Question about Canon BJC 2100 InkJet Printer
Pliiz help hello! i have a problem with my printer.It`s filled with ink but when it`s time to print the page that i need i only receive blank pages.what should i do? i`ve already cleaned it..
It sounds like you have flushed your printing heads useing printer maintance, if not I would do so, If this is not the problem try reloading your software for the printer. Good luck. dhu1988
Posted on May 25, 2007
HELP!!! Designjet T610 Prints Blank Pages. When printing multiple pages the printer start to print blank pages after the 1st or 2nd page. What can I do?
Go to Staples in your area or try the staples.com website you might be able to get the same kind of printer or better. the people at Staples are friendly and they will be able to assist you they know a lot about these kind of things such as printers, and computers, and tablets and stuff. See if they can help you better.
Jul 10, 2015 | HP Designjet T610 InkJet Printer
Canon MX300 printer--I replaced the black ink cartridge, reset according to instructions. Printer receives print jobs, but prints blank. Cleaned and deep cleaned heads. Test page prints blank for both...
Try this method to get the ink flowing:
  1. Simply fill a saucer with approx 2mm of just boiled water
  2. Place the print head in the saucer with the head in the water.
  3. Leave the head in the water for approx 2 - 5 Mins
  4. The Heat will assist in dissolving any blockages and help the ink to flow with out using any chemicals.
If it is a compatible cartridge you have used then it is possible to get a failure. Most are re-manufactured and are not 100% Reliable.
Also make sure the contacts on the inside of the printer are clean and all there. sometimes they can be damaged by removing and replacing cartridges. these can be cleaned with alcohol wipes.
I hope this helps Regards GM
Apr 23, 2011 | Canon MX300 Office All-In-One Printer
Hello! I needed to print 6 pages...the first one printed, then the printer started sending out blank pages and lots of them. I had to turn off printer to stop the blank pages from feeding through the...
Hey this might be that the toner is empty, get a shop to either refill it or purchase a new ink tonner for your make as you will take it to them and they can match it up. So you get the correct ink for your printer.
Did it print one and then spend out 5 pages exactly. If this be the case then it confirms that the ink tonner needs to be replaced. You have run out of ink.
Please take the time to rate my expertise.
Thanks
Oct 31, 2010 | Brother HL 2140 Laser Printer
No blank ink being printed or received by fax.
the m/c needs the 5 tank for faxes!Is it a canon cart?The head might be blocked!Go to your printer properties and under maintanace do a deep clean!!Good luck!!
Mar 31, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Printer is hardly used. Has been stored in a dry celler for 3 years. now I want to use it and can command to print pages which it does but prints blank pages. The ink cartridges are surely dried out;...
Had a good read of the manual, which can be found on this site and I think you must fill the cartridges with ink, otherwise you could cause damage to the printer if you continue running it empty. The instructions for filling them manual can be found on my tip on filling PG40, CL41. You should also try standing them first in a saucer of ink cleaning fluid which you get with refill kits. This might clean the nozzles. However I would run the expense of buying new ones first, shop around on the net, they are coming down in price!
Jan 05, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Printed pages are blank ie without text
Please make sure that you have removed and alignhed the printheads.
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Dec 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hello, I have a problem with my mp360 printer. I
Inkjet Printers dry out over time if they sit idol. Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. If the printer has a cleaning option either on the printer itself through the menu system or on the machine through the print driver, you can use that afterwards. Some printers will let you re-run the cleaning utility several times.
Nov 08, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
Canon BJC 80 prints blank pages!!
Power off the printer.
Unplug it, then plug it back in.
Wait until it stops its initialization sequence.
Press and hold the power button.
Allow the printer to beep 7 times, then release the power button.
This will reset the EEProm to factory default, and should clear your problem.
May 26, 2009 | Canon BJC 80 InkJet Printer
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Canon BJC 2100 InkJet Printer Logo
94 people viewed this question
Clive
Clive
old marine
old marine
