Question about Sewing Machines
Kenmore electronic sewing machine 385.1950280 (sensor 70) will not sew the specialty stitches, numbers or letters when the codes are punched in. Is the board bad?
I've read the manual and am punching in as instructed (and have tried other variations) but it will only respond in zigzag which changes to straight stitch. Is this a board problem? Or is there an easy fix?
  • 2 more comments
  • llazyme
    llazyme Nov 07, 2012
    The machine has a curved hole in the needle plate so it's not that.
  • Elle scooter
    Elle scooter Mar 23, 2014
    I finally had the machine fixed at a shop. Cost me $100 and it works great- would cost several hundred for a machine that does as much. Very happy with it now
  • Elle scooter
    ps.. this is llazyme under a different sign in as I couldn't remember my password.
  • Elle scooter
    The machine was actually stuck in reverse before.
  • Sewing Machines Master
  • 7,365 Answers
Yes, it's possible that the board is bad, having the machine checked
will tell you for sure
Posted on Nov 07, 2012
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
vash4me
  • 5 Answers
SOURCE: Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
Posted on Jan 13, 2009
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
  • 26 Answers
SOURCE: My Kenmore machine sews a straight stitch fine for
timing issue, needs to be serviced and re timed.
Posted on Aug 22, 2009
Zenqi
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
Does my kenmore sewing machine Model number 5151 do zig zag stitch?
I was able to find this photo on the internet. If your machine looks something like this
http://www.worthpoint.com/worthopedia/strong-vintage-kenmore-sewing-machine
Kenmore sewing machine in cabinet model 117 305 Collectors Weekly
Photo gallery Stitch in Time Must Liquidate EstateSales org
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=25&ved=0ahUKEwjXk5Gy3ZTMAhXhyIMKHaaSA_w4FBAWCEEwBA&url=http%3A%2F%2Fwww.searsarchives.com%2Fhistory%2Ffiles%2Fsewing_id.pdf&usg=AFQjCNEavJEwfhMVnix2pT0kwej_RSZ33A&cad=rja
then it most likely has zig-zag. There are a lot of dials and levers on this machine. Most straight stitch machines have only one or two. One dial/lever with numbers from 0-4 or 5 would be the stitch length. The other dial/lever with numbers from 0-4 or 5 would be stitch width, which would make a zig-zag stitch.
Apr 17, 2016 | Kenmore Sewing Machines
When I sew knits, the stitching is never tight enough. I have a Singer 7258. It is very loose and looks bad. What settings should i use when sewing knits?
here is a link for a free manual for the machine, it should have the information you need in it,, always use a scrap piece of fabric your sewing to adjust the tension, when adjusting the top thread tension do it one number or letter at a time and then sew on the scrap fabric, until you get the desired stitch you want.
http://www.singerco.com/uploads/download/617_7258-instruction-manual.pdf
Needle types
There are three main types of needles that are used for the majority of sewing, as well as many specialty needles.
Universal needles have a slightly rounded tip, and this general purpose needle should be used on wovens as well as some sturdy knits.
Jersey needles have a medium ballpoint tip designed especially for knit fabrics because it slips between the knit fibers and does not break or damage them while sewing.
Stretch needles, often confused with Jersey needles, are also a medium ballpoint tip, but these have a special eye and scarf that are designed for extremely stretchy fabrics and elastic. Swimwear is an ideal application for this type of needle.
Jun 18, 2015 | Sewing Machines
How old is my sears Kenmore sensor sew 70 model# 3851950180? Iwould like to know if it can be repaired
Almost any machine CAN be repaired, but it may not be worth the money to get it repaired and with older machines finding parts can be a real problem.
If you call Sears and tell them the model and serial number they should be able to tell you the age of the machine, and whether or not they are still willing to repair a machine like it. They may not have parts though.. sometimes independent repair shops are a better bet. Ebay is often a good source for old machine parts too.
Nov 18, 2014 | Kenmore Sewing Machines
I have a Kenmore 158.13500 sewing machine with no feed dog cover and i can't find one how can i free motion with the feed dogs in the way
Set the stitch length to 0. Find a thin piece of plastic and punch a smooth hole in it for the needle. Tape the plastic over the feed dogs and you're good to go.
Feb 04, 2014 | Kenmore 19233 Computerized Sewing Machine
Kenmore 100 stitch machine will not form stitches
it's probably time for the machine to be serviced
May 29, 2012 | Sewing Machines
How do I make a "space" in between the lettering. How do I enlarge to do stippling.
with the lettering mode, there should be a code number you program in for each letter, number and for a space as well.
Stippling is usually done by free motion stitching with a special foot so its not actually a stitch pattern, just a straight stitch that you form into the stippled pattern by moving the item as it is stitched.
Jul 20, 2011 | Elna 7200 Computerized Sewing Machine
It will sew three to five stitches and will stop. press go petal again and it will sew three to five stitches and stop
If its an older machine the foot conrtoller is probably in need of repair or replacement. A newer machine , computerized especially, will have electronic issues.
Derek
Jan 14, 2011 | Kenmore Sewing Machines
Stopping
What machine? If it is a 19606/19365 and you are using stitch number 19, then tha twould be normal. It is a tacking stitch. If it is not a electronic, please reply with a model number and I'll try to help!
Thanks,
Bonnie
Jul 29, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Setting stitches on my 19233 Kenmore
Just as soon as you can. Electronics have a shorter warranty period than mechanical problems.
sewman7
Mar 31, 2008 | Kenmore 19233 Computerized Sewing Machine
Kenmore 19365 decorative stitch will not stitch
You have to key in the number for the stitch on the stitch panel
Jan 22, 2008 | Kenmore 19365 Computerized Sewing Machine
Sewing Machines Logo
146 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
