Question about Canon ZR200 Mini DV Digital Camcorder
Firewire card How can I tell if I have a firewire card to download videocam tapes to my computer?
  • Canon Master
  • 2,794 Answers
Check in your network connections and look for a 1394 connection. If you have one, you have a firewire port on your computer.
Posted on Jan 05, 2009
Hi im trying to transfer 8mm tapes to my computer?i have down loaded new software but when i hook up computer says it cant locate i,link cable?i have hooked up provided usb cable but it wont reconize it?
This type of camera usually downloads better with a Firewire (Sony call this i.Link) connection. Some mini-DV and D8 cameras only use the USB connection (if they have one) for stills and can ONLY download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The DCR-TRV265E definately has to use Firewire.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select Windows as the operating system, then Digital8 as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
Jan 04, 2011 | Sony Handycam DCR-TRV265E Digital...
I cant transfer my videos from sony handycam dcrhc36 to my computer os window 7 evenafter downloading pmb from sony sitemy computer is not detecting the handycam
You don't say what type of connection you are trying to use. This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software through the Firewire cable. Confusingly, Sony call Firewire "i.Link".
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. If you have a MAC, you may already have a port.
Dec 11, 2010 | Sony Handycam DCR-HC36 Mini DV Digital...
Want to downlaod to computer via usb, but computer doesn't see device
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Nov 11, 2010 | Sony Handycam DCR-TRV27 Mini DV Digital...
Hello. I have a digital video camera Panasonic NV-GS22 and I can't connect it to my PC. My PC recognize only photos, not video. I have some tapes with movies of my family and i can't download them on...
You can download a manual for this camera by enterring the model number in this webpage.
Nov 09, 2010 | Panasonic NV-GS22 Mini DV Digital...
What cable is required to download the recorded video on tape?
To download from the tape (not the memory card) you need a firewire cable, and a computer that has firewire compatibility. Most laptops have this, but desktops may require a firewire card to be installed.
May 05, 2010 | Canon Elura 100 Mini DV Digital Camcorder
Firewire port missing
You can add a PCI Firewire card to your computer if you have an empty slot.
May 22, 2009 | Dell Dimension 3000 PC Desktop
LCD video camera to vcr
Hello!
You need an A/V cable (audio-video).
That is a bundle of three RCA male-male cables and they are marked with yellow (video) white (Left audio) and red (Right audio) for easy identifiying.
Connect either to the front or back of the VCR, make sure you have the right input selected.
If you have your TV on and on the video channel you should see the movie from the camera when playing it.
If you can see it then just record.
To record your VHS tapes to a computer you need either a TV-card or a digital videocam with a firewire connection.
If you have a TV card (affordable nowadays) or video capture card you can connect your old videocam directly to your pc using a S-video cable or the analog A/V cable described above.
Firewire PCI cards that is compatible with any desktop PC are not expensive these days. (if you dont allready have a built-in connection.)
You will also need a "4-6" firewire cable (also called DV-firewire cable)
Connect the old cam to the DV cam using one of the above cables.
Connect the DV cam to the PC using the firewire cable.(You may have to set the DV cam to a "record from external source" -mode)
You will also need software to record the signal to your harddrive, there is a lot of freeware programs you can download on the internet.
If you use windows you can use the "windows movie maker" software.
Good luck.
May 01, 2009 | Panasonic NV-GS15 Mini DV Digital...
Panadonoc pv-gs19 camcorder
The USB port on the camera is to download still pics from the Camera's SD Card to your computer. USB connector is not for video downloading.
For video downloading you have to use FireWire port. Your computer must have a FireWire port too. You will need some sort of video downloading software - like Microsoft's MovieMaker. There are some free software to download videos from mini dv camcorders to computer. It takes 1Hr to download 1Hr tape - you have to play it all to record it all.
3yrs ago when I purchased this cam, I did not have FireWire port in my computer. I searched online a lot and found a way to download video using USB - it was tough, complicated. It was possible, but quality was too bad and too many dropped frames.
If you do not have firewire port, google for FireWire PCI Card, should be <$10. You have to install it inside your PC. Also search for FireWire cable ($10+/-) that will match BOTH camera and PC ports.
Thank you.
Jun 15, 2008 | Panasonic PV-GS19 Mini DV Digital...
Downloading to computer to burn to a dvd
I have a zr300. You need a firewire connection and a firewire cable to download the contents of your minidv tape for burning. You can not do that with a usb cable. USB cable can only download photos and videos from your memory card not from the tape.
Jan 09, 2008 | Canon ZR300 Mini DV Digital Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
105 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
