Question about Health & Beauty
I need a replacement lid for a Wahl James Martin mixer zx590=1
The lid has broken and won't work the machine as the lip making connection has snapped off
Hello, I too have been looking for a replacement blade spare part for this machine. Unfortunately it appears there are none! However I have a lid and wonder whether you would be interested. If you are still needing one please contact me on
norma_sheppard@yahoo.co.uk
Kindest regards
Norma sheppard
Posted on Feb 02, 2013
User manual for jamesmartyn food processor
Actually the James Martin processors are distributed by Wahl. You might try contacting them here to see if they can help you find your manual.
http://www.wahlglobal.com/united-kingdom/contact.html
Sep 05, 2014 | Food Processors
Washer won't spin
just a guess maybe belt is broken or main shaft
Mar 08, 2013 | GE WJSR2070B Top Load Washer
The blender jug from the ZX717X-1 food processor has seized up
hi, where can i get the manual for this food processor?.
Thanks
Feb 27, 2013 | Food Processors
Washing machine top loader aqua smart the lid cannot lock while washing. I have tried switching the machine on and off, still won't work. This happened a little while ago but then is rectified i
Is the lid lock tang on the lid ok & not broken.
You need to jam the lid lock lever in the lid lock down for it to do a wash.
This is where your lid lock is
Feb 21, 2013 | Fisher and Paykel GWL11 Top Load Washer
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
Washer fills up then stops?
check the door safety switch,, if it isn't working it won't continue,, check around the door ( lid) you will see the switch, its usually under the lip, once you get to it, you can go to the connector, and unhook it,, and on the side away from the switch, place a jumper wire on the connections,, it should start, if so , replace that switch
Aug 12, 2011 | Kenmore 24042 Top Load Washer
Just replace motor coupler a few days ago...now washer filled up, washed & got to rinse cycle then stopped. Turned dial back to wash cycle, won't work. Checked lid switch, not broken. Jumped outer...
since the coupler is new and lid switch was jumped i would be looking at the connections on the motor plug that you disconnected to replace coupler depending on your exact model there is the main plug the 2 wires on the capicator and a smaller plug. BUT FIRST recheck lid switch what must be jumped out is the connection leading up to control panel and NOT the part in the cabinet
to me a appliance tech w/30 years experience it sounds like a bad lid switch!
Aug 10, 2011 | Kenmore Washing Machines
Whirlpool duet Washing machine won't drain
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive or spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
May 11, 2011 | Whirlpool Washing Machines
Health & Beauty Logo
145 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
