Question about Gateway HD2201 22" LCD Monitor
How to remove the cover of my Gateway HD2201 Monitor
A pet sprayed my monitor. Liquid got behind the display and dried up. I'd like to try and clean it if I can...even if it means ruining the monitor. I have to try...I'd like to use it again without the black blob spreading .
  • 9 Answers
SOURCE: 19 "lcd gateway monitor will not power on.
Is this a Gateway FPD1960 monitor? If so the power supply inside of it died. It is a common problem with these. I repair the Gateway FPD1960 monitor so if you want to trash it let me know. You can contact me at sure-power(at)nc.rr.com
Posted on Jun 23, 2007
SOURCE: Green Light, no Display - Gateway FPD1730
I picked up a FPD1730 monitor for free which was just sitting out in my apartment hallway. I suspected something was wrong and sure e**ugh there was ** backlight, but I could see faint video when I shined a flashlight on it.
A quick Google search of the inverter model # led me to a German forum which suggested replacing the fuse labeled "F1" on the inverter board. I don't have a matching fuse on hand but I bridged the connection with a wire and sure e**ugh the backlight came back on. Short-circuiting like this is definitely **t 100% safe but if you can find a 4A fuse then it's a really cheap and quick fix.
Posted on Mar 09, 2008
  • 6 Answers
SOURCE: fdp2275w Gateway lcd monitor won't turn on. comes on for a second then goes black
Ok, I just got one last night, and it took a while to open the bugger. Why put screws when there are so many hidden clips to carefully pop? My poor Craftsman club card will never be the same! But, I digest...
There were two bad capacitors, the first and probably the main culprit was a 1000uF 25volt cap that had expanded and vented. I also found a 680uF 25volt cap that started to expand, and when tested it was low, about 550uF.
If you are so inclined, these can be obtained by mailorder (I use Parts Express), but Radio Shack parts can be used in a pinch, just expect to go back in there eventually. I didn't have the 105 degree low ESR caps, so I used regular ones and I had the monitor up and running in aobut 90 mins.
Check for any capacitors that are expanded at the top. Look for a dome shape or feel with your finger, it should be completely flat. Or look for the rubber bottom pushing out where it goes into the board. This is the third monitor I have repaired in the last six months, and each one needed one or two capacitors to fix a dark back-light problem.
Posted on Feb 10, 2009
  • 12 Answers
SOURCE: same problem 2 seconds on, then turns black
The problem with the monitor is the power inverter board. I took my monitor apart and tested all the power outputs. The ones going to the main board where ok but the ones going to the backlight where different. I changed the three capacitors on the power board that where located between the two heat sinks I think it was the 1000uf and the two 470uf. They looked ok but when i tested them they where off. Next on the opposite side of the board with all the little componites there are a few dry joins that you have to resolder. If you cant find then you can just resolder the whole back board it should only take 30min. If you have no idea what i am talking about i would not sugest taking the monitor apart.
Posted on Jul 28, 2009
leighblue31
  • 77 Answers
SOURCE: monitor goes dark after a few seconds
it looks like the video driver needs to be chcked. can you try to go to the bios of your omputer by pressing f2 on boot and let it stay there for 5 minutes? if it still goes to a black screen, its either your video card or lcd thats having a problem. but if it doesnt goes to a black screen in bios, its just the video driver. go then to safe mode by pressing f8 on boot. then uninstall and reinstall the video driver. or run system restore. restore it back to a working date thts by clicking start, then click all programs, go to accessories, go to system tools, click system restore, choose an earlier date and hit next, follow the prompts,wait for the computer to restart and that should work!
Posted on Sep 18, 2009
My Hoover 2X PetPlus Pet Stain & Odor Remover (64 oz) turned my off white carpet rusty orange! The liquid itself was orange brown. Is this the normal color?
I don't believe this is normal. I would contact the company. I would use 1 part white vinegar to 2 parts water and put it in a spray bottle. Use that to clean pet stains.
Sep 19, 2016 | Hoover Vacuums
Tip
Tricks Clean an LCD Screen
Enhance. Turn off your LCD monitor can be spots or areas that need to be cleaned more observable.Dust it off. Then use the microfiber cloth and wipe carefully collected the dirt off the LCD display.Use a suitable cleaning liquid. You can buy a cleaning kit, which are usually manufactured specifically to keep your LCD screens in the best conditions. There are LCD natural cleaning products and take into account.Work with the correct tissue. When cleaning LCD screens, use a good old cotton shirt or a handkerchief or buy special wipes to thoroughly clean the LCD screen. Spray cleaning solution on the cloth and clean with gentle circular motions. Let dry. Make sure your monitor is completely dry before using again.
on Feb 08, 2011 | Computers & Internet
How do I clean the LCD/LED screen without smudging or leaving a water mark
Hi Herkandjen,
Most TV companies recommend only a dry cotton cloth for cleaning the LCD screens. My personal experience is that using a mildly moist clean cotton cloth is the best thing for this purpose. For tough oily marks MILD soap solution can also be used in place of water. Please be careful to apply only very mild pressure while cleaning. Never ever spray the screen with any kind of liquid. Because the liquid if seeped through the plastic frame can damage the electronics inside. Happy viewing.
May 10, 2015 | LG Televison & Video
Display problem on HP AiO
I'm afraid your display has been damaged by the liquid. Just a few drops getting behind the glass are enough to loosen electrical contacts or even damage the LCD elements themselves, and once that happens it can spread from a small area to a much larger one, as you're seeing on your unit.
Sorry, but you'll need to have the display replaced (they're almost impossible to repair). The rule of thumb for cleaning all displays, from the smallest to a huge flat screen TV, is that you should never spray any liquid on them, or even use a wet cloth. Instead gently wipe them with a dry dust cloth or, if really marked up, barely dampen a soft cloth with a safe-for-screens cleaning solution and use that. Don't press hard -- certain screens can be damaged by pressure too. There are exceptions -- watches rated for underwater use come to mind -- but it's better to safe than sorry.
May 01, 2014 | HP Pavilion Computers & Internet
Keeps coming up with main menu
Fisrt thing to check is the monitor screen button.
if you clean your monitor there is chance that cleaning solution got inside the button and then even if you dont push on it, it does get a signal from the liquid trapped inside. you can try drying the solution with a hair dryer, but if the liquid leave a dry conductor inside the button this will be still there. the other option is to tear appart the monitor and unplug the button or manually try to clean the contact inside.
if you did not cleaned it, the menu button might simply be stuck in.
trying to release it can fix this.
Jan 03, 2014 | Hanns.G Corporation Computers & Internet
Can this be fixed?
Buy a WD40 liquid thine silicon spay and then open the camera body. Now spray the solution on the circuit board & batter connector. Clean them by dry clean cotton. Don't use spray on lens. After that fix the camera and then insert the new battery and see the result.
Aug 04, 2012 | Nikon Coolpix L120 Digital Camera 14.1mp...
Whats the best cleaner to use on the outside of this model?
My Favorite is SIMPLE GREEN - it's got the "ooooh-ahhh" fresh smell to it -- You would not need full strength Simple Green for cleaning or to get the desired oooh-aaah out of it... and as Andy mentioned it is non-toxic and an all natural cleaner
The original Simple Green, as in a dark green colored liquid (even in a spray bottle) is typically full strength -- You can easily cut it with 10x water to get to the "mean green" brand (which is Simple Green cut 10x) and either works just fine.
PS: Don't be bashful with the water,. definitely try small scrub brush for stubborn dirt, goop, etc.,. do a nice damp and/ or a dry towel dry -- and if really blasting with water,. let the dry out overnight if necessary.. prior to plugging it back in...
If necessary, you could concoct a cleaning rod out of a coat hangar by tying some pieces of rag on it and running it through the pipes.. just make sure your knots are tight so the cloth doesn't come off in the pipes and or hoses (or perhaps even a garden hose for the pipes if they come off or are otherwise accessible for that. And/ or alternatively use a small scrub brush around the edging of the unit to get any crevasses on the outside of the unit,. etc.,.
Don't forget the once over on the beater brushes also! :))
So now Crystal -- being the curious sort I am,. How did I get the request to answer this one?? -- Yes I added you (with your cute pic) to my connections... ;))
Best Regards
Ck
Aug 17, 2011 | Hoover U6630-900 WindTunnel Bagless...
What is the best way to clean the monitor screen?
The TFT or LCD screen is one of the most expensive component of your notebook or desktop computer and they're very sensitive to dust, fingerprints or even when you cough or sneeze without covering the mouth and nose.
Unlike the standard CRT monitors with Glass screens, you are not advised to clean an LCD Monitor by wiping it with a piece of dry lint-free cloth since the sensitive display is likely to get scratches from dust particles.
So how do you clean an LCD monitor screen without buying any of those expensive LCD Monitor Cleaner solutions or Monitor Wipes available in the market ? We look at some proper methods and precautions before you clean the monitor [should apply to HDTVs, projection TVs and Plasma TVs as well]
Think of LCD Displays just like the soft and delicate skin of your newborn baby - Be very gentle and never put even the slightest pressure on the computer screen with your hand.
Second, you need to find a piece of soft cloth - old cotton handkerchiefs lying in your mom's wardrobe should be fine but don't try tissue papers, toilet rolls or even shower towels as the fabric will scratch your screen permanently [like sandpaper or utensil scrubbers]
Either turn the monitor off or set the background to black and hide all the desktop icons and minimize the open windows. This will easily help you identify the dirty areas of the monitor.
To prepare the solution for cleaning LCD monitors, you will need deionized or distilled water and vinegar or iso-propyl alcohol - Don't use tap water or mineral water as they could leave white marks on the screen because of the dissolved salts.
Dilute the vinegar or IPA with distilled water [1:1] and spray this liquid on the cloth. Never ever spray liquid directly onto the LCD screen. Moisten the cloth with this home made LCD cleaner and gently move the wet cloth in just one direction - from top to bottom.
Word of Caution: Be sure that the LCD screen is dry before closing it or using the computer. Do not use any solutions that contain Acetone, ethyl alcohol, toluene, ethyl acid, ammonia, or methyl chloride. Never touch the LCD screen with your fingers as this can cause the pixels to burn out.
Jul 03, 2010 | Microsoft Realsync DS771 17 Black LCD 8ms...
Black spot on the monitor .
I beleive the liquid had leaked into between the LCD panel and the filter sheets. Hopefully it will dry out, otherwise you have to disassemble the panel which not to be done unless you have clean room to work in.
May 06, 2010 | Acer AL1916W 19" LCD Monitor
Liquid behind the screen
put a hair drier on low at the source of the problem, that should fix it.
Feb 10, 2007 | Toshiba 46H84 46" Rear Projection...
Gateway HD2201 22" LCD Monitor Logo
110 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
