Question about M-Audio MXL 990/991 Recording Mic Duo and Audio Buddy Package Microphone
I have a m-audio buddy using a mlx 990. I have this hooked to 200 ohm peavy amp. The problem is I can barely touch the gain on the pre-amp or the amp without getting extreme feedback.
It appears that the condenser microphones that are omni directional are too sensitive to process thru an amplifier. I used an mlx 991 directional condenser microphone and though still very sensitive, I was able to avoid the feedback. According to the company condenser microphones are used more for recording and not so much for live stage.
Posted on Jan 06, 2009
Would you please help me? My MXL 990 doesn't work when i plug it in the M-audio USB interface. The led doesn't light. I use XLR cable. Please help. Thanks a lot!
Make sure the Phantom Power on the Audio buddy is on. If that fails, get in touch with MXL and they will troubleshoot it with you.
Oct 30, 2010 | M-Audio MXL 990/991 Recording Mic Duo and...
The diagnostic LED indicator comes on and i dont know why
first check the ground as it is the most important par to the wiring and operation of an amp. itshould be t the frame of the careand touching clean bare metal no paint! if that doesnt work it may be going into termal protection meaning ts getting too hot. you should always be able to continously keep yourhand on the amp, if its too hot try backing the gains down a little. next make sure the spakers are ired to a safe impedance for the amp. if its wired too low it might could put the amp into protect mode or blow it! most amps are only 2 ohm stable nd 4 ohm stable when you bridge them...hope this helps!
Sep 15, 2010 | Performance Teknique ICBM-775 Car Audio...
Have 600w amp 2 10's and they aint even bumpin, DO I NEED TO BRIDGE IT
No, that'll use two channels to power one sub. First, is the gain turned up? There's a knob on the amp to turn it up. If the gain is already up, and if the amp is two-ohm stable, then wire the subs in parallel. I'm assuming the subs are each hooked up to their own individual channel. Swap the two negative wires at the amp, so sub 1 is hooked up to channel 1 positive and channel 2 negative, and vice versa for the other sub. That'll dramatically increase the output. Again, make sure the amp documentation says it is 2-ohm stable, or you'll damage your system.
Dec 24, 2009 | Kenwood KAC-729S Car Audio Amplifier
Amp burning speakers.
one of the channels your using may be burned out or there is sum wire touching inside the amp so take the cover off and make sure nuthn is touching and see if sumthn is burnt and also try using a different channel on the sub
Feb 26, 2009 | Sony XM-2165GTX Car Audio Amplifier
Low ohms light flashes and bass distorts at high volume
Sounds like you need to invest in a capacitor. Those are used when subs receive a bass spike. You just a need a 1 Farat Capacitor (1,000 watts) ran between the head unit and the amplfiier to fix your issue. Also, try reducing the volume gain to half gain and low pass frequency to half gain; this will increase your clarity and make your amp less hot. This may fix it without a capacitor. Also find out what amprage your alternator is. Your alternator may not be designed to run the amplifier. Most alternators are 200 amps now if they are gold plated.
Hope this helps
Feb 10, 2009 | Jl Audio 500/1 Car Audio Amplifier
Your other preamp does not have phantom power to supply power to the microphone. All condensor mics like this need phantom power. The Audio Buddy provides phantom power, which is why it was shipped with those condensor mics
Jan 16, 2009 | M-Audio MXL 990/991 Recording Mic Duo and...
M-audio buddy feedback from mlx 990 condenser mike
Hey I Have These Mics They Work Awesome. But Yes Feedback Is A Problem You Need To Move Away From The Speakers Way Away. Try Lowering Your Highs Or Invest In A Feedback Eliminator They Are Like 89 Bucks But Obviously That Would Almost Cost As Much As The Mic Set. Anyways Feedback Is Made When A Microphone Can Hear Itself Maybe Try Headphone?
Jan 05, 2009 | M-Audio MXL 990/991 Recording Mic Duo and...
JL audio 500/1 produces barely any sound
have you checked the input sensor on the amp?
Oct 28, 2008 | Jl Audio 500/1 Car Audio Amplifier
M-Audio MXL 990/991 Recording Mic Duo and Audio Buddy Package Microphone Logo
188 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
