Question about InFocus ScreenPlay 5700 Multimedia Projector
Screenplay 5700 I have an Infocus Screenplay 5700. After 3-4 years of serivce I recently replaced the bulb, however, I get absolutely no power, after trying to powe back up. hoe can I trouble shoot the problem?
  • tdgoods Jan 05, 2009
    I tired to reseat the bulb however this did not resolve the problem
  • emundo007 Apr 21, 2009
    I have an Infocus Screenplay 5700. After 4 years of service Irecently appear a white parallel vertical lines... sometimes disappears when I press in the outside. how can I trouble shoot the problem?
  • 4,234 Answers
Because these units have dangerous high voltages inside, there are a number of safety interlocks throughout. Take out the lamp and reseat it. Also, make sure that the access door is installed correctly and securely. Both have interlocks that will prevent a poiwer up is not installed correctly.
If this is not the case for you, please update this and we'll look for other causes.
Thanks,
Dan
Posted on Jan 05, 2009
Infocus screenplay 5700 I've had this product for
Hi!
Just had the same problem and I want to sincerely thanks rey francis basa !
I went down and changed C16 as you said. Exactly where you said.
Works perfectly now!
Jan 05, 2013 | Office Equipment & Supplies
Need Manoal
I have the manual with me. If you can give your email address then I'll sent the manual of InFocus ScreenPlay 5700 to that email address. Or you can down load the manual from the following link.
http://www.retrevo.com/support/InFocus-SP5700-Projectors-manual/id/1081ag706/t/2/
OK
Oct 10, 2011 | InFocus ScreenPlay 5700 Multimedia...
Hi, it doesn't power up when I plug it in.
Sounds like the power supply has gone bad. If you interested in getting it repaired you can find me on ebay. Gtitubro is my screenname.
May 22, 2010 | InFocus ScreenPlay 5700 Multimedia...
InFocus ScreenPlay 5700, ceiling mount, installed new 4 - 5 years ago, was working fine, now won't turn on. Gave me a high-speed flicker on the power button, but now nothing, even when plugged into a...
Most probable cause is a faulty power supply. The capacitors inside tend to overheat and burn out. They can be tested with ohmmeter for 25-30 ohms if you can get power supply open. Most people change entire supply. You can test power from supply to main circuit board with a voltmeter.
If you have a fuse, check to see if it is good. It will probably be next to power supply.
Last possible cause could be faulty control board usually due to faulty capacitors or resistors.
Oct 25, 2009 | InFocus ScreenPlay 5700 Multimedia...
I have a screenplay 5700 which stop displaying a picture. I replaced the bulb but the projector keeps starting up and then makes a clicking sound but never displays anything
Does the clicking sound happen right when you plug in the power cable? If yes then you have an issue with the power supply. I repair these power supplies. If your interested you can check out my reviews here, or on Ebay. My ID is gtitubro
Aug 26, 2009 | InFocus Office Equipment & Supplies
Lamp won't stay lit
I've got the same problem, I'm wondering if it has to do with some sort of auto shut off kicking in due to overheating or something, I was gonna try replacing the fan to see if it's something to do with that
Jul 07, 2008 | InFocus ScreenPlay 5700 Multimedia...
InFocus ScreenPlay 5700 Multimedia Projector Logo
289 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
