Question about Microsoft Xbox 360 Console
Wireless controller flashing green light but wont detect xbox360?
Xbox360 switches on and wireless controller switches on but they won't "marry up"??
  • lorraineabbe Jan 06, 2009
    Thanks a million this was very helpful tip!!
    Problem Solver:
  • 19 Answers
Have you pressed the connect button on the controller and the unlabeled connect button on the console? The console's button is the small round button between the memory card slots and the power button. Press them both and they will search for each other then marry. Do this for every new wireless controller you buy as well.
Posted on Jan 05, 2009
  • 124 Answers
Have you tried resyncing your xbox and controllers? On the controller, press the little circle button on the top of the controller, between the bumpers. On the 360, there's a small circle button, about half inch wide, next to the memory card ports. Press that as well.
Bluetooth peripheral device driver
Sai Ch Krishna,
Depending on the system. The bluetooth would have to have been purchased at point of sale. The wireless and the bluetooth are turned on by a wireless switch on the side of the computer. If needed you can reinstall the drivers. Also, make sure bluetooth is turned on in the bios. Below is more information.
Wireless Switch
Wireless Technology The Latitude D630, D631, and D630c system ships with a wireless feature called the wireless switch. It is located on the left side of the system next to the IEEE 1394 connector. When used in combination with the Dell 38482; Quickset utilities, this switch enables or disables the wireless LAN, wireless WAN, and Bluetooth cards in the system or searches for all wireless networks in range.
To scan for a Wi-Fi wireless LAN, slide and hold the switch in the momentary position for a few seconds. The Wi-Fi Catcher network locator works whether the computer is turned on or off, in Hibernate mode, or in Standby mode, as long as the switch is configured through QuickSet or the BIOS to control Wi-Fi network connections.
Because the Wi-Fi Catcher network locator is disabled and not configured for use when the computer is shipped, it must be enabled and configured through the Dell QuickSet utilities to control Wi-Fi network connections.
Wireless Switch LED Settings
The LED on the wireless switch works even if the system is off. A user can activate the switch and have it scan for networks without going through a complete boot process. The switch can be set to detect for only certain wireless signals, such as WLAN only, WWAN only, Bluetooth only, or any combination of these. This is set in the BIOS under the Wireless section.
The LED indicates the presence of a network as follows:
  • Flashing green - The system is searching for a signal.
  • Green - The system has detected a wireless signal and has good strength.
  • Yellow - The system has detected a wireless signal, but it is moderate to weak in strength.
  • Red - The system failed to detect a wireless signal, or the wireless signal is extremely weak.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Aug 27, 2013 | Dell Computers & Internet
Problem with the xbox 360 wireless network trying to connect with the internet
Hi Kev716
When you say the red light comes on, are they 3 red flashing lights?
Jan 09, 2008 | Microsoft Wireless Network Adapter Xbox...
Push buttons on remotes won't raise/close lift master mod 81lm
Check to see if the light in the wall control is flashing. If it is press and hold the lock button for 3 seconds.
Jun 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
Gamestop Edge PS2 Wireless controller wont work. New batteries and the square control (router) box just keeps blinking green. I pressed the button for reconnect and it still does nothing I need...
If the light on the controller is flashing then the batteries are still good. There is a small reset button on the receiver that came with the controller. use a needle to reset it while it is still in the ps2. make sure that the ps2 is turned on and the green light is flashing on it. it should blink a few times and then the light on the controller should turn red. once it does then press start and your good to go.
Hope this helps!
Nov 08, 2009 | Gamestop Edge Wireless Controller for Xbox...
I have a siemens gigaset se587 wireless router and a xbox360 network adapter it does not connect up to my network where am i going wrong I have connected it up using the ethernet cable and it works fine...
sorry to bother but i cant get xbox live to work with the ethernet cable, where did u plug the ethernet cable into? ive tried different places and none seem to be working
Oct 17, 2009 | Microsoft Wireless Network Adapter Xbox...
My wireless cntroller will not flash its green center lights
sounds like.... the battery completely died on controller.. you charged it by plugging it in to system and never restarted the system to regain the wireless signal..
turn off 360... turn off controller.. boot system.. boot controller, if no signal is detected you have a hardware issue with controller (assuming other controllers work with system)
Aug 24, 2009 | Microsoft Xbox 360 Controller
Xbox360 wireless adapter wont work
your router is no compatible with xbox live , get a new router .THere is no other option .
Apr 10, 2009 | Microsoft Wireless Network Adapter Xbox...
My second wireless controller for my xbox360 wont work.
You still have to hit the sync button on the controller and on the console to marry them. Just like when you first got the console. Just hit the small round button on the console that is between the memory card slot 2 and the power button, and the sync button on the top of your controller. The lights on both will spin then lock. They will be married and you will see the controller 2 light on on your ring.
Jan 14, 2009 | Microsoft Xbox 360 Console
Xbox360 wireless controller not being detected
1. Turn XBOX360 on
2. Press the sync on the XBOX360, green lights swirl
3. Hold the center xbox logo button on the controller, lights swirl
4. Release the xbox logo button on the controller then press the sync on the controller
Good luck
Dec 04, 2008 | Microsoft Xbox 360 Console
Wireless controller
to activate the second wirless controler you have to press the search button on the xbx360 just below memory unit b, then press the search button on the controler aswell.
Dec 30, 2006 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Console Logo
282 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
