Question about Dyson DC14 FS Telescope Complete Lifetime HEPA Upright Vacuum Cleaner DC-14 No Suction Loss, Factory Serviced Refurbished, 6Mo Wnty, Op.3-5Yr Ext Wnty
A crack in the dyson collection canister
What can we use to repair a crack in the bottom of the collection canister? Wondering if epoxy would work... don't want to spend 70 dollars to replace it if we can avoid it. Thank you!
5 Suggested Answers
SOURCE: Dyson collecting debris/hair, ect on top of hepa filter?
Called Dyson today about the cyclone canister clogging in my DC17 Animal. Turns out it's a problem with the black rubber gasket in the bottom of the canister. This also causes the HEPA filter to get lots of dirt and debris on top of it. They are sending me a new Cyclone canister with the corrected gasket. This will prevent anything but small particles of dust from entering the top of the cyclone and the HEPA filter should no longer collect all that stuff. Hope so!
Posted on Oct 29, 2009
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: I have a yellow all
    Sorry to hear you're having difficulties with your DC07 bin. If the bin appears to be jammed shut, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Online Customer Support
    Posted on Aug 19, 2011
    madmike962
    • 7 Answers
    SOURCE: can you wash canister and vortex assembly in Dyson DC17
    you need a Hyla they use water as a filter and the smell goes down the drain
    Posted on Jan 22, 2012
    askdyson
    • 2572 Answers
      Verified Fixya Pro
      SOURCE: dyson canister won't fit snugly
      I am sorry to hear your canister is not fitting properly. You may want to separate your cyclone assembly (the top purple portion of your canister) from the clear bin and reattach the components to ensure they are fitted together properly.
      To do this, open the bottom of the clear bin, as if you were emptying it. Please be sure the bin is positioned over a trash receptacle in the event there is debris in the bin. Once the bottom of the bin is open please look at the back of your canister. Below the purple top of the canister and to the left of the debris inlet is a clear plastic loop that you can slip your index finger through. Just above this loop is a gray release catch . Using your thumb, press down on the gray release mechanism. At this point you should be able to gently pull the clear bin away from the cyclone assembly. After separating the pieces, briefly inspect them to confirm they are not damaged. If there is no obvious damage, close the base of the clear bin and place the bin on a hard flat surface. Next, carefully lower the cyclone assembly onto the clear bin. It may be helpful to use the red plastic piece on the back of your cyclone assembly and clear bin to line the pieces up correctly. You will hear a slight click once the pieces have been successfully reattached.
      Please attempt to return the canister to the machine. If you are still not able to attach the canister successfully, please call us so we can provide further assistance. We can be reached at 1-866-693-9766 (US), 0800 298 0298 (UK), and 01-475-7109 (IE).
      Best wishes,
      Jessica
      Posted on Jun 22, 2012
      My Dyson DC25 suddenly had a small blue spark near the bristle section and now the bristles won't work. Hoover works but bristles won't turn. Any suggestions how I can fix it? Thanks
      Hi Michelle,
      I would suggest contacting Dyson right away and see if they will cover it under their warranty.
      Also, I found their support site helpful as well. You will need the first 3-digits of your serial number (usually found behind the removable canister).
      http://www.dyson.com/support.aspx
      I hope that helps!
      Denver Epoxy Garage Floors
      Oct 12, 2013 | Vacuums
      I Have the Dyson dc23 animal stowaway canister motorhead. i want to clean the upper orange section as it is starting to hold the smell of dogs and dust but i can only seem to find videos on the upright...
      Hi Ashley,
      I have the DC17 Animal and my assumption would be that you could clean your canister the same way as you could clean an upright.
      I've found Dyson's site pretty useful (for this specific question it may be outside their scope but maybe worth a try) http://www.dyson.com/support.aspx
      I hope that's at least somewhat helpful.
      Boulder Epoxy Garage Floors
      Oct 08, 2013 | Dyson Stowaway DC23 Bagless Canister...
      I am having trouble getting my dyson dc 23 turbinehead vaccuum to power up again after unclogging the brush rollers and emptying the canister. Everything seems to be in correct order and locked down as far...
      I'm no electrician but sounds like an electrical issue. I'd maybe recommend visiting Dyson's site directly: dyson.com/support.aspx
      I hope that helps. You may also consider contacting their warranty department.
      Denver Basement Epoxy Experts
      Sep 07, 2013 | Dyson DC23 Turbine Head
      How is the dirt canister removed from the Dyson DC39 vacuum please?
      I'm sure you've figured it out by now but there is a button located next to the handle of the canister and you simply click there to release it.
      Hopefully that helped!
      Longmont Epoxy Garage Floors
      Aug 05, 2013 | Dyson DC39 Multi floor canister vacuum...
      I have a dyson dc14 that is not working. It has
      Hi its Darran at Dyson.
      First of all you need to ensure that the brush control dial on the cleaner head is in the correct position. With the machine stood upright, this dial should be in the centre position (you should be ablwe to move it backwards to the off position). If it is, you then need to release the head into the vacuuming position at which point the dial should move forwards to the on position, lie the machine on its side and switch it on. The brush bar should then start to move. If not, its possible that the cluth may have a fault and you may need a repair or replacement clutch assembly.
      If the brush bar starts turning, try the machine and if the suction is still poor, you will need to follow the blockage procedure. This can be found in the user guide, however as you no longer have a copy, you can download one for free via our website at www.dyson.com. Just visit our support section and you will find a complete self help guide and contact information for Dyson direct if you feel you need it.
      I hope that this information is useful to you.
      Kind regards
      Darran
      Dyson Customer Service
      www.dyson.com
      Apr 26, 2010 | Dyson DC14 Full Gear Bagless Upright...
      The vac. works when I use the hose but to vac floor it does a poor job
      I just read some of the solutions and think I should check the hose at the bottom for cracks.
      Nov 16, 2009 | Dyson DC08 Cylinder Bagless Canister...
      Round filter keeps clogging and nothing gets thru to the canister
      I was having this same problem with my Dyson, and then I realized that mine was caused by the rubber gasket inside the canister being too high. It somehow was pushed up allowing everything to go up into the “cyclones” and then on through to the filter. This probably happened when I separated the clear part of the canister and balanced the inside part on the floor. To solve this pull the rubber gasket down as far as it will go, on mine the grey plastic dips in about 1/8th of an inch above where this gasket should be located, and there should be no gap between the bottom of this gasket and the bottom of the canister. Also I used my old vacuum to clean out the inside of the cyclone as this was full of pet hair. The filter continued to catch the remaining pet hair that was inside the cyclone that my old vacuum could get to. This took about two or three “vacuum session” before it all cleared through and no more hair was collecting on the filter. I now always make sure that the gasket is all the way down as this same situation can also lead the cyclones becoming completely clogged, and destroying the vacuum. Hope this helps!
      Sep 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
      Feb 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
      Dyson DC17 Animal
      I have the same problem with my Dyson dc17...there is dog x2 hair collecting in the 'cylinders' just underneath the purple cap on top of the cyclone/canister. And i can see twisted 'braids' of hair coming out of each pea-size hole. I called Dyson's Support number and after they asked a few questions about the round filter (tell them you clean it every month or so), the representative told me that you should not see anything collecting on top of your filter located at the base of the canister (mine was covered with dog hair, etc.). They told me that nothing larger than minute dust particles should be there...which eventually travel into the purple cap. They said the cyclone canister has since been redesigned to correct the faulty rubber seals, etc., and they are going to send me a whole new cyclone/canister within a week or so. so call Dyson directly before you try to get inside "the purple chamber"...I know I could not figure it out!
      Oct 02, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
      Dyson DC14 FS Telescope Complete Lifetime HEPA Upright Vacuum Cleaner DC-14 No Suction Loss, Factory Serviced Refurbished, 6Mo Wnty, Op.3-5Yr Ext Wnty Logo
      279 people viewed this question
      Top Dyson Vacuums Experts
      AskDyson
      AskDyson
      Samyfam
      Samyfam
      Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
