Question about Metra 40-cr10 2005-2008 Chevy Equinox Ls Antenna Cable Car Audio Radio Stereo
Windows aren't working, rear hatch won't unlock
    Master:
  • 689 Answers
Hot wire it , Then it will (Open)
Posted on Nov 09, 2012
Back passenger power window stopped working
I can help with a little testing. On the hinge side of rear passenger door, should be a wiring harness. Probably has a protective rubber boot covering, pull the covering back far enough to get at wire colors in the diagram. One wire is voltage the other is ground depending if the window is going up or down. Use a test lite to check. Key on, I would think.Your front passenger window works ok? If the wires check out good for voltage and ground, could be something wrong with window motor?
Oct 22, 2017 | Cars & Trucks
Chevy Avalache 2007 blew a fuse while getting a jump, car won't start, rear windows and power locks don't work
You blew more than 1 .
The HUGE MAXI FUSE is probably burned... IF I remember correctly, it is a 80 or 100 Amp
Apr 06, 2013 | 2007 Chevrolet Avalanche LTZ
Door locks won't lock/unlock
What kind of vehicle is it?
May 02, 2017 | 1999 Chevrolet Blazer
All 4 windows won't work and rear door latch won't open! So, I have two problems: Firstly my rear hatch won't open as of yesterday (Keyless entry pushed & it doesn't even make a noise...
Look at your maintenance manual. To find where your fuse box is located(may be under the hood or under the steering wheel). When you find the fuse box look on the back of the panel flap and you'll find a fuse map. Locate the fuse that corresponds with your problem. It could be the same fuse but not likely. If fuse is blown then replace it with a spare. Most manufacturers will put spare fuses in the box or you could pull a fuse from some where else just to try and see if the problem is still there( make sure it's the same size and understand that it could blow this fuse as well then you will need 2 fuses). Most of the time fuses don't just blow. For some reason it pulled to much load. Probably a dead short in the wiring. I hope this helps.
Jan 22, 2013 | 2005 Toyota 4Runner SR5 V8
Replaced door lock fuse on 03 Suburban, doors still won't unlock.
You need to replace the Unlock Relay, it should be in the fuse panel on the passanger side.
Dec 03, 2012 | 2003 Chevrolet Suburban
Metra 40-cr10 2005-2008 Chevy Equinox Ls Antenna Cable Car Audio Radio Stereo Logo
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
