Question about Air Hogs Havoc Heli Helicopters
Havoc heli flight problems
The tail prop for my havoc heli broke and was replaced. it still flops around looking wounded after spinning out of control. i noticed BEFORE the tail prop broke that the tail was broken so how could this be the problem? any help will be much appreciated.
    Problem Solver:
  • 11 Answers
Make sure the blades and rotors are free of debris. I had the same problem then noticed hair had gotten wrapped around the blades. Once you remove the hair or thread or string or whatever it should fly fine
Posted on Jan 05, 2009
My helicopter has no lift even when fully chargered. The props are spinning but it just stays on the ground.
i got a new model havoc heli and the trim buttons did not help at all... in the end I took a motor/prop off of an air hog styrofoam plane I had that was identical to the havoc heli tail rotor and swapped em out.. Problem solved... there was some sort of error with the tail rotor
Mar 22, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
Apache havoc micro... can not trim the helicopter it spins counterclockwise.
the cause of this issue is hair or something preventing the tail rotor to spin properly.. i had this issue and checked mine over very good, noticed the hair in tail rotor, and then took a needle to fish IT ALL out.. if u dont get it all.. it wont trim properly cause it cant spin fast enough
Mar 02, 2010 | Air Hogs Havoc Heli Helicopters
Hi, the main rotor of my havoc helicopter is spinning in an unbalanced way and causing a high level of vibration making flight impossible
Look on the underside of the rotor. You may be missing one of the small metal weights that balance the rotors.
Jan 08, 2010 | Air Hogs Havoc Heli Helicopters
My Havoc Heli is really hard to control and I need help.
You have to keep tapping the right trim button. Keep tapping it until it stops spinning. If the spinning stops and it just turns, Use the the left right moving analog un til it flies straight.
Mar 15, 2009 | Air Hogs Havoc Heli Helicopters
Spinning no matter what i do
Issue: Heli spins to the Left (counterclockwise) uncontrollably.
Problem: Tail rotor not turning fast enough, Dragging.
Background: My son's Heli Cage also started spinning to the left after he had flown it a couple 3 times. The trim and direction stick could not compensate. One time, the tail rotor came off during a crash. It was put back on and ran fine a couple more times until the dreaded left spin. I began to troubleshoot the issue. I checked for damage, hair and whatever else on the shaft. There was no obvious signs. When I pulled the tail rotor off, I noticed that it came off very easily. I put a new one on it and problem solved.
Diagnosis: the tail rotor shaft was spinning inside the rotor. This prevented the tail rotor from turning the correct speed.
Corrective Measures: replace rotor with new one. Avoid hitting the rotor while it is spinning...good luck! :-)
Mar 02, 2009 | Air Hogs Havoc Heli Helicopters
My havoc wont even take off when i push the acceleration it just flops around PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :( thanks
Make sure you are slowly pushing the throttle up. and make sure the blades and rotors are free of any type of debris such as string thread, hair, etc. if it still does not work i would send it back to the company to replace.
Jan 02, 2009 | Air Hogs Havoc Heli Helicopters
Air Hogs Micro Havoc Heli spins wildly
The same thing happened to me. It turned out that some hair and fibers got wrapped around the tail rotor axis. I pulled the tail roter off and cleaned it out. After I put it back together it worked fine. I hope this helps.
Dec 26, 2008 | Air Hogs Toys
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Air Hogs Havoc Heli Helicopters Logo
511 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
