Question about Lenovo Computers & Internet
I have lenovo 44463fg laptop why it is not charge do you tell me the charging ic name thanks
I have lenovo 44463fg laptop it problem in charging or to say in its not charging it also on at baitre. and when i conected with dc power or charger its shows me charging but not charg
  • Lenovo Master
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Nov 08, 2012
SOURCE: my eee pc charger wont charge my laptop...
we had a similar problem the ac jack socket burnt out so we got a replacement part from ebay and my husband put it in and hey presto it works it cost 6 pounds for the part whereas a company to fix it wanted 100
Posted on Jul 19, 2009
issken
  • 1472 Answers
SOURCE: dell 1525 not charging. dc usb board replacement
rubberman
Sorry to hear that you are still having trouble. The only other thing to try is your battery on your buddies notebook. If it works there then it is the charging mechanism on your notebook and this would mean replacing the motherboard.
Issken
Posted on Jan 11, 2010
  • 6 Answers
SOURCE: battery charging,and can't run laptop on battery
u need a new battery.
Posted on Feb 28, 2010
  • 2567 Answers
SOURCE: Hellow Dear, My acer aspire 4935
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 15, 2010
SOURCE: My lenovo G550 appears not
Hi m529,
I see you are having issues with you G550 charging.
You mentioned that the light on the charger is lit up but then it suddenly switches Off, and you also mentioned that the charge still has a light but the power is somewhat low despite of a fully lit up charger Light.
Have you tried draining the power from the system?
  • Remove the battery and the Charger or AC Adapter as well call it from the G550 then press and hold down the power button for 10-15 seconds to drain power from the system motherboard.
  • Once drained connect the AC adapter but do not connect the battery yet, then turn the Laptop ON to see if the system will power ON using the AC adapter/Charger if it powers up then there is no problem with the AC adapter/charger.
  • After testing the AC adapter if it is working power down the Laptop doing a normal shut down.
  • Once shut down or turned Off insert the Battery back in the Laptop then turn the Laptop ON using the battery only without the AC adapter/charger see if the system will turn ON using the Battery only.
  • If the Laptop powers On using the battery alone with out the AC adapter then the battery is most likely working as well on the issue.
  • Now power down the Laptop then connect the AC adapter to the Laptop with the Battery in the Laptop as well then turn the system ON again see if the problem will Occur again having the battery and the AC adapter/charger if the Problem happens with both Battery and AC adapter on the Laptop then the problem is the Motherboard, most probably the motherboard is having issues relaying power from the AC adapter to the battery and may be sent to the Depot for repairs.
I suggest that you call Lenovo for further information about your system, if you still have warranty and is still in the one year period then your system will be covered for any repairs needed - you can call @ 1 877 453 6686 for troubleshooting, you will be asked for a serial number Located underneath the Laptop on a small white sticker that states s/n meaning serial number.
I hope that this Helps.
Have a nice day,
mvincentc
Posted on Jun 21, 2011
Lenovo ThinkPad T520i Battery
Have you check your Charger for Proper Voltage? Is it Providing Proper Voltage to your Laptop? Check it First.
This Problem can Happen due to bad Charger or due to the Charging IC not Functional properly, which is located on the Board of the Laptop
Aug 11, 2012 | Lenovo 423947U - Thinkpad T520I 423947U...
Lenovo g410 not charging
This is going to be one of three things either your power supply is not giving out enough voltage to charge the battery, have you tried another psu?
If its not the psu then it could be the dc socket being loose on the mainboard or the fuse which controls the charging section has blown which means you need a replacement mainboard. Usually its either the charger or dc socket
Mar 23, 2012 | Computers & Internet
My name is Kelvin, am having problem with my battery, my laptop is Compaq 615. is telling me to consider replacing battery, why?
Typically these automatic battery replacement messages are generated by a few different things.
1. number of charge cycles the battery has been through, typcial recharge rating for LIon batteries in laptops is 500 cycles.
2. The charger circuit in the laptop has detected that it cannot charge the battery as much as before.
3. Based on rundown time that the laptop experiences, ie how long a battery is lasting compared to new.
On my Lenovo X series, I started noticing that battery life was down from 6 hours to about 2.5 or less and then I got a message from the power monitor software that informed that my battery was only capable of holding 32% of new charge. As I rely heavliy on my laptop in situations that have no battery power I elected to replace the battery. If you do not use the battery much, then you can likely chose to ignore this message.
Jul 02, 2011 | Computers & Internet
My lenovo s10 does not detect the battery. The laptop only works if the charger is plugged in, not off the charge. OS is windows 7.
System recognizes the battery is by the battery's ID resistor, IC internal device name, and if system PIN access to system ground.
So this issue maybe caused by 2 possibilities:
1.If you have installed some software will affect the system BIOS, resulting in-abnormal communications between systems and batteries, so the battery can not be recognized. (If you can find a same battery is all good, try to check that if system BIOS is in-abnormal.) 2.You haven't use the battery for a long time and pack-self discharge (self-discharge) led to Gauge IC (chip) shut down, So the battery can not communicate with the system led system does not recognize it. If your Lenovo S10 battery is a 3 series one in P +, P, you can use 12600mV, 200mA to get the current through, touch click on is OK. This is nothing with your Lenovo power adapter.
Apr 28, 2011 | Lenovo S103 Netbook
Lenovo Z560 laptop battery charge drops from 50% down to 7% suddenly. And after that, i need to charge the laptop where it gets charged till 99% only. What is the problem i am facing now?. I purchased the...
A sudden drop from 50% to 7% means that the battery is faulty, it is simply a case where it is not holding any charge. I would suggest you contact the seller and check if the battery is under warranty. Hope this helps and good luck.Any question please feel free to ask.
Dec 30, 2010 | Lenovo IdeaPad Z560 Notebook
I have formatted my lenovo G55O System,and i have no audio driver ,so plz tell me the actual path in internet to download it safely and securely. thanks
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, Driver downloads and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Nov 20, 2010 | Lenovo Computers & Internet
Nokia 6300 Cellular Phone
try to replace a new and tested one..if still fast drain your nokia 6300 is shorted and need to remove the shorted parts..thanks
Jun 10, 2010 | Nokia 6300 Cellular Phone
Computers & Internet Logo
110 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
