Question about LG DLG1320W 7.0 cu. ft. Front Load Gas Dryer
I need to convert my new LG dryer from natural gas to liquid propane. Can you send me instructions on conversion/installation from beginning to end? Thank you!
    Top Expert:
  • LG Master
  • 9,472 Answers
Here is a video to walk you thru the process. Keep me posted should you need anything else.
Posted on Nov 08, 2012
4 Suggested Answers
  • 489 Answers
SOURCE: LG gas dryer to convert in propane
If you replaced the orifice on the gas valve, then you must screw down on the adjustment screw on top of the valve.  Use a flat screwdriver and screw down the pressure adjustment screw till it stops in the down position.  Then the valve is set for propane use.
Posted on May 26, 2008
MNTECH
  • 1543 Answers
SOURCE: I am trying to open my lg tromm dlg 5988w dryer to
Remove three screws on the back holding the top cover, then standing in front of machine, use the palms of your hands to sharply push back on the L and R edges to move the cover back about 1 and a half inches, then lift cover off. Top cotrol panel is held on by a screw at the top corners and tabs along the top edge. Watch out for sharp edges. Remove control panel and place on top or dryer drum with wires still attached. Open door and remove screws at 4 and 8 O'clock positions, the the four screws along the top of the front panel. Unplug the light and door switches and remove the front panel. That should get you most of the way there.
Posted on Nov 12, 2009
Testimonial: "perfict just what i needed. Thanks"
  • 129 Answers
SOURCE: can my LG natural Gas dryer be fitted with a
orfices, gas valve and regulator
Posted on Feb 02, 2010
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
Do I need a part to convert my Maytag gas dryer/washer combo back from propane to Natural Gas?
Yes you can, but whether you should is another matter. I purchased a new dryer and needed it to be propane ready...you need to get the proper orifice (which lets the gas in to the burners) changed out. Natural gas orifice has a larger hole than a propane orifice. In addition, the regulator must be modified. It may involve flipping an insert under the cap (typical of stoves) or it may require conversion parts packed in the conversion kit (order one specific to your drier). This regulator is part of the piping within the back of the drier.
Incidentally, conversion orifice(s) should be included with the drier and screwed to the body in a clip. When you change it over and label the equipment as converted to propane, put the old natural gas orifice in the clip and screw it back onto the body. Put the instructions in a paper envelope and tape to the outside of the body of the drier.
Apr 27, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Liquid Propane vs. Propane (like used for BBQ)
They are the same thing.
The propane you buy for your BBQ is liquid in the bottom of the tank. At the top, it comes out as a gas, which you run through a regulator and then into your grill. If you by some chance turn the tank sideways, the valve inside will shut and keep the liquid propane from coming out. If it did you could have a serious fire.
However, there is a difference between what most folks call "Natural Gas" and propane. If you have gas piped into your home, it's natural gas and not propane.
Natural gas dryers won't run right on propane (LP Gas) and vice versa. There is usually a conversion kit you can buy to switch them over.
Oct 14, 2009 | Dryers
Dryer has been converted to propane using conversion kit #131776600 and I need the info needed to get it back to run on NG The dryer is a Fidgaire Gallery series model #FDGC648GHS0 any help greatly a
Hello there. If the parts were saved, they can be reused. If not, contact your propane provider and tell them that you plan to convert back to natural gas. They will be able to get you the kit you need, and will possibly have a technician come out and install it for a fee.
May 27, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
May 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
COnverting it to propane
You need to change the orifice on the end of the gas valve and flip the cap on the regulator to the LP side. Model number would help.....?
Oct 30, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Conversion back to natural gas
4948EL4001B back to natural part number LG will only sell it qualified techs..but here's a start.
Jul 09, 2008 | LG DLG3788W Gas Dryer
LG DLG1320W 7.0 cu. ft. Front Load Gas Dryer Logo
108 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
