Question about Dell 2600 Notebook
Lexmark printer "replace cartridge" after refill install
I have 2 lexmark inkjet printers (P6250 & x4270) that both exhibit the same problem that after a refil or replace cartridge with a generic. They may print for short while but then complain about the cartridge needing to be replaced.
I filled more, cleaned contacts etc but no use. With the P6250 if I select continue and "select" on the printer it will actually print but that's for each print job.
I wonder if the printer senses characteristics of the non-lexmark ink?
Lexmark X4270 gives an error message...black cartridge missing. It is not missing. what is the problem
Make sure you are using genuine Lexmark black cartridge. Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
Try to reinsert your black cartridge and make sure it is properly seated in the cartridge carrier. If error comes back up right after placing it in the printer, then it could be a faulty cartridge. Try to replace it with a new genuine Lexmark cartridge. If you are already using a genuine Lexmark cartridge, please contact Lexmark Technical Support Center for additional assistance.
Dec 02, 2011 | Lexmark X4270 All-In-One InkJet Printer
After installing both cartridges in lexmark p6250 it says the colour cartridge is missing.both ink cartridges are made by lexmark
It could be old stocks or possibly faulty cartridges. Please contact Lexmark Technical Support Center for assistance.
Aug 26, 2011 | Lexmark P6250 All-In-One InkJet Photo...
I installed a refilled color ink cartridge. several times, but the display still says color ink cartridge missing. What's up?
EITHER THE REAL THIN TAPE IS STILL ON THE CARTRIDGE, OR DO WHAT I DID, QUIT USING REFILLS CAUSE THEY'RE JUNK AND CAUSES HEADACHES..........
Jan 09, 2010 | Lexmark X4270 All-In-One InkJet Printer
Can one reset the Lexmark P6250 printer refilled cartridge?
No, you can usually tell your printer to "ignore ink levels" when it gives the ink low warning on your computer screen. As long as they print just keep printing until they run out.
Dec 28, 2009 | Lexmark P6250 All-In-One InkJet Photo...
P6250 indicates there are no cartridges installed just after I put in new ones. No refilled and I took out the tape. I see the big x's in the display. Does anyone know what is happening here? Thanks in...
Try turning off your printer from the socket. Wait for several minutes, then turn it back on.
If the problem persists, i suggest you remove your printer's installation from your computer and then install it back again.
If you do not have the installation disc, here is a link to Lexmark's site, where you can download them:
http://support.lexmark.com/index?locale=en&segment=DOWNLOAD&startover=y&userlocale=EN_UK&question=P6250+drivers&productCode=LEXMARK_P6250&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_P6250&searchid=1271407894552#1
If none of this works, return the cartridges to the store and ask for a replacement.
If you find my answer useful, please vote. Thank you!
Mar 26, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark 5070 printer
Hard to tell...There are other issues which could contribute related to the printer itself, etc.
But I will say in my experience often refill kits for ink cartridges don't work if you allow them the cartridge to run bone dry. Maybe the internal components become hard and won't re saturate with new ink, not sure. If new cartridges work; and the refills don't I'd say there may be a problem with them.
Jul 22, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark p6250 does not detect black cartridge
did you do a clean and recalibration on these new cartridges/
You may also need a new set of drivers(never hurts)..get em here
Mar 22, 2008 | Lexmark P6250 All-In-One InkJet Photo...
"Cartridge Error" in the display.
I got this from Lexmark this morning didn"t work for me but it may help somedody else worth a try C/P. You need to clean NVRAM on Lexmark P6250 printer. Please find below the steps to clear the NVRAM on the Lexmark P6250: 1. Press the "Up" arrow and "Menu" button at the same time. 2. Press the down arrow until the LCD displays "Clean NVRAM." 3. Press "Select."
Nov 30, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark X3480
There are 2 possible problems, or the cartridge is a refilled one or some problem by the cartridge itself. Try to change the cartridge.
Nov 10, 2007 | Lexmark P6250 All-In-One InkJet Photo...
Dell 2600 Notebook Logo
54 people viewed this question
Alun Cox
