40 t dryer. wont start just ticking.
do you hear anything running?,might have broken the belt or idler wheel,motor runs but no tumble,need to look inside,warning !! unplug ,high voltage.be carefull
Sep 22, 2009 | Dryers
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
Hotpoint aquarius condenser dryer TDC30
I would dry it just to be on the safe side, even though it doesn't say so. It can't hurt. The front t'stat should be under the top at or near the drum.
Feb 03, 2009 | Hotpoint Dryers
Tumble dryer when switched on cuts power to all sockets in house
Hi.
Try it with the heater disconnected, you will find it at the rear of the m/c at the bottom left behind a removable panel.
You may have to remove the top cover and the right hand side panel looking at the m/c from the front. Try it again.
I fit does not trip. then your heater is faulty.
If it still trips then you are probably going to have to call en engineer
Nov 26, 2008 | Hotpoint NWXR473EV Dryer
Hotpoint tumble dryer model wt something, colour graphite. The problem is that when I press the start button the dryer comes on and normally stays on when you release your finger from the button, but when...
hi your on/off switch has broken down you will need to replace it it will cost you about £4-£8 it is fairly easy to fit good luck if you need help just ask.
Apr 22, 2008 | Washing Machines
Tumble dryer
You may have loose wires.
Check the door switch first.
Then check the wires going to it by opening the top or front of the machine, which ever opens to examine the switch and wires.
Also, check this link.........
http://www.howstuffworks.com
Let me know if you have the problem solved please.
Thanks,
yalmer
Mar 13, 2008 | Dryers
CIC60 01 tumble dryer only works if on/off button is held in
is the new on/off switch new or second hand if its new get it exchange cause these switchs have a spring in them with 2 channel cutouts in them once depressed when it starts to come back up it automatically goes into another channel which keeps it on faulty switch thats all it can be if secondhand again take it back cause its faulty this is the only thing it can be they are simply made so they dont mess up try doing it when its not on the washer love peter
Nov 16, 2007 | Dryers
Dryers Logo
184 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
