Question about Food Mixers
Replacement lid for a wahl james martin mixer zx590-1
The lip on the mixer lid has snapped where it makes contact to activate the mixer
I need a mixer blade for Andrew James hand mixer
Fixya does not sell replacement mixer blades.
Jul 29, 2017 | Food Mixers
Piece of lid broke off
Sand the area on bottom of piece along with areas surrounding the broken piece. Get another small piece of plastic that is large enough to cover the broken piece and adjacent areas and apply the glue to that using a good epoxy for adhesion. Let it set up and it will hold - trust me.
Sep 27, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
The lip of the planetary ripped off and I am having a trouble replacing it for a Kitchen aid K5-A mixer
The planetary is replaced by removing the chrome drip ring from the housing and then knocking the through pin out that holds the planetary hub onto the shaft from the gearbox. In New Zealand the planetary comes as individual parts not an assembled unit so will certainly look different to the full assembly you take off. The lip of the planetary ripping off is most likely caused by one or more of the 5 gearcase screws under the planetary coming loose and rubbing. Check the other 4 (total) screws at back and middle of gearcase as well.
Nov 23, 2013 | Food Mixers
I have a Hobart N50 and am in need of a SS bowl. The bowl pins are 8 7/8" apart. Do they make a replacement bowl for this? I've seen the ones that have 9" bowl pins. Thanks, Ron
can buy hobart bowls from lots of places, or use the correctly shaped kitchenaid ones, both fit.. i like the lip and thickness of the hobart bowls, bought mine from globe equip.. do u still have the service manual, if so i would be real intrested in it, please
Jun 14, 2009 | Hobart N50 Stand Mixer
My Super Grinder needs repairs
the blade of the jar got jamed, you have to remove the jar shaft and lubricat with any oil and refix it back
Feb 02, 2009 | Food Mixers
Mixer won't start
your problem sounds like the thermister is burnt out.
Sep 26, 2008 | KitchenAid KP2671 Professional 6 Series...
Kitchen aide mixer
was the bowl snapped in to place.....push down on the back lip of the bowel until you hear it snap
Dec 30, 2007 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Food Mixers Logo
66 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
