Question about Whirlpool LER5636P Electric Dryer
Won't start The drum tries to start, only moves a bit (1-2'') then it shuts off. It has been getting harder and harder to start, now it won't
  • djdigiacomo Jan 09, 2009
    I have the same problem and also got a smell as it sounded like it was trying to turn.  I immediately opened the door to stop it and then tried to start it again and got nothing at all.  Not even the sound of a sick motor.
  • 135 Answers
Likely bad motor. If the drum turns freely, 99% motor. If not, check for obstruction in the blower housing. Hope this helps! Send me your model # for part lookup.
Posted on Jan 05, 2009
Washer does not spin. Makes noise but drum doesn’t move
replace the rubber drive belt, unplug the machine remove the back panel to reach it as they do get worn and will wash but as the load sits at the bottom of the drum in spin mode the drum becomes heavier when the washing is sitting in the bottom its harder to start the rotation eric
Jan 18, 2018 | Washing Machines
International65A,tractor. My tractor run a while, then shuts off?? Some time if I move p.t.o. Lever or bounce on seat it will start....right now it won’t start at all.
1) Check your fuel/fuel delivery. The jostle to the tractor is possibly getting fuel to flow for a bit.
2) Check for a wire in the ignition system that has a short to ground,
a loose connection or is cut/broken. Looking closely at all the places where wires run thru holes.
I'm guessing it turns over, just doesn't fire.
Dec 06, 2017 | Garden
Hoover 1400 door won't close
I would call hoover a service number should be located by the serial number or possibly on the door
Sep 04, 2012 | Washing Machines
A zipper from a comforter is lodged between the moving drum and its housing causing a possible drag on the rotating drum. not sure how to dislodge zipper or remove drum to access
The whole drum should move a bit. Try turning it by hand and pushing back on it (or pulling forward). Also, you can try lifting up quite hard (drum is free to move about 1/2" in all directions the way most are set up. I havn't seen this specific unit but it is worth a try.
Otherwise, I think there is a set of screws around the top perimeter holding the top deck on. Remove that and you will have a better view of what moves and by how much.
Remember )
1) Unplug the unit before unscrewing anything.
2) Make sure everything is put back as you found it before putting lid back on.
Also, you won't break anything by only taking it apart to look. Have fun doing it and good luck. Hopefully they used standard screws instead of some tamper-resistant fasteners that German manufactures are using a lot of lately (Braun, Krups, Bosch, ...).
Most hopefully, you can get it un-stuck by shifting the drum a bit.
-Mark
May 02, 2011 | Bosch Nexxt 500 Dryer
The start button will depress but it doesn't start. Not on any selected time. It's been getting harder and harder to push it to start and we have to hold it down for a long time for the dryer to start. ...
Try this (you may need two people):
1. Open the dryer door and locate the door switch. While pushing the door switch in, have someone else push the start button.
2. You'll hear the noise. Keep pushing both buttons and take your other hand, reach in side and grab one of the drum fins and manually push the drum in a clockwise direction.
3. The drum may take off on its own. BE CAREFUL TO REMOVE TO HAND QUICKLY TO NOT GET BUMPED BY THE FINS AS THEY BEGING TO ROTATE.
If it does not start, the motor needs to be replaced. If it is still under full warranty, simply call a repairman.
If this works, turn the dryer off, close the door and try to start it again just by pushing the start button. If it works, it may have been something obstructing the drum from turning. OR, the motor could be going out. It may continue to start on its own for an unkown period of time, a day, a week, and year. But eventually it will go out and will need replaced.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are Bosch certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on whatever you decide.
Best, G
Aug 02, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Need manual
Finding free drivers is becoming harder and harder. Many so called driver sites are merely fronts for other software you have to buy to get the driver. Even then you don't always get the driver. Give this one a try, it seems genuine.
http://safemanuals.com/user-guide-instructions-owner-manual/ALESIS/D4-_E
Good luck
Apr 18, 2010 | Alesis 16 Bit Stereo Drum Machine System
I can't get the the drill bit out of my cordless drill
Try to keep your drill straight and try a bit harder - looks like you were drilling something very heavy.
Apr 03, 2010 | Dewalt 18 Volt Compact Drill Kit
Drum will not spin. The belt is not broken but is hanging lose
If the motor is working...Shut off the power to the dryer, reach inside the drum and try to rotate the drum 1/4-1/2 turn. Sometimes the motors get dead zones in them and this will help move it out of the dead zone
It could also be the drum rollers that need lubrication or replacement, if they are not rotating it would not allow the drum to spin.
I hope this helps
Oct 02, 2009 | Kenmore 73952 Gas Dryer
Drum starts but does not continue
You have one of two possible problems. 1. The run winding in the motor, or wiring to it in the motor switch is bad. = get a new motor. Or, more likely: 2. The internal centrifical switch in the motor is not moving back into the non-running position. (this results in only the start winding being energized when start switch is used.) Usually = get a new motor, but you can try to lube it up and get it moving again. You will have to open dryer top to be able to take dryer front off, then remove belt so you can remove the drum to get to the motor. Look inside the motor near the belt end. There is a collar on the motor shaft with springs on two sides of it. That collar needs to be free to move back and forth. (only about a 1/2 inch or less) Sometimes a bit of spray lube and a little manual moving of the collar is enough to free it up and save you the cost of a motor.
NOTE: Do NOT try to run dryer with using only the start switch held. You will burn out the start winding.
Jul 28, 2009 | Dryers
Whirlpool LER5636P Electric Dryer Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
