Question about Compaq P 1220 22" CRT Monitor
P1220 won't start
I just bought a used HP dc7600 Convertible Minitower. I have two monitors, one of them came along with the computer and it's a Compaq p1220, the other one is a rather old HP monitor. A HP w19b I think. Anyhow, neither of the monitors will power up fully when I've connected it. With the p1220 (Which I've personally seen working with the computer before.) goes into power save mode as soon as I turn it on. shortly after it fades to black. With the Hp w19b, something similar happens, but it says "No Signal" and it too goes to black. I am 90% positive. it isn't the computer as I can hear the "Windows opening theme" thingy, (The little melody that plays when the desktop comes up) and I can also hear the USB-thing-connected/disconnected sound effect. Now, as I'm no computer freak, I'd appreciate some understandable words here, and thank you for the help. ;)
SOURCE: Dead Monitor
the monitor is dead
Posted on Jul 26, 2008
  • 6 Answers
SOURCE: Compaq FS740
try pressing escape. or press f8 when your computer starts up and then press factory restore
Posted on Aug 27, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: problem with compaq MV 520 monitor
Your monitor is operating normally. After Windows starts it is setting the video resolution to something outside of the monitor's range. That's why you see the Windows splash screen, then the message from the monitor about the settings. Most likely the computer was used before with a monitor that had a wider range of resolutions available.
Restart the computer. When the manufacturer's logo screen appears, press the F8 key three or four times. This should get you a startup menu screen. Pick the option of starting in VGA mode, and Windows will start with video settings that your monitor supports.
Posted on Feb 05, 2009
  • 11 Answers
SOURCE: power problem with HP Compaq d530 Convertible Minitower Desktop
Try this first : Load the bios (F10 - vista or F1 - XP), Load setup defaults F5. then Save changes F10, and try restarting your pc.
Secondly, after restarting your pc, on the HP invent screen, keep tapping on F9 for the diagnostic test
If theres no any error message, press any other key ACCEPT for the 'R' key to restart or repeat the test.
Other sollution ----------------------
Try loading into safe mode F8, select on the safe mode and let the computer stays into safe mode for sometime.
If the pc doesnt restart, it means theres no any HW problem in ur pc. If it does the same, it means, you will need to check your Power supply, M/board with your tech
Posted on Jun 20, 2009
SOURCE: Monitor moving on its own
On your physical monitor adjust the verticle and horizontal lengths to take up the full length of the screen. The CRT guns have to draw the exact location of your screen, so extending them to the edges will be easier on the guns. You can also try raising the refresh rate, although that probably wont fix it but it will help on your eyes. and if You have other options like convergence, focus, etc. Try messing with those.
Posted on Feb 09, 2010
HP Compaq dc7600 Convertible Minitower ram support
old post , from dead file via SPAMMER.
p4 processor is a dog ,not 64bit
and 4gig max, 3.5g actually with XP or Vista
SEE PAGE 50, FoUR 1GIG STICKS IS MAX
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/action.process/public/psi/manualsDisplay/?sp4ts.oid=472276&javax.portlet.action=true&spf_p.tpst=psiContentDisplay&javax.portlet.begCacheTok=com.vignette.cachetoken&spf_p.prp_psiContentDisplay=wsrp-interactionState%3DdocId%253Demr_na-c00383428%257CdocLocale%253Den_US&javax.portlet.endCacheTok=com.vignette.cachetoken
let me guess, 1gb now and want 4
4 will only give you 3.5g. win 3b2 limits.
Feb 09, 2013 | HP Compaq dc7600 Convertible Minitower PC...
No videos playing on my HP dc7600 convertible minitower PC
Have you installed Abode Flash Player? If not, get it here. If you did install it and the issue still exists, it might be the Windows Media Player plugin. You can go to Microsoft's website to get the plugin.
May 28, 2012 | HP dc7600 Convertible Minitower PC Desktop
Each time I start up the computer, it only shows a black blank screen with a cursor blinking on the top right corner of the monitor
That usually happens when the computer is booting up from another drive other than the hard drive... Try pressing delete when the computer start then make sure that hard drive is selected as the primary..
Sep 09, 2011 | HP Compaq dc7600 Convertible Minitower PC...
HP Compaq dc7600 convertible minitower version. CPU clock slow. Replaced CMOS battery twice just to be sure I didn't get a bad one the first time around. Get a new CPU? Get a new MB? Trash it and...
Try installing the system board driver and chpset driver.
You can also try setting the BIOS to factory default settings.
If you have a volt meter check to see if there is votage at the battery connector, and the power supply connectors are plugged into the mother board, which I suppose you are, just an idea, if the above suggestions don't resolve your issue.
I hope this helped.
Good luck and have a fantastic day.
May 24, 2011 | HP Compaq dc7600 Convertible Minitower PC...
I want to download audio driver for hp compaq dc 7600 on windows xp. What is the best driver for it? Thanks for help Maz
Audio drivers for this computer are here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=472278&lang=en&cc=us&prodTypeId=12454&prodSeriesId=472276&taskId=135
Original drivers from HP
Nov 24, 2010 | HP Compaq dc7600 Convertible Minitower PC...
I am not found hp compaq dc7600 ethernet controller download pleas help me
Try here :-
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=472278&prodTypeId=12454&prodSeriesId=472276&swLang=25&taskId=135&swEnvOID=2094
or just google "hp compaq dc7600 drivers"
Nov 13, 2010 | HP Compaq dc7600 Convertible Minitower PC...
Please Help. I hv HP Compaq dc7600 Convertible Minitower PC Sound Problem.... control panel--->sound and audio devices-->No audio device
well first after turning the computer on, immediately press F10....go to security and check if the audio is turned on (not invisible) if it is go to pci devices and check there if the sound is enabeled, don t forget to press F10 to accept values and reboot the computer goodluck
Oct 17, 2010 | HP Compaq dc7600 Convertible Minitower PC...
Compaq P 1220 22" CRT Monitor Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
