Question about Refrigerators
My ge gss22ufmd bb side by side freeze de frost heater isn't coming on what is the most likely problem and how can I find out
  • 219 Answers
SOURCE: I have a GE Profile TFG 28PF. 'DE' light flashes,
sounds like a defrost problem replace heater t stat and main board in back
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: Freezer works fridge does not on a GE GSS22QGMC BB
you need to take freezer evaperator cover off , then turn it to defrost and test the supply voltage across the defrost element. if no volts then test the round disk looking thing with 2 wirers comming out of it . with the supply power removed from the power point, the coil frozen up , disconnect these wirers and use a continuity checker such as a multy meter on diode check or buzzer mode, you should have a closed circuit through the defrost termination thermostat (round disk with 2 wirers) , it is in series with the defrost element thus cutting the power to the element if the coil temp gets too high and terminates the element , the timer will time out after it's time duration is reached. A good way to test the motor in the timer is to put a texta mark on the dial of the timer and check it in 1/2 hr, to see if it has moved.AFTER YOU HAVE PUT THE ELECTRICAL CONNECTIONS BACK AFTER TESTING THE TERMINATIN THERMOSTAT AND MADE IT SAFE, YOU WOULD PLUG IT BACK IN.
The defrost timer needs to be connected to power of the fridge to opperate.
regards
****. let me know your progress pls.
Posted on Mar 31, 2009
Sea Breeze
  • 4655 Answers
SOURCE: ge gss22ufmd cc not staying cold in fridge or freezing in freezer
Your refrigerator has a control board located on the back. If you can unplug refrigerator and remove the board so you can examine both sides. We need to look for burn marks on the board. That circuit board controls all functions on your refrigerator. If you want we can get this fixed from here, Let me know, Thanks, Sea Breeze
Posted on Apr 20, 2009
  • 35 Answers
SOURCE: GE GSS25kgmc side by side refridgerator side is
BAD MOTHER BOARD OR HEATERS
Posted on Jun 18, 2009
Sea Breeze
  • 4655 Answers
SOURCE: my GE modle ess25xgmc bb is frosting up i changed
OK, This does not happen much on that model. This time I want you to work with me on the solution and test a couple test points on the motherboard. If you are comfortable with this let me know. It will require a voltage meter and an OHM meter. Let me know, Sea Breeze
Posted on Feb 16, 2010
Hi I have a GE model# DSS25KGRE BB fridge. The fridge runs constantly, meaning it cools until the coils get all frosted up. then the defrost heater kicks on and 'thaws' the coils. I have tried
OK, first check the condenser coils and fan to be sure they are free of lint and dirt buildup. Dirty coils will keep the unit from cooling correctly and the unit will run endlessly. Post back the results to me and we will take it from there.
Regards,
Richard Roth
http://appliancecafe.com
Nov 30, 2012 | Refrigerators
GE refrigerator isn't cold at all
you need to have the frig defrost the passage is in the back going from the frig to the freezer so if it is frosted in the back than the air is not moving correctly
Sep 18, 2012 | GE Refrigerators
I have a GE Profile counter depth French door refrigerator bottom freezer and I keep getting frost in the freezer. The seal on the door isn't as tight as the seal on the refrigerator but no cold air...
Where are you getting frost at? Is it on the back wall in the freezer? if so - your problem may be a defrost issue and in that case you would need to hire a professional appliance repair technician to service your refrigerator.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - We repair refrigerators and all other appliances in the Houston, Katy, Spring and Woodlands, TX areas!
Aug 29, 2011 | GE Profile PDS20SFSR Bottom Freezer...
My GE modle ess25xgmc bb is frosting up i changed
Feb 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge gss22ufmd cc not staying cold in fridge or freezing in freezer
Apr 20, 2009 | GE Refrigerators
I have an older side by side ge fridge with the panel display that shows pf - power failure de - cc etc well the de light has come on and I don't know what it means - I do not have the manual and I'm not...
The DE error comes up when the refrigerator has not detected adefrostcurrent within a certain amount of time. This is most often theresultof a burnt out defrost heater. The refrigeratorwill likelykeep working for a week or so until the frost builds up andblocks theair flow over the evaporator (the cooling coils behind theback wall ofthe freezer). The defrost heater is located at the bottomof saidevaporator.
You can try your zip code in http://www.geappliances.com/buy/ and look for a servicing dealer.
Good luck.Please rate my answer if accepted.Thank you.
Jan 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost on back wall of freezer, side by side, wont freeze
It's most likely a defrost issue. One or more of your defrost components have failed. Defrost components are defrost thermostat, defrost heater, and defrost timer or board depending on model
Nov 21, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side refer, no model number available at this time
a flashing DE usually indicates a defrost problem on any unit, they don't flash indicating they are in defrost, soner or latter the problem will show. You could have an intermittant bi-metal or most likely it being a ge - a bad defrost heater. and there is always the possibility that it could be the board. It would have to be trouble shot properly
Aug 04, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
