Question about Lenovo IdeaCentre Q150 PC Desktop
How do I control fan speed? - Lenovo IdeaCentre Q150 PC Desktop
  • Lenovo Master
  • 27,725 Answers
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
The fan speed on a laptop can determine how it operates consistently and reliably.
You can slow it down or speed it up, based on the circumstances.
For instance, slowing down the fan speed may be useful in reserving processes or during a prolonged slow time.
Speeding it up is beneficial in keeping the laptop cool during ongoing use or high-traffic times. For the long term, find a happy medium for regular use, so you won't "psyche" out your computer by constantly adjusting the settings.
Click on the Start menu and select "Control Panel." Next, choose "Performance and Maintenance."
Select "Power Saver."
To slow the fan speed, locate the slider next to "CPU Processing Speed" and slide it down by moving across to the left.
To speed up the fan, move the slider to the right.
Press "Apply" and then "OK," if prompted.
Hope this helps
Posted on Nov 08, 2012
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
When i start my 2008 Cadillac sts i get a notification that engine hot A./C off. Even though it is the first time i stated it today
ENGINE HOT - AC OFF
Cooling System Description and Operation
you must have a cooling system problem of some sort !
Do the cooling fans come on when A/C is switched on ? Fan's should come on ! Does your vehicle have two or three cooling fan's ?
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 puller type electrical cooling fans and 3 fan relays. The relays are arranged in a series parallel (S/P) configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block. The ground path is provided at G104.
During low speed operation, the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan S/P relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the ECM supplies a ground path for the high speed fan relay and the cooling fan S/P relay through the high speed cooling fan relay control circuit. This energizes the cooling fan S/P relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time, the high speed fan relay coil is energized closing the relay contacts, and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit, to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
The ECM commands the low speed cooling fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 94.5°C (202°F).
• A/C refrigerant pressure exceeds 1447 kPa (210 psi).
• After the vehicle is shut OFF, if the engine coolant temperature at key-off is greater than 101°C (214°F), the low speed fans will run for a minimum of 60 seconds. After 60 seconds, if the coolant temperature drops below 101°C (214°F), the fans will shut OFF. The fans will automatically shut OFF after 3 minutes, regardless of coolant temperature.
The ECM commands the high speed fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 104.25°C (220°F).
• A/C refrigerant pressure exceeds approximately 1824 kPa (265 psi).
• When certain DTCs set
At idle and very low vehicle speeds the cooling fans are only allowed to increase in speed, if required. This ensures idle stability by preventing the fans from cycling between high and low speed.
Cooling
Having a qualified professional technician check it out would be your best bet ! Hooking up a factory or professional type scanner an check data input's an DTC'S - diagnostic trouble codes .
Diagnostic Starting Point - Engine Cooling
Begin the system diagnosis with the diagnostic system check. Refer to Diagnostic System Check - Vehicle . The Diagnostic System Check - Vehicle will provide the following information:
• The identification of the control modules which command the system
• The ability of the control modules to communicate through the serial data circuits
• The identification of any stored DTCs and their status
The use of the Diagnostic System Check - Vehicle will identify the correct procedure for diagnosing the system and where the procedure is located.
DTC P0480: Cooling Fan Relay 1 Control Circuit
DTC P0481: Cooling Fan Relay 2 Control Circuit
DTC P0691: Cooling Fan Relay 1 Control Circuit Low Voltage
DTC P0692: Cooling Fan Relay 1 Control Circuit High Voltage
DTC P0693: Cooling Fan Relay 2 Control Circuit Low Voltage
DTC P0694: Cooling Fan Relay 2 Control Circuit High Voltage
DTC P1258: Engine Coolant Overtemperature - Protection Mode Active
DTC P2600: Auxiliary Coolant Pump Relay Control Circuit
DTC P2601: Auxiliary Coolant Pump Performance
DTC P2602: Auxiliary Coolant Pump Relay Control Circuit Low Voltage
DTC P2603: Auxiliary Coolant Pump Relay Control Circuit High Voltage
Dec 10, 2017 | Cadillac Cars & Trucks
2007 ford taurus condensor fan not coming on with ac
Fan Control The PCM monitors certain parameters (such as engine coolant temperature, vehicle speed, A/C on/off status, A/C pressure) to determine engine cooling fan needs.
For variable speed electric fan(s):
The PCM controls the fan speed and operation using a duty cycle output on the fan control variable (FCV) circuit. The fan controller (located at or integral to the engine cooling fan assembly) receives the FCV command and operates the cooling fan at the speed requested (by varying the power applied to the fan motor).
EDGE/MKX, FIVE HUNDRED/FREESTYLE/MONTEGO, FUSION/MILAN/MKZ, CROWN VICTORIA/GRAND MARQUIS, TOWN CAR: FCV DUTY CYCLE OUTPUT FROM PCM (negative duty cycle) FCV Duty Cycle Command (NEGATIVE (-) duty cycle) Cooling Fan Response/Speed Greater than 0 but less than 5% Fan off, controller inactive Greater than 5% but less than 10% Fan off, controller is in active/ready state Edge/MKX, Crown Victoria/Grand Marquis, Town Car:
10% - 90% Edge/MKX, Crown Victoria/Grand Marquis, Town Car:
Linear speed increase from 30% to 100% Five Hundred/Freestyle/Montego, Fusion/Milan/MKZ:
30% - 90% Five Hundred/Freestyle/Montego, Fusion/Milan/MKZ:
Linear speed increase from 50% to 100% Greater than 90% but less than 95% 100% Greater than 95% but less than 100% Fan off
For relay controlled fans:
The PCM controls the fan operation through the fan control (FC) (single speed fan applications), low fan control (LFC), medium fan control (MFC), and/or high fan control (HFC) outputs. Some applications will have the xFC circuit wired to 2 separate relays.
For 3-speed fans, although the PCM output circuits are called low, medium, and high fan control (FC), cooling fan speed is controlled by a combination of these outputs. Refer to the following table.
If you don't understand these thing's listed above your best bet is to take your vehicle to a qualified repair shop . Have the vehicle checked for DTC'S - diagnostic trouble codes !
If
Jun 14, 2016 | Ford Cars & Trucks
I have an 05rendezvous,need to locate switches for cooling system,fans aren't co ming on & now I'm going to need a new radiator,cuz plastic broke.But it broke before fans gave out.Which I changed stat
The engine cooling fan system is controlled by the body control module (BCM) and the powertrain control module (PCM) or engine control module (ECM). The BCM performs the calculations as to how long, when and what speed the cooling fans should turn on. The BCM then sends a class 2 message to the PCM/ECM to engage the cooling fan relays. If there is a malfunction with the BCM, the PCM/ECM will control the engine cooling fans independently. The engine cooling system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the PCM/ECM to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood accessory wiring junction block. The ground path is provided at G100.
During low speed operation, the PCM/ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan 2 relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM/ECM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM/ECM supplies a ground path for the cooling fan 3 or S/P relay and the cooling fan 2 relay through the high speed cooling fan relay control circuit. This energizes the cooling fan 2 relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
The BCM and PCM/ECM command Low Speed Fans on under the following conditions:
Engine coolant temperature exceeds approximately 106?°C (223?°F).
A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
After the vehicle is shut off if the engine coolant temperature at key-off is greater than 140?°C (284?°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The BCM and PCM/ECM command High Speed Fans on under the following conditions:
Engine coolant temperature reaches 110?°C (230?°F).
A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
When certain DTCs set.
The three relays are located in the under hood fuse / relay box ! You need to have it checked for DTC'S -diagnostic trouble codes ! An you need a GM Tech 2 scan tool !
This diagnostic procedure supports the following DTCs:
DTC P0480 Cooling Fan 1 Relay Control Circuit
DTC P0481 Cooling Fan 2 and 3 or S/P Relay Control Circuit
DTC P0691 Cooling Fan 1 Relay Control Circuit Low Voltage
DTC P0692 Cooling Fan 1 Relay Control Circuit High Voltage
DTC P0693 Cooling Fan 2 and 3 or S/P Relay Control Circuit Low Voltage
DTC P0694 Cooling Fan 2 and 3 or S/P Relay Control Circuit High Voltage
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. With a scan tool, command the Fans Low Speed ON and OFF.
Do the low speed engine cooling fans turn ON and OFF with each command?
Go to Step 3
Go to Step 4
Important:: A 3 second delay occurs before the powertrain control module (PCM)/engine control module (ECM) changes the cooling fan speed.
With a scan tool, command the Fans High Speed ON and OFF.
Do the high speed engine cooling fans turn ON and OFF with each command?
Aug 08, 2015 | Cars & Trucks
Hi I have three new ceiling fans with a speed controllers (fan power is 220 V 50 Hz 80 , speed regulator 220 V 50 Hz 0.36 Amp,brandNational). And after installation; every thing is working right, the...
Seeing as these fans are 220 volts you probably have to use the control that comes with the fan. What make/model of fan is it? Are you in the USA?
Jul 04, 2013 | Dryers
My copier is having a system error E-805
E805 0000 Fan failure
only one in this copier>
The fan is faulty. -
Check the fan connector.
- Replace the fan.
- Replace the DC controller PCB.
Switching between full-speed rotation and half-speed rotation is controlled as described below.
1) Full-speed control
When the CPU on the DC controller outputs a fan full speed signal (FAN_FULL), the fan drive voltage switching circuit supplies a +24 V fan drive voltage to turn
the heat exhaust fan at the full speed.
2) Half-speed control
When the CPU on the engine controller outputs a fan half speed signal (FAN_HALF), the fan drive voltage switching circuit supplies a +16 V fan drive voltage to
turn the heat exhaust fan at the half speed.
E805-0000 (Main body fan error)
When the cooling fan of the main body starts, the fan lock detection signal (FAN_LOCK) has been held at the "H" level for longer than the prescribed time.
also check your low-voltage power supply
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Canon iR 2016i Black and White Copier
I have an existing ceiling fan with a three speed controller. The low speed setting was too high so I have engaged an electrician to install a variable speed controller, Clipsal 32E500F Series. The new...
some manufacturer already attached a variable speed controller when you purchased them, meaning the unit requires this control, but in your case when you purchased it, it does not have any, meaning they sell it to the market as ready to use, so why install additional control?
There might be an installation error during the assembly, so all you have to do is just interchange the wire connected to the control from LOW, MEDIUM and HIGH, it is a trial and error thing but it won't affect or damage your unit, maybe your high speed connection was connected to a low speed control, so just inter-change it. Remove the variable speed control
Nov 01, 2009 | Aloha Housewares (93645) Ceiling Fan
I'm trying to find out how many cooling fan relays are in a 1999 Ford Taurus SE with the 3.0L Vulcan OHV engine. This model year has done away with the CCRM (Constant Control Relay Module), so the relays...
fuse #9 protects the 2 cooling fan relays.
It looks like the hgh speed cooling fan realy is in a thin box mounted sideways between the battery and fender.
It has high speed relay, autolamp relay, autolamp headlamp relay, horn relay, washer motor relay, wiper hi/lo relay, wiper park relay.
Section 03-03: Engine Cooling 1999 Taurus, Sable Workshop Manual
DESCRIPTION AND OPERATION Electrical System NOTE: With A/C ON, the cooling fan motors will run continuously. Cooling fan motors will not cycle ON and OFF with A/C clutch (2884) .
NOTE: An exception to this is when vehicle speed is over 61 km/h (38 mph) and coolant temperature is below 100°C (212°F), and A/C head pressure is below 1.71 MPA (250 psi). The cooling fan motors will then automatically shut off.
The cooling fan motors are mounted within a fan shroud (8146) behind the radiator (8005) .
Engine Cooling Fan Control CCRM Applications The PCM monitors certain parameters (such as engine coolant temperature, vehicle speed, A/C on/off status, A/C pressure, etc) to determine engine cooling fan needs. The PCM controls the fan operation through the Fan Control (FC) output (single speed fan applications) or the Low Fan Control (LFC) and High Fan Control (HFC) outputs as shown in Table 2. Although the fan control (FC), low speed fan control and high speed fan control relays are normally open relays, the FC/LFC circuit is wired through a voltage inverter inside the CCRM. The voltage inverter ensures that the PCM must turn on (ground) the FC/LFC output to turn the fan off. This is done so the cooling fan will operate in the event of an open FC/LFC circuit.
Stand-Alone Fan Control Relay Applications The PCM monitors certain parameters (such as engine coolant temperature, vehicle speed, A/C on/off status, A/C pressure, etc) to determine engine cooling fan needs. The PCM determines engine cooling fan control requirements and controls the fan operation through the Low Fan Control (LFC) and High Fan Control (HFC) outputs (Table 3).
Jun 29, 2009 | 1999 Ford Taurus
Antec fans connected to akasa fan controller, Speed doesn't change
Sounds like a problem with your fan controller. The controller is simply controlling the voltage applied to the fan to adjust the speed. Have you tried a fan without a speed control built in?
May 09, 2009 | Akasa Fan Speed Control Fan Controllers
Bay Model # 526-012 Fans what size speed control
I can't see any reason why a Leviton fan speed control couldn't be used on any ceiling fan, after all, I don't even think Leviton makes ceiling fans. Second, you may be able to try using the 1.5 amp fan speed control and see if you can get by. The worst that could happen is the speed control wouldn't work or would only work for a short time and be junk.
Jan 03, 2009 | Hampton Bay (261025) Dual Mount Ceiling...
Lenovo IdeaCentre Q150 PC Desktop Logo
226 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
