Question about GE Spacemaker JVM1640SJ Microwave Oven
Parts for Model JVM230WLC
This is an older Spacesaver microwave, but it has performed exceptionally well over the last dozen years. I am trying to locate a parts manual so that I can order a new front for the door and control panel. Any help would be appreciated.
Mark
  • GE Master
  • 9,098 Answers
Are you looking to upgrade it cosmetically or does it have a problem?
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
To replace the outer door panel, you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove for disassembly.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Posted on Jan 09, 2009
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1400 Spacesaver is not heating things up AGAIN!
It's what, about 7or 8 years old? I'd buy a new one on sale. Probably not worth messing with just to squeeze out another year or two. You can pull out the Capacitor and take it to any electronics appliance repair place and have it checked for little or nothing, but if it's bad and you order a new one you have no microwave for a while. IF that's the ONLY thing wrong you're back in business.
Mar 30, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Spacesaver XL1400 quit heating last night. everything seems to be wroking except no heat. Is there something I can check for an easy fix or should I just replace the microwave. thanks, dan
This is a fairly common problem. I have a tip at http://www.fixya.com/support/r4223574-microwave_oven_will_not_heat which explains the fix, where to go for parts and how to troubleshoot the unit. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous repair.
Mar 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver XL JVM1341WW002 microwave broken door handle!
Its a free country Bage, but microwave energy is extremely dangerous! Repairs are not feasible unless performed by factory personnel under warrantry, and certified. I suggest you contact the manufacturer about the problem.
Ray
Nov 19, 2008 | GE JVM2050 Microwave Oven
GE Spacesaver over the range microwave oven
GE Microwave ovens, and Microwave Ovens produced by GE but released under different brand names, have had several power problems for the past 20 years. Because it is so easy to sell parts and charge outrageous rates for repair GE never corrected the problems. They just continued it in the next model. They found that you would most likely purchase a new unit rather than paying $75. for a service charge, and $150. for labor plus parts (if out of warranty period).
Most failures were cold solder connections on the power relay board. These would come completely dis-connected after arcing and burning away the solder. Could be 1 month, could be years, but they knew it would happen. This power relay board feeds 120volts to the LV (low voltage) side of the HV (high voltage) Transformer. No High Voltage,,No cook. Everything seems to run normal, but if you listen carefully you will not hear the low tone from the HV Transformer. Over my thirty years in the business I have re-soldered rather than replace so many I couldn't count.
Next to that, a defective Magnetron.
Jan 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Spacesaver micro not heating
Your magnetron, HV diode, Capacitor, or control board maybe bad most of these components run with high voltage and difficult to test without the proper equipment
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver doesn't heat
if you are as lucky as i was...i have a ge spacesaver model jvm130...same problem. first unplug unit and check fuse on the "power control module". if fuse is ok...unscrew the screws holding the "power control module" in place...carefully tilt module and see if a solder joint needs to be re-soldered. my problem was the solder joint under the front plug (5 large wire plug). you may have to unplug the three connectors to the board to get access to bottom. this is the second time i had to re-solder...last one was several years ago though. best of luck tennisrme
Aug 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
125 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
