Question about Philips 3000 series DVD player DVP3886X
Hi, Iam using a DVP3886/94 model Philips DVD Player, of late the digital display is jumbling and the remote control is not working. The DVD player gets hanged when a Hard Disk is used on a USB drive. Please advise
5 Suggested Answers
ANDREIONELUV
  • 29 Answers
SOURCE: philips dvp 5992 Disk drive wont open
HELLO MY NAME IS ANDREI
I THINK YOU MIGHT OF LOCK THE DISC. BY DOING THIS YOU BLOCK THE PLAYBACK OF THE CURRENT DISC. SUBSEQUENT ACESS TO A LOCKED DISC REQUIRES A SIX DIGIT PASSWORD THE DEFAULT PASSWORD IS 136900. THIS WILL UNLOCK THE DISC LOCK FEATURE. MAKE SURE YOU GO YO SETUP AND CHOOSE UNLOCK DISC LOCK PERMANENTLY OR IT WILL KEEP DOING IT EVERYTIME YOU PLAY THE SAME DISC. HOPE THIS MIGHT OF SOLVED YOUR PROBLEM.
Posted on Jan 15, 2009
SOURCE: My dvd model is philips dvp 3005 and it is in standby mode
my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Posted on Feb 18, 2009
  • 4 Answers
SOURCE: Hi, my Philips DVDR3455H/75 DVD/Hard disk doesnt
THE DVDR3455H HAS A COMMON PROBLEM AFTER A FEW YEARS THE HARD DRIVE GO BAD, IT WONT BOOT UP
99% OF THE PROBLEM WITH THE PHILIPS DVDR3455 IS THE HARD DRIVE.
IT WILL KEEPING REEBOOT OR IT WILL HANG ON THE PHILIPS LOGO.
IT IS NOT A FIRMWARE PROBLEM IT AHARD DRIVE PROBLEM.
ONE THING YOU SHOULD KNOW, IF THE HARD DRIVE IS BAD YOU WILL NOT BE ABLE TO UPGRADE THE FIRMWARE IT WILL NOT READ THE CD OR DVD DISK.
AT THIS POINT IT NOT LOOKING FOR A FIRMWARW DISK BUT IT LOOKING FOR THE BOOT UP SOFTWARE.
OR THE LOAD CD WHAT PHILIPS CALL IT.
SOLUTION REPLACE THE HARD DRIVE WITH THE LOAD SOFTWARE INSTALL ON IT.
THE HARD DRIVE IS SOLD ON EBAY JUST LOOK FOR DVDR3455H YOU WILL FIN NEW DRIVE READY TO INSTALL THAT WILL FIX YOUR PROBLEM.
Posted on Dec 11, 2009
BElectric
  • 1140 Answers
SOURCE: I have a Philips TV and I believe I must have sat
Hi There,
I really need to know the model number for the TV to give the correct answer, but on most Philips TVs, the INFO button (on the Philips remote supplied with the TV) will switch this feature on and off.
If you don't have an INFO button or you still can't remove the channel/input information, please reply to me with the model number of your TV.
Hope this helps.
Regards,
BElectric
Posted on Mar 05, 2011
How To set a Philips DVD player dvp5996k to "multi Region" ?
There's a lot of useful information on the videohelp.com website.
Philips DVP5996K region code
posted by satish_z2002.
  • Please turn off all power using remote
  • Turn On Power
  • Eject Tray - Player will display NO DISC
  • Enter Setup and navigate to preferences page
  • Type 138931 on your remote
  • Player will display Default Region Code
  • Use up down arrow keys and select 0(Zero) for All Regions
  • Hit Enter
It's now region free.
DVD Player and Blu ray Player region codes
Jan 19, 2014 | Philips GOGEAR Audio Players & Recorders
Hi, bought dvd ntsc format from US but can't play at our player. Are you able to assist ? Player type - Philips HTS3011/98
your dvd has regional code..only play dvd from where your purchase it.
you can do some hack.
try this
To convert this player for multi-region playback
This hack should work on all Philips DVD players with any firmware version, and other similar models by manufacturers such as Grundig, Marantz and Yamaha
Please note that if you experience problems with this hack you can obtain firmware version 7.03 and later by visiting the PhilipsSyndicate to obtain files that you can burn to a CD-R and flash your unit to the new version.
1a.
The following uses the machines own remote control:
We have heard reports that hacking some players using the units own remote control incurs a 25 change limit after which it will lock the machine in the last set region
We have heard other reports that hacking some players such as the DVDR-880 using the units own remote control can result in an inoperable unit, we recommend you use the OneForAll remote only and consult our Region Hacks forum for more information
  • Press the Play button on the player
    NB: You may need to press this button on the remote control instead
  • Press the 1 button on the remote control
  • Press the 5 button on the remote control
  • Press the 9 button on the remote control
Although the above may appear to work on many units, showing the correct display as indicated in Step 2, the hack may still not work. In which case you WILL need to use Step 1b instead! 1b.
If the above does not work, you will have to send the infra-red code RC6 (aka Codeset 4, Key 235 in nerd-speak) to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital with the following instructions:
  • Configure your remote using the setup code 0 5 3 9
  • Press the Magic button
  • Enter the code 0 8 5, or if your unit requires a five digit code, enter 0 0 0 8 5
If you own a Palm Pilot, you may also use Pacific Neo-Tek's OmniRemote software to generate the RC6 code using a downloadable .pdb file.
  • Download the .pdb file into your Palm Pilot
  • Press the OmniRemote key marked as 955 Multizone
If you do not own either of the above units, it is possible to construct a cheap DIY solution by following instructions at the following website.
NB: Sending these codes to some players, such as the Philips DVDR-980, requires you to select a DVD player remote on the unit as the default IR device, as opposed to the DVD recorder remote it is factory set to. Please consult your player documentation to find out how to do this.
2. The onscreen display should show 11 spaces like this: '-----------'
NB: The actual display may differ slightly depending on the model of your player, may be shown on the unit itself, or may even not be visible on some models at all.
3. Using the number keys on your DVD player's remote control, enter the code 222 222 005 255. Note that this is 12 digits and the last digit will not show on the on-screen display.
NB: For players such as the Philips DVDR-980, DVDR-985 and DVDR-1000 units, you may need to use the code 121 212 005 255 instead. For players such as the Philips DVDR-880 you may need to use the code 121 212 005 00x instead, where x is the desired region, however this also works on other units including the DVDR-985 for setting a specific region. 4. Press the Play button on your DVD player's remote control 5. The onscreen display should now show the words No Disc 6. Power off your DVD player, wait 10 seconds and then power back on
Aug 24, 2011 | Televison & Video
Phillips Portable DVD Player DCP750/37 says "Wrong Region"
To change the region on the Philips dcp750
1. Press the Open button on your remote control to open the drive tray
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
Mar 13, 2010 | Philips Televison & Video
Philips universale remote CL034 codes for magnavox dvd player
Here are some codes I found
0441
0442
0599
0799
0699
0247
0193
0093
0598
Nov 30, 2009 | Philips Televison & Video
Need remote code for DVD model ZV420MW8
try to transfer codes using the ir senser.
neo
Mar 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Need code to program ge remote control and dvd player
Go to the following page to get information on how to program your GE remote:
http://www.jascoproducts.com/support/download-files/GE-Universal-Remotes-Instructions.pdf
Codes for 4 digit remotes:
PHILIPS ............. [0371] [0344] [0345]
Codes for 3 digit remotes:
PHILIPS ............. [734] [743] [744] [745] [755] [814] [823] [824] [825]
Thank you for using Fix Ya!
Good Luck!
If you have any other questions, just let me know!
Don't forget to rate the overall satisfaction of this solution.
Feb 02, 2009 | Philips Magnavox Learning Universal Remote
Unlock my dvd player
try this
Power Up the unit with NO Disc in the tray.
Open the tray
Press the SETUP Button on the remote control
Navigate to the PREFERENCES page using the Right Arrow Key
Press the DOWN ARROW one time to select
Press the 1 button on your remote control
Press the 8 button on your remote control
The current Region Code Setting will display
Use the UP/DOWN Arrow Keys to select the region required or '0' for All Regions
Press the PLAY Button on the remote control
I bought mine tonight. The above procedure works perfectly. It is now set to 0, and I confirmed via firmware version page.
Cheers!
Sep 06, 2008 | Philips Magnavox DVD/VCR Dual Player
DvD Player
My remote cannot function with the recorder. Battery is OK
Their is a number 2 digit on the display.
Assistant please
Mar 06, 2008 | Philips DVDR 3355 DVD Recorder
Philips 3000 series DVD player DVP3886X Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
