Question about Emerson LC320EM9 32 in. LCD HDTV
Go to turn on tv and it goes from on to off right away with no picture or sound....put new batteries in the remote;;;;checked all wires and cables...tried to go into component but tv wont stay on to do anything
    Top Expert:
  • Emerson Master
  • 14,553 Answers
Power supply--some suggestions here if able to safely open the set:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signs of damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down the problem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the generic ones like Radio Shack). Many fuses are special even aside from amperage--Don't put a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses a standby power supply that runs 7/24 and a main supply (some are combined and some not.
Here aside from checking fuses you want to examine all the filter caps on the power/standby to see if any are puffed up or buldged up in some fashion--I attach a photo of a good one---top should be silver metal and PERFECTLY flat and have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating (saves money) which causes them to fail in a year or two---the standby runs 7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over. If set is opened at least look for puffed up and bad caps like in this photo.
go to turn on tv and it goes from on to  - 11_8_2012_4_10_38_pm.jpg11_8_2012_4_10_58_pm.jpg
Posted on Nov 08, 2012
2000 SC92 TURN KEY ON PUSH START BUTTON,NOTHING. SHOWS MILAGE TO CHECK ENGINE AND GREEN NEUTRAL GOES AWAY. PUT NEW BATTERY IN READS 12.5 VOLTS. ALL LIGHTS SHOW ON,BATTERY GOOD.
sounds like you have a bad connection on you're battery or on a ground wire some where on make sure the ground wire on the motor is tight
May 11, 2011 | 2001 Victory V92 Cruiser
2001 sunfire put new starter in car would not start so put in new battery car finally started after holding key to start then would not turn off unless u disconect battery posts, now when u put posts...
Hi, it sounds like the starter solenoid was not wired properly. You have 2 wires at the starter, right? The bigger wire goes to the big top post on the solenoid, right? The smaller wire is called the start wire and it goes to the smaller terminal labeled "S." Is that how you wired it? You also have to be careful when tightening the nuts on the terminals that the start wire terminal does not touch the other terminals and vice versa. Do you have the starter in the car now? Can you take a picture to send me?
Apr 05, 2011 | 2000 Pontiac Sunfire
Menu pops up while tv is on
Isolate the problem by removing the batteries from the remote. If the problem goes away replace the remote: "CHEAP" .
If the problem does not go away, the problem is in the TV, repair the TV "EXPENSIVE" !
Aug 28, 2009 | Televison & Video
Picture and sound go out and remote isn't working properly
Take the original Mitsubishi remote and remove the batteries. Install new fresh batteries and then try to operate the set. Do not try to use any of the inputs that are active. Just check menu funtions with the mits remote. All kinda irrational stuff happens when multiple and universal remotes get involved. If this a model remote that has a selector switch at the top for choosing tv/sat/vcr, etc make sure it's on tv.
May 28, 2009 | Mitsubishi WS-55515 55" Rear Projection...
WII CONSOLE
When you turn the Wii on, and the light goes from red or orange to green, press A a few times (this would be to get through the warning/safety screen) then wait a minute. Then when you wave your remote about, you will feel it vibrating as it goes over the channel icons on the wii menu screen. Plus a blue light will be lit at the bottom of the remote to denote player 1.
If all of this happens, it is just a lead or TV input issue. If these things do NOT happen, the Wii is broke and needs fixing by Nintendo!
Dec 25, 2008 | Nintendo Wii Console
NO PICTURE
Turned the Tv seton had only half a screen tried to used the remote to reset the set to is regular settings it reset but the picture was offset to the right of the right of the screen I the brought up the menu in hopes of using the vertical or horizontal to bring it back full screen and the remote stop functioning for the tv and i put new batteries in it thinking matbe the remote was down but to no avail it still didnot work I had to unplug thr tv for about an hour and plug it back up for the remte to work and still had only a half of sreen and now i have sound and no picture just a green screen
Nov 15, 2008 | Televison & Video
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
JVC AV-27530 27"
WHEN YOU TURN THE SET OFF,SOUND LEAVES BUT PICTURE STAYS ON--SOUNDS LIKE THE MAIN POWER RELAY IS STUCK-NEEDS TECH TO REPLACE BUT SHOULD BE A CHEAP JOB!!
Dec 03, 2007 | JVC AV-27530 27" TV
Sky remote code for lg 37lc46
for sky plus remote ver 8 the code four number is 0206
the three number code is 206
Nov 16, 2007 | Televison & Video
Remote wont work TV goes off by itself
Hello, please take the batteries out from the remote. Best regards, Arpi
Jun 23, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Emerson LC320EM9 32 in. LCD HDTV Logo
27 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
