Question about Samsung HLN617W 61" Rear Projection HDTV
Our Color TV is now Black & White
We bought this tv (Samsung DLP Hln617W) end of 2004 and have already had to replace the bulb. Now a couple days ago i'm watching and hear a pop and then the picture goes out, so i turned it off. Next day we turn it on and we have picture, but only in black and white (not a negative looking type of picture) just no color on the picture or any of the menu or control panels that are brought up on the screen. Any idea what might be the problem? Whatever it is, i sure hope it's not going to be another $500 repair. Thanks!
    Champion:
  • 217 Answers
It sounds like the main board to me, I can purchase them if you want one let me know
Posted on May 27, 2007
Samsung DLP HLN5065W tv Black & White Picture
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
May 23, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
My DLP617W is black and white today and tried everything I know, does not work. Any suggestions ? Thank you.
i'm probably sure that is the dmd let me know a couple of things.
TV make's were noises? the white spots comes and go?
it look like this?
Dec 28, 2009 | Samsung HLN617W 61" Rear Projection HDTV
My Samsung DLP model HL-P6163W keeps turning on and off and now lights are flashing. We replaced the color wheel last year and about two years ago the lamp.
could still be the lamp but it could also be the Ballast for the lamp has failed. I've replaced a lot of Ballasts on DLP machines.
Nov 17, 2009 | Samsung 61" Slim-Depth DLP HDTV
My samsung dlp tv model#hln617w keeps turning off. Only stays on for 2 minutes. I replaced fan #2. Thunking that was the problem.
Why did you replace the fan was it noisey and did that cure the noise. These sets commonly have problems with color wheels-do you get motor noise at startup?
Sep 30, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Apr 29, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Samsung dlp model hlp5067wx
the color wheel has to be replaced. (Technican Job) this device is inside the light engine,
Jan 06, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Mar 26, 2008 | Samsung HLN617W 61" Rear Projection HDTV
It could be the color wheel and in fact probably is. I've seen them shatter which would explain the noise. They are glass and spinn at 9000 rpm. An involved repair though definatley a job for a pro. It could be worse, probably a few hundred will do it. Was the TV begining to be a little loud before the failure? Could be a sign, i've seen many noisy color wheels.
May 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
160 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
