My washing machine is a whirpool stylemaster model no. LXR9245EQ2 and it will not do anything besides put the water into it and it will only halfway drain. It does not agitate at all.
    Master:
  • 545 Answers
Washing machines work based on the motor running, which turns a belt, which generally rotates the drum and agitator and the water pump. If the motor or belt are either one not operating correctly, then you won't have a spinning drum or agitator. If you can get the water to drain out, you'll be able to service it.
Some models have the belt and pulleys accessible from the bottom. Most older models require the top section to be popped off the bottom (usually a flat-head screwdriver works), and then the front panel removed for access to the motor, and anything not accessible from the bottom. The water pump is normally accessible from the rear of the unit.
Posted on Nov 07, 2012
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically.
Here is the switch to order.
The part comes with a 365 day, any part, any reason return.
  • 36 Answers
SOURCE: Washing machine won't agitate
it sounds like the transmission is shot. Not knowing the cost of parts if you can replace the transmission yourself then yes it could be worth fixing however if you can't do the job yourself adding cost of parts and labor it may not be worth it
Posted on Jan 01, 2009
jsrock516
  • 5911 Answers
SOURCE: Washer won't drain
The symptoms you describe are typical of a lid switch failure. When a lid switch fails, the washer will fill, but stop at the spin cycle and will not drain. Sometimes it will fill, then stop. The switch is located under the washer top cabinet on the right hand side and is activated by a small plastic piece on the lid (called a "lid strike") through an opening along the right hand side of the casing next to the wash tub opening. First, make sure the lid strike is still intact on the lid. Next, open and close the lid and listen for a "clicking" sound. This is an indication that the lid strike is at least making contact with the switch. Then, check the two screws along the right side of the wash tub opening that hold the lid switch in place. Sometimes the screws come loose or fall out causing the switch to fail to contact the lid strike. In many cases, all that is required is to tighten these screws to realign the switch with the lid strike. If all these preliminary checks fail, the lid switch should eb replaced. The following link explains how:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you require parts, go to searspartsdirect.com and type in the model number you provided. The lid switch will be listed under the "Top and Cabinet" heading as item number 11. The lid strike is listed as item number 20.
Some other sites to view are repairclinic.com and appliancepartspros.com. Sometimes these sites offer better pricing on parts.
If you have questions, or if the diagnosis is incorrect, please post back and let me know. I hope this helps you.
NOTE: If the wash tub is full, you DO NOT have to empty to complete this repair. Once a defective switch is replaced, the washer will spin out and drain on its own.
Posted on Jan 23, 2009
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
  • 91 Answers
SOURCE: Will not drain or go into spin cycle
Definetly the lid switch has been knocked out of place or has gone bad.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Posted on Aug 26, 2009
dblred
  • 68 Answers
SOURCE: Washing machine stops mid-cycle, water doesn't drain
Sounds like you have a bad lid switch, or the plastic plunger on the lid that engages the lid switch is broke. if the plunger is broke, it is cheap, and only 2 screws to remove and put new one on. if that is not broke, check the lid switch. This model is a lid switch, and lid lock in one. You can test it before replacing it if you have a meter. you need to hinge the lid up to check and replace the lid switch. use a putty knife, on each side between the top and top of the front panel. slide the putty knife in one side, it will hit a bracket if your in the right spot. press in, and lift on that side of the top. do the same on other side, just don't let go of the first side or it will latch again. then swing the top back, the back side is on hinges. the lid switch is on the right side attached to the top. unplug washer, remove the 2 wires on the switch and check continuity. there should be continuity, or "open" when the lid is closed, and no continuity, or "closed" when you open the lid. if it is "closed" even when lid is closed, replace the lid switch. let me know if you have any further questions, shane.
Posted on Sep 12, 2009
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
WHAT IS THE SIZE OF MY WHIRLPOOL WASHER? model number LXR9245EQ2
We have the same model. We plan to purchase a replacement washer, and tank size is a major factor.
Machine manuals are available at www.whirlpool.com. It's great Whirlpool has the docs available online, but there was no indication of tank volume for this model found in the manuals: Parts, User, Instructions.
I decided to figure it out by filling the washing machine tank manually counting the number gallons of water dumped in. I managed to dump in 23 gallons before risking overflow. I don't recommend this approach since the specified water level limit for the tank assembly may be lower than the perceived water level limit. This volume test was performed on a machine that's being disposed.
Google says 1 US gallon is equivalent to approximately 0.1337 cubic feet. Applying this ratio to the number of gallons poured in, the volume is 3.08 cubic feet. If 24 gallons, then 3.21 cubic feet.
I'm sure the tank is not 4.0 cubic feet since that would have required another 7 gallons of water, beyond the 23 already poured in, making a mess on the floor, and potentially wetting machine wiring and other hardware that should remain dry. Even if we account for the space occupied by the agitator, it's unlikely an additional 7 gallons of water could be added without significant overflow.
4.0 cubic feet is approximately 30 gallons.
We're going on the assumption our LXR9245EQ2 washer is a 3.2 CF machine.
Dec 07, 2009 | Whirlpool Washing Machines
Aug 26, 2009 | Whirlpool Washing Machines
Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Jun 18, 2009 | Whirlpool Washing Machines
Whirlpool LXR9245EQ2 tub won't fill at beginning of cycle
HI, you have a combination issue. the Water fill level pressure switch and, the cycle selector switch are both damaged and, they should be replaced. the total cost of these switches will run you about $90.00.
We recommend the hands of a skilled service tech when repairing this type of electrical issue.
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
