Question about Maytag Washing Machines
My maytag washer front loader door will not close ( latch shut)
I cannot get my front loader door to shut ( latch closed). iIhave tried with the power off and with the machine powered on.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 08, 2012
worldvet
  • 859 Answers
SOURCE: washer front loader
Does your model have a Male Female latch, where the femal receptor of the male plug is plastic?
Regards,
Worldvet
Posted on Sep 06, 2008
  • 155 Answers
SOURCE: front load washer door won't latch, close.
possible cause is faulty door latch also check latch on door for any raised or damaged surfaces next try pushing on door slightly if it latches and starts most likely door problem look more closely hope this helps
Posted on Nov 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet washer ghw9250mw1 door won't close ...
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
SOURCE: door won't close/lock
Just had the same issue. The latch, which rotates up and forward, is spring-loaded towards the rear. If 'tripped' to closed position, it cannot rotate back down until it's carrier/hinge slides slightly forward. I bent a sturdy wire into a long 'U', then bent both ends down (~3/8in) and slightly outward to hook over the latch-hinges and pull both sides gently (its plastic) forward, while rotating the latch downward with a small screwdriver. be careful to keep what appears to be a brown plastic button raised, if it pops down from above the latch. Yes, having 4 hands would help, but the 'U' wire can pull from behind the two outer edges with one finger. Once the latch rotates down, release tension on the 'U' wire and extricate it - problem solved.
Jon (We don need no steenkin manuals)
'Build a more idiot-proof machine, and the universe will build a better idiot.'
"We don't take no s*** from no machines."
Colonel Jason Grant (Walter Koenig), Moontrap 1989
Posted on Dec 19, 2010
  • 472 Answers
SOURCE: I have a Maytag front
sounds like you got a bad door switch.... make sure the door switch is actually latching and the wires are still connected.... if all is good there then the pcb controller which is the main board is bad.....
Posted on Dec 31, 2010
Electric dryer not get heat
Inspect the front door lock if "F22" is displayed. Press the "Pause/Cancel" button two times. Close the washer door firmly to latch the door. Remove clothing preventing the door from closing and latching. Press the "Power" button, followed by the "Start" button.
May 12, 2012 | Maytag Epic 7.0 Cu. Ft. SuperSize Capacity...
Problem with door closing
The latch needs to be adjusted. Does it need a repairman? That all depends on how mechanical minded you are. Put a THIN piece of plastic behing the latch. The lid from a butter dish will work. Try it. Don't move it out too far, or it will leak.
Mar 20, 2010 | Maytag Neptune Washer
Can't get the door to unlock? Load in washer is beeping ND..not draining but after several attempts inlcuding shutting power off..still can't get the door to disengage?
In front loader machines there is a safety latch that stops you from opening the door if there is water in the machine. I think it needs power to release the latch, I am not familiar with this model.
You probaly need to drain the water off somehow.
Dec 16, 2009 | Maytag MAH2400A Front Load Washer
417 front loader washer - door doesn't register as closed, washer won't start all lights are lit except "door locked" of course I"ve tried to close door fully, unplugged, etc. but no go
The door lock/latch mechanism has failed.
Replace it.
Aug 07, 2009 | Kenmore Washing Machines
Washer front loader
Regards,
Worldvet
Sep 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front load washer door
A lot of these errors on these front loaders can be resolved by simply unplugging the washer for 30 minutes to reset the computer. You may also attempt to manipulate the door latch by using the manual release lever to see if you can get the latching mechanism to stay open. The following link explains how to do this:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
This is normally used when the door is latched with the door shut, but it still may apply in your case. If you attempt any of these preliminary checks and the latch still does not work properly, I would recommend replacing it. The next link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Hopefully you will not require any replacement parts. But, if you do, a replacement latch can be found at searspartsdirect.com or repairclinic.com. Just type in your complete model number to perform a search for parts. I hope you find this information helpful. Let me know if you require additional assistance.
Sep 01, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
