I have a JVC LT 32 EX 18 TV. When connecting my laptop over HDMI, playing on a playstation or WII the sound and picture work perfectly. When I want to watch normal TV over cable though the problems start arising. First, I am able to watch TV, I receive all the right programs but the picture is black and white, sometimes very fuzzy and instead of sound all I receive is a constant buzzing sound. Is there anything I can do so I can finally start watching TV?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If the rear inputs work consider connection for the channels with a box using one of the rear inputs--sounds like a tuner related issue and going to the rear inputs bypasses that.
Posted on Nov 08, 2012
SOURCE: No surround sound when watching TV
hdmi can only pass pcm 2.0 digital for the separate cables you may try to switch them to another output from the monitor to the receiver or if you can get your hands on a spd-if cable (one single fiberoptic cable that will go as high as 5.1 dolby surround)
Posted on Feb 01, 2008
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
  • 105 Answers
SOURCE: No Picture
I am deeply sorry but you will need to replace the backlight bulbs. These are not available.
Look on Ebay for a 32" JVC with a broken LCD Screen. Buy it and use these bulbs to fix your TV. I am sure there will be a few good ones in the broken TV. It's that or list it on Ebay for $50 and expect to get about 200-300.
LCD Panel repair for this problem is $500 for parts so you are stick with repair yourself or sell.
Posted on May 27, 2009
  • 105 Answers
SOURCE: No Picture
Backlight Bulb is out.
You cannot purchase these as a spare part, you must purchase the complete backlight.
Backlight cost is more than or equal to a new TV
You may sell this TV on Ebay (list your exact symptom). Start at 100 you will get about 250. Take this money and buy a new TV.
LCD backlights don't fail often but when they do there are no part available to repair them so you get stuck buying the complete assembly part. This is more expensive than a new TV since LCD prices have dropped so much in recent years.
Posted on Jun 23, 2009
SOURCE: Connecting Nintendo Wii to JVC television
every time im using my wii in my jvc tv i keep clicking channel the when i click the tv button on the rca remote then a code. i keep forgething the code
Posted on Dec 12, 2010
Laptop will not connect to tv
the tv might not be able or new enough to handle the picture of a laptop or computer check to see if it is able to
Apr 23, 2013 | JVC Televison & Video
JVC LT-42X579 42 in. LCD TV
If it has more than 1 port try another---If it has component try connection there.
Mar 22, 2012 | JVC LT-42X579 42 in. LCD TV
I connected a sony playstation 3 and there is no sound while playing games. The video works and I can play the game, but there is no sound. I returned the playstation 3 thinking it was the console but the...
http://manuals.playstation.net/document/en/ps3/current/settings/audiooutput.html
Adjust the audio output on your playstation and the television depending upon how you're connecting it to the television for picture and sound.
For an hdmi cable between the television and the PS3 only then adjust the audio ouput to hdmi on the PS3.
You do not need to connect anything else between the television and the PS3 besides an hdmi cable.
If you are using the colored plug type component or composite cables then it is av.
If you are connecting with a fiber optic cable to a surround sound system then it is set to optical.
Depending on what television you are using you would also have to change the Playstation to 48khz/96khz
Jan 09, 2011 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
No picture coming to my tv
If you have sounds already playing on the laptop, then you must switch your default to the HDMI then go and re open the program ie itunes. Any other program playing sounds on ur laptop speakers will continue to play through the lap top speakers...
On VISTA do this
Right click your screen
go to personalize
on the left there is an option "connect to a projectror or external display"
Click the speaker picture, and set the default to HDMI by right clicking it and selecting make default.
Close your media programs, and then re-open them and hit play
However, click the provided link for more information;
http://www.zimbio.com/Playstation+3/articles/20/Playstation+3+No+Picture+Problem+How+Fix
Regards,
Anirban Mazumdar
May 16, 2010 | Sony Playstation 3 (PS3) Console
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
Dec 28, 2007 | Televison & Video
Televison & Video Logo
169 people viewed this question
Top Televison & Video Experts
