Question about Linksys Wireless-G WRTP54G Router
WRTP54G not routing
Linksys WRTP54g rev 1.1 stopped routing.
The IP from ethernet is in status tab ok.  All config is ok.  Even led is blinking. Sudennly it stopped routing few days ago.
  • bartosz_bedn Jan 05, 2009
    no,  this does not help.
    But very strange: Few minutes ago when i turned off wifi server, sudenlyit started routing.
    But when i turn it on (wifi in settigs), after 1 minute it stops working.
  • 268 Answers
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
Posted on Oct 13, 2011
    Genius:
  • 1,913 Answers
Turn the power off for 5 minutes then try.
if still pro let meknow.
Posted on Jan 05, 2009
    Problem Solver:
  • 16 Answers
If you see back side of the modem a hole from where you can rest the modem, so please reset the modem to solve your problem. In most cases it will work.
Note: all you saved settings in modem will be erased and you need to reconfigure your modem again (eg: user name and password, etc.).
Hope it will solve your prolem.
Thanks.
I have got a WRTP54G Switch Ihave lost the CD I need to set a password to WIFI in it how can i do
Hello Friend
Please open page with address 192.168.1.1 and open the router page with username= blank
password=ADMIN
Go to wireless tab and click on the security
Click on the secutiy box and enable this.
Set this to WEP or WPA
Enter the passprase\password which you want tas a password for your wireless network.
Enter these details
You can also check this user iterface here.
http://ui.linksys.com/files/WRT160N/v3/3.0.00/WL_WPATable.htm
Jul 22, 2013 | Linksys WRTP54G Wireless-G Broadband...
I need to secure my router just for my home , right now it is open so anyone can use it .
you can use the website here:
http://homesupport.cisco.com/en-us/wireless/lbc/WRTP54G
click on the tab that is labeled "guide me" and type in "wireless security"
The web based application will ask you a few multiple choice questions based on what you want to accomplish.
If the web based help does not live up to your expectations, the manual is also available from the same page on the "downloads" tab.
Dec 23, 2010 | Linksys Wireless-G WRTP54G Router
I am trying to find my WPA address for my linksys wrtp54g. How do I find this?
Unfortunately since the key is masked on your router even when looking at it physcally on the router, you would not be able to determine the key. The easiest thing to do is to change the key and match it with what you configure on your laptop.
Follow step 6 on this link to create a new key (but choosing WPA instead of WEP):
http://www.columbia.edu/acis/networks/aptnet/linksys/index.html
Jul 01, 2009 | Linksys Wireless-G WRTP54G Router
The wireless network is broadcasting but it will
Howdy,
Sounds like you may have an encryption problem. Are you running an open or secure network? Try setting it to Security > Disabled and see if you can get on. (Please note where you were before you disable the security) This will be under the Wireless > Wireless Security tab. If you can connect after disabling the security then you probably did not enter you key code correctly. OR... You may have set it to a level of encryption that your wireless laptop does not support. (Don't know the age of the laptop - some older ones will support WEP only and "b" only.) Make sure that you are broadcasting in both "b" & "g" ranges and if WPA won't work for you, then try WEP. It is a little difficult for me to tell you exactly what to do because I do not have all the necessary information but perhaps this will help. The main thing is to disable the security first and see if you can connect. If you can, then this is a BIG clue and good news. Then you know it is an encryption issue.
Typically the encryption choices are WPA - WPA-PSK - WPA2 - WPA2-PSK - RADIUS & WEP. I would recommend WPA-PSK with TKIP for normal "modern" applications. If your WRTP54G has the Auto Security setup button on the front of the router you may want to use it to automatically set up your wireless security. You can tell by feeling the raised rectangular push button on the front panel.
Good Luck!
J
Jun 12, 2009 | Linksys Wireless-G WRTP54G Router
Internet connection problems
Sorry but that seems to be a pretty convoluted explanation. Here is how it should go.
Vonage unit connected to phone line(s) and cable modem. Linksys connected to Vonage box. Computers connected to Linksys.
Ethernet has a length limitation of about 300 feet before you need another switch (hub) or a repeater. Does your wire length exceed this?
Apr 20, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys router
hello any one help me for router i can't entry to sitings on the ip 192.168.1.1
Sep 24, 2008 | Linksys Wireless-G WRTP54G Router
I heard that u shouldn't donwload a.....
If you have troubles using linksys devices here is FREE way so that a SENIOR technician form linksys will call you at the convinience of your own preferred time.
100% Satisfaction & Problem resolved !!!
step 1.
step 2.
step 3.
and fill up the form.
ENJOY!!
-- GEEKazoid.
Jun 21, 2008 | Linksys Wireless-G WRTP54G Router
Linksys Wireless-G WRTP54G Router Logo
246 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
