Question about Acer Extensa 5630-6806 Notebook
My keyboard stopped working and a computer workshop I took my laptop to disconnected it. I had to buy an external keyboard. Can I replace it with a new one or is it a software problem?
  • Acer Master
  • 32,281 Answers
You can install a new laptop keyboard.
Try this WEB site.
Keyboard replacement, LCD screens for mobile phones, Ipods and computer equipment. http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Posted on Nov 08, 2012
SOURCE: replace keyboard for acer 3100
just a note - this site helped a bunch. I was looking up how to remove my keyboard so I can clean it real well (I'm OCD that way). Thanks!
Posted on Feb 12, 2008
hardkiss69
  • 43 Answers
SOURCE: Pioneer DVR-K17RS ATA ACER CODE=39
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 18, 2008
  • 58 Answers
SOURCE: acer aspire 5920 keyboard replacement
http://www.gadgetsmanual.com/aspire-5920-series-users-guide.html THat should be whatcha looking for. Good luck!!
Posted on Jan 11, 2009
SOURCE: replace keyboard on Acer Aspire 5515 laptop
Click this link it is basically the same. Let me know if you find a keyboard:
http://www.powerbrixx.com/reference/acer/3610_keyboard.htm
Posted on Apr 16, 2009
JulesPCaut
  • 702 Answers
Code 39 for cd/dvd drives is a common problem, you need to edit the registry to fix this error. See these instructions on how to fix code 39.
Posted on May 05, 2009
My keyboard wont type
Restore a Laptop Keyboard b> When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
b>
Jan 11, 2013 | Samsung N145 Plus 10.1 inch Netbook -...
Arrow keys stop working on the laptop keyboard
Hook a external keyboard to the computer, if okay! the laptop keyboard will need to be replaced, if no change! try a system restore bringing the computer back in time before this happened.
Mar 25, 2012 | IBM ThinkPad Computers & Internet
My keyboard can' use le++er
Hello Fara,
The keys you are mentioning is not working then they are internally damaged. You have to replace the keyboard with new keyboard. Meanwhile you can use the external usb key board or the onscreen keyboard from the Accessibility option or Ease of access from, the accessories
Dec 19, 2011 | HP Laptop Keyboard for HP Compaq Presario...
Using my computer to access the internet it suddenly stopped typing 'l' and then started typing 'l' without stopping. I have disconnected from the internet and now it will not type 'l' in a word document....
This is going to sound odd, but i you 'slam' the I key down, does it work occasionally? Somtimes this is all it takes.. otherwise you will probably need to have the keyboard cleaned or replaced.. however, in the meantime, you can always connect an external USB keyboard to your laptop and use it instead of the laptop keyboard.
Mar 13, 2011 | Acer Computers & Internet
I wife spilled champagne on my Toshiba Satellite and the keyboard stopped working. Computer still works so I dont see damage to mother board but is there a easy fix or should I just buy replacement...
You can plug in an external keyboard to a usb port and it will work. You can also buy a replacement. Usually they are fairly cheap and easy to swap out. Usually three or four screws from the bottom and a time ribbon underneath the keyboard.
Mar 01, 2011 | Toshiba Satellite M100 Notebook
The keyboard is not working
Connect an external USB keyboard, if there's no problems with it then remove your laptop's keyboard. First: Disconnect the ribbon connection and reconnect again
Second: If that doesn't fix the problem
Third: Buy a replacement
If the external USB Keyboard doesn't work you may have some software issues
Jan 25, 2011 | Toshiba Tecra M2 Notebook
Dell inspiron 1300, g and h keys suddenly stopped
There are some circuits malfunktion in your keyboard.
Try to connect and external keyboard and you will see that the external keyboard works fine.
This way you can continue using your computer,
and continue writing,untill you get a replacement keyboard.
You need to replace the keyboard.
Hope this helped you to continue using your computer.
If you were helped. Please vote!
May 12, 2010 | Dell Inspiron 1300 Notebook
Our HP Pavillion dv8000 just recently started having problem with keyboard. No Virus. Caps Lock light will not go on (frozen) and "s" key does not work. Sometimes the keyboard properly- sometimes it...
Clean the keyboard wiith a compressed air can, if that doesn't do the trick try a usb keyboard, if the external keyboard works well then you need to replace the laptops keyboard.
May 13, 2010 | HP Pavilion dv8000t Notebook
Laptop keyboard not working when LED Power board is connected.
chances are there have been short circuits on the keyboard controller. better bring it to a service center
Jul 07, 2009 | Computers & Internet
Key not working inspiron 6400 laptop
try to reseat the keycap of that coresponding key,the plastic inside might be broken or loose,try ro use external keyboard,if external kbd works,its only the key,entire keyboard should be replaced..just buy the part and you can install the kbd on your own..just go here for instructions in replacing kbd
Oct 09, 2008 | Dell Inspiron 6400 Notebook
Acer Extensa 5630-6806 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
