Question about JVC Televison & Video
Jvc av32d305 has sync problem rolling vertically and horizantally
    Top Expert:
  • JVC Master
  • 14,553 Answers
You are going to need a schematic---the sync pulse either comes on a line from the high voltage transformer or the Jungle chip---my money would be a open resistor from the Flyback with that pulse for sync.
Posted on Nov 08, 2012
My 6 yr old jvc av32d305 tv just went off. The green light is on I unplugged an plugged back in. Cannot power back on no sound or picture
The power supply regulator section inside the TV has to be troubleshooted. This is a skilled work.
Apr 01, 2012 | JVC Televison & Video
Zenith b25a24z has a line in center of screen and i replace the verticle output ic and the problem remains can somebody help me?
was the line vertical or horizontal? if vertical check on the horizantal sync side if horizontal check vertical side also check for dry solder joint on the circuite.
Apr 07, 2010 | Zenith C27A24T 27" TV
My roller will roll to side to side but wont push down on my blackberry phone
PLEASE FOLLOW THESE STEPS AND CHECK Go to main menu Go to Options. Select the Screen and key board. Scroll down and Select Horizantal and Vertical sensitivity to 100.
Hope it works
Nov 16, 2009 | AT&T Blackberry Curve 8300 Smartphone
View is vertical not horizantal
Ctrl-Alt-Up Arrow key
Or look in Control Panel>Display>Adapter settings for settings specific
to your video card.
Jun 25, 2009 | Computers & Internet
VERTICAL AND HORINZONTAL
maybe your tv is set to PAL mode set it to NTSC, or else your tv is out of sync.check the jungle.
Oct 08, 2008 | JVC AV-27530 27" TV
Vertical hold problem
Maybe sync separator transistor is faulty
Dec 22, 2007 | Zenith C32A26 32" TV
PROBLEMS WITH VERTICAL ROLL
That is not a vertical roll from side to side, this is a horizontal rolling. if the vertical had a roll it would be going from top to bottom. This is most likely a coupling between the horizontal sync circuit and the sync separator circuit. Good Luck
Jun 28, 2007 | Sony KP-53S65 53" Rear Projection...
Vertical rolling
Does you set have PIP (picture in picture)? If it does then the PIP module has a bunch of capacitors that have gone bad (dried out and leaked) causing you to loose vertical sync. Vertical synchronization is what locks your picture keeping it from rolling. Even if you don't have PIP then still you have a vertical sync problem. The set would have to be checked by a tech to find exactly what's happening. Stargazer
Mar 04, 2007 | Mitsubishi WS-55807 TV
Picture keeps rolling
The picture rolling is simply because the PAL decoder can't lock up to the 60Hz vertical sync pulses, even if your DVD player is set to NTSC-PAL conversion and there is no vertical hold adjustment (either external or internal) on this model set to achieve this. There is a possible alternative only if your DVD player has RGB output (not component). The JVC for example has direct RGB drive capability via the SCART input on the back panel. If you get a suitable lead you could try getting a picture this way as it bypasses the decoding and sync sep circuits in the PAL decoder chip.
Oct 03, 2005 | Panasonic DVD-F87 Multi-disc DVD Player
Televison & Video Logo
59 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
