Question about Dishwashers
My dishwasher not spraying water
My dishwasher is not dispensing water when i turn it on.
    Scholar:
  • 50 Answers
Answer kind of depends on whether tub fills or not. If tub is filling and the arms just aren't spraying water, that would suggest a problem with the pump or motor. If the tub is not even filling at all, then it may be a problem with the intake strainer, solenoid or valve. If you give mfg/model and more specific info I will try to help... Tripp
Posted on Jan 05, 2009
Buffalo12980
  • 625 Answers
SOURCE: re: Maytag dishwasher
does the timer advance the control knob? check to see that nothing is in the way of the center spray tower. does it sound like any water is spraying around inside?
Posted on Sep 01, 2007
SOURCE: Dishwasher
I have a kenmore dishwasher (about 10 year old) it won't turn on. It just buzzed when set to wash. What can I do?
Posted on May 16, 2008
SOURCE: Kenmore 665.1736 fills with water but does not spray
Take thre drain hose off from disposal. Pour hot water down the hose until full. Cover end with hand. Press cancel/drain while holding hand over hose - over bucket. That may unstick checkvalve balls and or fix air lock. I have to do that every 6 months or so. Started happening 1 month out of warranty. Go figure. Not a fix - just a work-around...
Posted on Jan 17, 2009
  • 2187 Answers
SOURCE: water jet arm does not work
In most units, the movement of the arm is powered by the water. If the water does not come out of the arms, check the filter for debris or the arm itself. This could also be caused by mechanical issues. You may want to inspect the arms itself for loose connections or worn out parts.
Posted on Oct 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: it doesn't start and clean light flashes
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 07, 2010
Testimonial: "You solved the problem quickly and easily. Thank you for the great assistance!"
The rinse aid dispenser is not adding any rinse aid. how do I unclog it so my drinking glasses don't come out feeling like they have sand all over them.
Good Morning friend, thank you for your post!
I see that you are having an issue with your rinse aid dispenser not adding rinse aid into your Frigidaire dishwasher. You may need to run hot water into your dispenser to help clear out any dirt or clogs within your dispenser. If that does not help I would recommend making sure the water temperature inside your dishwasher is at 120 degrees. If the water is not at the correct temperature it will not allow proper dispensing of the rinse aid. You may also want to check the filter at the bottom of your dishwasher to assure that it has been cleaned out and is not distributing dirt or debris inside of your dishwasher. I would also recommend checking the spray arms to make sure they are not dirty and spray water evenly. You can clean them out using a pipe cleaner. I hope this information is helpful to you. -Matt
Aug 09, 2015 | Frigidaire Dishwashers
Dishwasher not cleaning dishes
DISHWASHER NOT CLEANING WELL??
Here are 5 common reasons why not.
Here are Improper Water Temperature
I can tell you from personal experience that water temperature has a direct impact on how well your family's dishwasher operates. If the water entering your dishwasher is not hot enough, your dishes are likely to come out coated with grease and dish detergent residue. As such, you will want to make sure that the temperature of the water inside your dishwasher is somewhere between the range of 120 degrees Fahrenheit and 140 degrees Fahrenheit. If it's not it could be a faulty heating element.
Dirty Pump
Based on my experience, a dirty dishwasher pump will also cause your dishwasher to produce less than stellar results. Therefore, you may want to consider cleaning your dishwasher's pump every six months. In many instances, it is an easy task to complete. In order to clean your dishwasher's pump, you'll most likely have to remove the dishwasher's spray arms. Once the spray arms are removed, you'll want to clean and inspect the pump's impellers, blades and pump guard. I should also mention that there are appliance companies that sell dishwasher pump repair kits should you notice that a part needs to be replaced. A basic dishwasher pump repair kit will tend to cost you $20 to $60 depending on your dishwasher's unique needs.
Dirty Spray Arm
Dirty spray arms may also be to blame. After all, if the spray arms' holes are clogged, the hot water won't be able to reach the dishes properly. A dishwasher's spray arms are very simple to clean. In order to clean them, you will need an old toothbrush and a bread twist tie that has been stripped of its paper. Use the toothbrush's bristles and the wire from the bread twist tie to unclog all the holes.
Broken Dish Detergent Dispenser
A broken dish detergent dispenser is another likely culprit when it comes to dish cleanliness problems. Sometimes the dish detergent dispenser's door will not open or shut properly, which prevents the dishes from getting nice and soapy. The good news is that most dish detergent dispenser problems may be solved relatively inexpensively. The cost of a replacement dish detergent dispenser will vary based on the make and model of your dishwasher. There are also instructional videos online that will help you with the installation of your dishwasher's new detergent dispenser.
Dirty Filter
A filter has an impact on a dishwasher's effectiveness as well. Hence, you will want to inspect your dishwasher's filter for obstructions. The location and type of filter will vary based on your dishwasher's make and model. I would recommend that you check out your dishwasher's operator's manual. It should contain instructions on how to clean your particular unit's filter as well as where you can order a replacement part if need be.
Dec 16, 2013 | Dishwashers
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 | Dishwashers
    Rinse aid does not dispense
    Normally 2 things operate the dispenser. 1) is by means of an electrical solonoid which activates automatically. 2) when your rotors rotate, they spray hot water onto the dishes and your soap dispenser. The heat activates it then. possibly the rotors are blocked not allowing the rotators to turn resulting in no hot water getting to the dispenser. Clean the rotors
    May 17, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
    Kenmore dishwasher we use new finish detergent and the little soap pouches do not dissolve.
    DOES THE SOAP DISPENSER DOOR OPEN, IF SO THEN EITHER THE WATER FROM SPRAY ARMS NOT REACHING THE DISPENSER, POUCHES IMPERVIOUS TO WATER OR REQUIRE HOT WATER AND WATER IS NOT HOT ENOUGH. CHECK THAT THE SPRAY ARMS ARE NOT CLOGGED WITH DEBRIS. ALSO COULD BE SOME UTENSIL KEEPING THE SPRAY ARMS FROM ROTATING.
    Mar 09, 2010 | Kenmore Dishwashers
    Detergent tablet not dissolving.
    sometimes the dispenser doors are not designed for tablets, and they don't let enough water in to dissolve them....next time you wash; put the tablet in one of the silverware compartments....should do the trick. and leave the dispenser door for liquid detergents only.
    if this is helpful please click the correct button. thanks
    Jan 22, 2010 | Zanussi Dishwashers
    GE profile PDW7880J Soap left on dishes and soap left in dispenser
    Dishwasher - Soap Stuck in Cup If you have dishwasher detergent stuck in the soap cup after a full cycle, please check for the following conditions:
    • The water temperature should be at 120 degrees (140 degrees if your dishwasher has water heating capability). Check your water temperature Check your water temperature.
    • Make sure the soap cup is not blocked by anything.
    • Allow the dishwasher to fill and make sure it is getting a proper amount of water. The dishwasher should fill for about 90 seconds. On permatuf models, the water should measure 3/8" above the island near the center of the tub. On all other models, the water should measure about 1/2" below the heating element.
    • Check the lower spray arm for any blockage in spray holes or items that would restrict its turning.
    • Make sure the soap cup has opened at the end of the cycle.
    • Check the sump area inside the dishwasher for any restrictions.
    Apr 09, 2009 | Maytag 24 in. MDBH950AWS Built-in...
    Detergent stays in the dispenser
    Clean and dry your dispenser prior to filling with detergent.
    Use only fresh detergent.
    Do not place anything ie. cookie sheets, cutting boards in the path of the water obstructing the dispenser.
    Do not allow anything to fall between the racks and stop the spray arms from turning.
    Always turn the hot water on at the sink prior to starting you dishwasher they use less than 2 gallonsof water in the initial cycle and they require 120 deg f water. Unless you have hot water recirculation in your home.
    If you have low water volume or low water pressure due to bad impellor or windings in circulation pump. The water volume or pressure will be insuficient to reach the dispenser.
    Mar 31, 2009 | Kenmore 24 in. 16492 / 16494 / 16499...
    Automatic detergent dispenser does not
    Make sure all the spray bars are rotating good, that there is no trash in the spray bars or plugged nozzles, and that the pump inlet screen at the bottom of the dishwasher is not plugged up.
    The dispenser works on water spraying on the cover.
    If all the above doesn't fix it, then replace the dispenser.
    Reply what you find and I'll help further.
    Feb 02, 2009 | Asko 1595 Dishwasher
    Dishwasher
    May 15, 2008 | Dishwashers
    Dishwashers Logo
    2,545 people viewed this question
    Top Dishwashers Experts
    Mike Cairns
    Mike Cairns
