Question about NEC Electra Elite DTU 16D-2 Corded Phone
Need to change month and year - NEC Electra Elite DTU 16D-2 Corded Phone
    Scholar:
  • 277 Answers
Already answered here:
http://www.fixya.com/support/t14903437-change_time_phone_system
Posted on Nov 07, 2012
How to set the year for armani meccanico watch AR4218?
The Armani site is not very helpful but try this one:-
The year should change when the month hand passes from December to January.
If you pull out the winder (it may need to be screwed out anticlockwise first), you should be able to find a position where the month can be changed. Wind the month hand passed December. If you need to advance it more than one year, then wind it backwards from January to December and then forwards again to January.
Jan 18, 2010 | Giorgio Armani Emporio Armani Sport Ar0532...
Do I need to change brake fluid, clutch fluid and power steering fluid in my 2000 Honda ex 2Dr. coupe? It has 97,000 miles on it.
Unless you have a record of these fluids being changed in the past 18 months you should definitely change them. These fluids will degrade over time and need to be changed at appropriate intervals.
You should also flush the engine radiator and cooling system and replace with new coolant to the manufacturer's specs unless this has been done in the past 18 months.
Also ensure you change the engine oil and filter frequently (certainly more frequently than the manufacturer maximum interval specs which is based on optimum driving conditions which does not reflect reality.)
Frequent fluid changes = cheap preventative maintenance.
Brake fluid - every 2 years minimum
Clutch fluid - every 2 1/2 years minimum
PS fluid - every 3 years
Coolant flush and change - every 2 years
Engine oil - every 3500-4000 miles or 5 months minimum whichever is sooner
Oil filter - every second oil change.
Cheers
Sean
Volunteer contributor.
Dec 10, 2009 | 2000 Honda Civic
How to add current date to folder name- updates automatically
newPath = "C:\Year\" & year(Date)
Call MkDir(newPath)
newPath = "C:\Year\" & year(Date) & "\" & month(Date)
Call MkDir(newPath)
Apr 17, 2017 | Microsoft Visual Basic 6.0 for PC
How frequently should sparkplugs and sparkplug wires be changed?
Every 60,00 miles or 48 month's, which ever comes first.That's what my manual states.
Oct 23, 2009 | 2000 Ford Contour
Can't get the day of the week to go with the month and date
You have to set the calendar for the correct year. To see the year, you have to press the time & month/date buttons altogether. You will see the display change from month/day to year. Use the set+/Set- buttons to change the year to the correct calendar year. This will fix the day to work with the month and date.If you keep having this problem, you will need to change the internal battery. I hope this information help you with your problem.
Apr 08, 2009 | Emerson Smartset Clock Radio
Setting the time..
Normal 0 this is how ive changed the time before, note that you dont see the number you type in.
Press FEATURE **8463 – Display shows PASSWORD:
Then type in 23646 (Note this number will not show on display)
The display will show hours.
Press CHANGE (or NEXT if you do not need to change the hour).
Enter the hour (00 to 23). If number is less than 13, the display shows AM.
Press CHANGE to select PM.
Press NEXT. The display shows minutes.
Press CHANGE (or NEXT if you do not need to change the minutes).
Enter the minutes (00 to 59).
Press NEXT. The display shows year.
Press CHANGE (or NEXT if you do not need to change the year).
Enter the last two digits of current year.
Press NEXT. The display shows month.
Press CHANGE (or NEXT if you do not need to change the month).
Enter the month (01 to 12).
Press NEXT. The display shows day.
Press CHANGE.
Enter the day of the month (10 to 31)
Press RLS (release) to exit.
Oct 27, 2008 | NorStar M7310 Corded Phone
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Oct 03, 2008 | NorStar T7208 Corded Phone
Setting date & time on M7310
Normal 0 TIME CHANGE PROCEDURE: DONE FROM THE MAINPHONE
The display will shoe hours.
Press CHANGE.
let me know how you get on
Sep 15, 2008 | NorStar M7310 Corded Phone
Reset clockdue to power outage.
hi, this worked for me
Press CHANGE.
this has to be done fro the main phone system
hope it helps
Jul 09, 2008 | NorStar M7310 Corded Phone
Changing Time and Date
i had this problem a while ago, you have to set the time from the main phone
Press CHANGE.
Apr 16, 2008 | NorStar M7310 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
11 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
