Question about Fedders AEQ07FBG Air Conditioner
Fedders 1965 centroal a/c add freon - Fedders AEQ07FBG Air Conditioner
4 Suggested Answers
  • 21 Answers
SOURCE: how do i add freon to fedders model # A6X05F2B
you dont!!! Only an EPA certified technician can do this. Besides that this is window unit and therefore it is a sealed unit not meant to be recharged. Some newer models allow for this but not this Federers. It probably just needs a good coil cleaning is all, if its losing refrigerant than it has major problems not worth fixing---buy a new one thats more efficient---the energy savings will pay for the unit.
Posted on Jun 17, 2009
FixinFax
  • 3085 Answers
SOURCE: CAN I ADD FREON TO MY FEDDERS AC ? it gets cool
Take the front cover off and make sure the copper bulb is not touching the fins. Bend out a distance of 1/2 inch
Posted on Jun 15, 2010
Testimonial: "this fedders ac heats also , its digital and has no copper bulb, theres a wire with a clip and it snaps on the front cover .?"
  • 1033 Answers
SOURCE: i have a fedders ac
Hello, you can add freon by installing a piercing valve on the low side of the system. Before adding freon I would check and make sure the air filter and both coils are clean. If everything is clean then most likey the unit has a leak and is low on freon.
Posted on May 26, 2011
How do i add freon to my fredders service # a6y12f2a-a
Hello, wimdow air conditioners do not come with service acsess fittings, so you must add a piercing valve to the unit to add refrigerant.
Jul 16, 2012 | Fedders AEQ07FBG Air Conditioner
Add coolant to a fedders a3t12f2al 12000 window ac
You can recharge the compressor with R134a refrigerant gas, but not with coolant. But, the compressor will have to be purged of any existing refrigerant gas, before recharging with new gas.You shouldn't mix old with new, because depending on the age of the unit, it may still have Freon in it. Freon has been banded by the EPAand doesn't mix with the new gas.
Hope this helped answer your question. Thanks for choosing FixYa.
Aug 16, 2011 | Fedders Heating & Cooling
I have a fedders ac unit that does not put out cold air only for a couple of minutes. model # A2Q06F2BG-D can i add freon
May 26, 2011 | Fedders D Chassis AED24E7E Air Conditioner
How ti add freon to an air conditioners
internet heat/cool supply houses sell piericing valves attach to large line called suction line screw the valve in then back off a few turns add freon usually r134a avail. at auto parts stores in 1 pound cans
Aug 21, 2010 | Fedders AEQ07FBG Air Conditioner
Ice on the evaporator
Make sure the coils are not dirty,if they are not dirty,add freon to the system,not much,feel the evaporator,when the evaporator is cool all over,and the condenser is warm all over,there is enough freon,add very little at a time,this system does not hold much freon,if this was helpful,at all,please rate,thank you.
Jul 06, 2010 | Fedders A6Y12F2D Thru-Wall/Window Air...
Fedders air conditioning model a3t12f2ag , my unit runs fine but it will not blow cool air?
you either have internal thermostat problems, selector switch problems or youve got a freon leak. to determine a freon leak is the units coil freezing up or is it dirty check filter first take unit out and to car wash remove housing and give it a bath dont plug it back in until its dry.hope this fix works if not work your switches remember they set in one position most all the time if freon call a tech
Jun 18, 2010 | Fedders A6D24E7D Wall/Window Air...
CAN I ADD FREON TO MY FEDDERS AC ? it gets cool for a few mins then compressor kicks off ! does it sound like low on freon , ?
Jun 15, 2010 | Fedders D Chassis AED24E7E Air Conditioner
How do i add freon to fedders model # A6X05F2B
Jun 15, 2009 | Fedders AEQ07FBG Air Conditioner
Fedders AEQ07FBG Air Conditioner Logo
18 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
