Question about Sanyo HT32744 32" TV
Hdmi shows hd not turned on - Sanyo HT32744 32" TV
    Top Expert:
  • Sanyo Master
  • 14,553 Answers
Check the input is HD and if using a box unplug for a while and power back---box will reboot etc.
HDMI can be touchy and does not like being disconnected or connected if unit is powered or on.
If the set has a component input for HD try that also instead of the HDMI.
Posted on Nov 08, 2012
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
Hdmi screen format problems
try it on av tv it may view and explain briefly i cant understand
Dec 08, 2007 | Denon AVR-3806 Receiver
Connecting Ps3 with philips tv (full hd) when i got hd cable in, and click to switch so the ps3 uses hd to show things and i than switch over to the channel i plugin the hdmi cabel it gives blac kscreen
If it's the first time using your PS3, use the composite cables that came with it. Turn on the PS3 go to video settings and switch the input to HDMI. After you've switched to HDMI, turn the PS3 off and connect your HDMI cable, go back to video settings and change the resolution to 1080p. If this isn't the first time you've used HDMI for your PS3, make sure your T.V. is on the correct input. If the T.V. is on the correct input, try switching the HDMI cable to a different input. If that doesn't work try using a different HDMI cable, testing different HDMI connections if you're still getting the black screen. If none of those work then it's probably a problem with the PS3, but just to make sure try plugging something else with HDMI to see if that works. If another HDMI device works, then it's your PS3, if it doesn't then it could be a problem with your HDMI connections on the T.V.
May 04, 2011 | Philips 52 In. LCD HDTV
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
Cant get our HDMI to work on our JVC HD 58S998.
First, contrary to popular opinion, HDMI cables connect to a tv are not the best way to connect the two. The HDMI technology has flaws that often shows up as sound problems.
If your TV has the capability for component connections, use them. It will take 5 cables, 3 for video and 2 for audio. You will get superior sound and video. The 5 cables terminate in RCA type connectors and are much cheaper than an HDMI cable.
I hope this helps and solves your problem. :-)
Jan 03, 2010 | JVC Televison & Video
Bravia & Sky+HD, aspect problem
There is nothing wrong with you Sony Bravia TV and it suppport all HD and SD formats.
Are you viewing the HD version of the channel when it is showing a standard defination show. e.g SKY1 HD instead of SKY1.
This means that regular standard defination shows are in a 4:3 ratio and does not fill the whole screen. In order to view these type of shows you will need to tune to regular channel instead of the HD version.
You can check if a show is brocast in HD by going into the tv guide and checking for the HD symbol in the programme symposis.
Example
Apr 13, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
HDMI SOUND
True HD can only work with HDMI interface and is only available on some newer HD DVDs. Check the DVD to see if the True HD encoding is available.
Feb 11, 2008 | Onkyo TX-SR605 Receiver
Samsung LTP326w
After few years of service with different TV providers I have problem with my TV. Last night my Samsung LTP326W just did the same think on HDMI connector and no mater what you do it will not turn HDMI video... it's connected to Verizon/Motorola DVR I called Verizon and they promptly replace DVR and HDMI cable but it didn't help at all, also sometimes when you power on/off I get message: The HD Content Protection of your display has been compromised Please use the YPBPR outputs for your HD connection...
When I switch to component cable it works just fine.
Feb 09, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
Sanyo HT32744 32" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
