Question about Canon PowerShot S410 / IXUS 430 Digital Camera
Camera was dropped and is not on
I have dropped canon s410 and it did not go on when i try to start ,battery is good, what are possible problems, it looks like there is no electrical contact with the battery ,thank you
    Genius:
  • 2,985 Answers
Take batteries out and have them checked, and make sure they are fully charged. Take a pencil eraser and clean/polish the contacts at base of the battery compartment Take a look at the battery-comp cover place and make sure the contact plate is firm replace batteries switch on OK No? Open the battery compartment, place a piece of foil across the batteries and shut it - turn on -OK No? Press the cover in OK No? Them it has broken beyond your reach and needs repair or replacement
Posted on May 23, 2007
PowershotA2400is len cannot retract
Are you sure the battery still has enough power (even after charging) to let the lens motor do its job?
Are you sure there is no mechanical problem, you can see on the outside? Did anyone stop the lens, while it was coming out? Did anyone drop the camera, while the lens was out?
There cam be a lot of reasons, why a lens won't retract. Could be some force was used, also could be something just went wrong inside the camera. Like a gear that broke inside, or the motor stopped working. A contact failed and perhaps lots of other things.
If you already took out the battery, and reinserted it, and nothing changed, The only thing you than can do is after getting the battery out, is recharge the battery and then put it in.
If you have a spare battery, or you know anyone who has the same battery, try that battery. If nothing indicates a mechanical failure, and nothing helps, just contact the Canon Service Centre closest to you. First ask what a possible repair will cost. hen decide if you would like it repaired or you want a new camera.
New camera's are much better and cheaper than cameras last year.
Feb 15, 2014 | Canon PowerShot S410 / IXUS 430 Digital...
Canon s410. All I get is a blank screen in the picture mode. The view picture mode works fine. I replaced the battery and still have a blank screen.
Its known issue of ccd imager chip failure in Canon S410 camera and Canon offers free of cost repair for said problem.
Click Canon CCD Imager Advisory for details.
Thanks.
Dec 26, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Canon PowerShot S410 smears of color on display and photos
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jul 15, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Hello! i own a canon s410 powershot,the camera got broken,i was given a canon a530 powershot and i want to use the software that came with s410,is that possible?my next question is about the the windows...
No, it's not likely to be compatible. The problem is that Canon did not update the drivers for many of its older cameras under the Vista operating system. So you're likely to run into problems downloading directly from the camera using the software. But there are other options, such as using an inxepensive card reader (can get them online for $2) to download your photos:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
But back to your S410, what exactly is wrong with it? By chance if it's taking black, pink, or distorted pictures, please see this:
Jun 23, 2009 | Canon Cameras
Lines across the images
Hello!!!
Try hard resetting once!!! Switch off ur camera , remove the batteries and press the power button for few seconds. then put the batteries back and try powering on!!
Nov 04, 2008 | Canon PowerShot S410 / IXUS 430 Digital...
Camera does not start up
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Oct 21, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
MAC is not Recognizing the S410
check the connecting cable or try another cable
Oct 10, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Canon powershot S410 Problem
This definitely sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Sep 18, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Flash doesnt work
There is a small battery (or large capacitor) inside your camera that stores a charge for when the flash fires. If you dropped your camera and hit the right spot, this battery may have been bumped out of position. A solution would be to open up your camera to see, but this is obviously risky and can void a warranty if you still have one. If you do choose to look inside, be sure to not tear any gentle wiring as this can ruin your camera for good (I know because it's happened to me).
Jul 13, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Canon PowerShot S410 / IXUS 430 Digital Camera Logo
55 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
