Question about Garmin Nuvi 660 GPS Receiver
My 680 locks up.
Hi!
I connect my GPS to the mount in the car. Press the on button. It loads the maps; stops at the "I agree" button", then locks up. Can't get it to go from there.
Any suggestions are appreciated.
Marvin
  • mmoberly Jan 05, 2009
    Thanks. I will try doing that. Appreciate it.
    Marvin
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, do a reset on the small button under the GPS antenna.
Should problem persist, pls post back. Was there any update done recently?
Good luck and Thank you for using FixYa.
Posted on Jan 05, 2009
    Genius:
  • 1,913 Answers
First remove battery from it then connect again then if problem still then rest it to factory defaults settings press power button for 10 seconds.
    Genius:
  • 1,550 Answers
Try to update the firmware to the latest .
You can get it from the garmin site .
Down loading maps on garmin gps
Check the map menu to see if the new map is on the unit. At the main menu, press the tools button then the map icon. Then press the "map info" button. Look to see if the listing shows the new map that you just downloaded or if the original older map is still there. Make sure that the map is enabled by a check mark next to the map listing.
Apr 25, 2013 | Garmin nuvi GPS
When I turn my Garmin Nuvi 680 on, and the first screen appears about not driving while operating the Garmin, I have to hit "agree" button several times before it goes to main menu, and from that...
Try performing a soft reset.
Disconnect the unit from any external power supply.
Depress the reset button behind the flip up antenna.
Reconnect the unit to the power supply and let it should work normally.
If the soft reset does not work, try performing a hard reset.
Caution: Performing a hard reset will erase all user information including favorites and bookmarks and restore the unit back to factory settings. Be sure to save any information before performing the hard reset.
With the unit off, press and hold the lower right hand corner of the screen while turning the power on until a pop-up appears. Press "Yes" to restore the unit back to factory settings.
Sep 21, 2011 | Garmin Nuvi 680 GPS Receiver
Wont stop loading maps
If your garmin nuvi wont stop loading maps, then you need to reaet the unit to get it to work perfectly fine once again. Try to hold down the power button for about 15 seconds and the gps receiver will restart, this time it will load normally and show you your maps.
If that does not solve the problem, then you need to back up your maps then format your gps receiver from a computer then restore the software and maps back on, that should do the job for you.
Hope this helps.
Dec 23, 2010 | Garmin Nuvi 465T Car GPS Receiver
Insignia NS-CNV10 won't start up - it begins to load (insignia logo, navteq maps, "loading application") but once it gets to the driver warning screen where you would press "I agree" it shuts off - this...
First, try resetting your player by inserting a thin tool (such as an unbent paper clip) into the reset port on your GPS navigator. A copy of the owner's manual with schematics can be found at InsigniaProducts.com, under the Support tab. If resetting the device doesn't resolve the issue, I would recommend visiting the place of purchase to pursue service options.
Mar 04, 2010 | Insignia NS-CNV10 Car GPS Receiver
Freezes on the loading maps message
Hook up your Nuvi to your computer and go to the Garmin site and download the latest driver software to the 680.
Jul 08, 2009 | Garmin Nuvi 680 GPS Receiver
Lost maps by updating
Unit comes with pre-loaded maps. Why update? Maps on DVD is the same copy as it's on the unit.
If you have troubles make sure you're not in Navigation mode when running the update. Update does not like files still in use.
Mar 23, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Tomtom map activation
Im pretty sure that Tomtom provided what you needed, if you did buy the map...
Mar 04, 2008 | Tomtom GO 700 GPS Receiver
Garmin Streetpilot i3 GPS cannot load map to memory card
The Garmin C340 comes preloaded with maps while the I3 require that the maps be installed onto a micro sd card.
You can place the micro SD card into a SD adapter and use a regular card reader to download your maps. When the software ask for 'Device' to download to use the drop down arrow and find your drive letter associated with the card reader. Using a card reader will be much faster since the it is ubs 2.0 vs ubs 1.1
You could also go to Garmin website and download and install the USB drivers, see link below.
http://www8.garmin.com/support/agree.jsp?id=591
Dec 27, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
