Question about Pentair Whisperflo 1 1/2 Hp Pool Pump Wfe-6 011514 (Pentair)
Wire diagram for whisperflo Wfe 2
I want to know how to wire the whisperflo pump. I bought a wiring harness, but it didn't come with any instructions
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: Pentair WhisperFlo Wiring Help
If you just bought this then there will be a diagram on the motor nameplate and/or under the terminal cover where you connect the wires. Generally speaking, there are two wires inside the motor that change positions depending on 115 or 230 v connection. If one of the wires is on a post common to one of the line leads, that usually means you have the motor set for 115V. Is that the voltage you are supplying to the motor? If there is no diagram you can make out on the motor, post what brand motor and the motor model number for a diagram.
Posted on Dec 24, 2009
  • 8404 Answers
SOURCE: pentaire 011486 wiring diagram
My friend, my experience with the two speed pump in low speed is less than spectacular. There is so little filter action with the lower speed as to render the process useless. If you are trying to save $, better to run the pump a little longer then turn it off. My experience is in a commercial application. I run three such pumps in that system ... the additional expense of the two speed motors was a waste of capitol. In addition, as a commercial facility, we could not meet the required water turn over rate in our pools. Of course yours is a smaller body of water and you are probably not in a commercial facility. We get a LOT of cleaning (through filtration) at night, after the customers go home.
I suppose you could run your system with a intelematic switch ... I have not seen a 'three way' switch in this line ... having said that ... to my way of thinking ... you would wire directly through the selector switch on the back of the motor to each of two intelematic's; one on the high side and the other on the low side. I would allow at least 30 minutes between the two cycles to prevent impeller damage.
Thanks for your interest in FixYa.com
Posted on Aug 02, 2010
jandjsay
  • 25 Answers
SOURCE: ghart106 asked:
There is a wire diagram on the inside or outside of the motor housing. There is a simple wiring switch that you can do to change the motor from 110 to 220 or vice-versa. Everything you need to know is on the motor.
www.cpo2go.com
Posted on Dec 03, 2010
Hello i have a 2012 passat so the person who had it before me cut off the male insert to the manifold air pressure sensor i bought one at the dealer but i dont know what color wire goes to what on the...
take to a dealer as they will do it in 10 mins and scan the OBD as well to check for any other issues , as vehicle is only 2 years old , leave out the way this happened say it was vandalised
Oct 07, 2014 | Cars & Trucks
New pump motor smoking 1 minute into running
see side of motor make sure brown on correct lead and white also
Sep 24, 2017 | Pentair Whisperflo 1 1/2 Hp Pool Pump...
Wiring 110v on wf-28
see side of motor for diagram you have to move wires or turn a switch to 120 volt then wire double check before turning on
Mar 15, 2012 | Pentair Whisperflo 2 Hp Ur Pool Pump Wf28...
Put new foglights on my 2002 hyundai elentra gls but dont know how to wire them
First of all, did the vehicle previously come with fog lamps? I'm assuming it didn't. Normally, each YM (Year/Model) Hyundai wiring harness is complete for every feature which might be included with certain trim specifications. However, you probably don't have the multi-function switch which has the 'Fog Lamp Switch' on it (Left Hand Turn & Parking/Headlamp Switches). However, the wiring for the fog lamps is probably there, you just need the multifunction switch which contains the fog lamp switch. The illustration attached shows where the wire harness plugs into the fog lamp bulb. This connector may be taped up in the wire harness out of the way (since I'm assuming the vehicle didn't originally come equipped with fog lamps).
Aug 29, 2011 | Hyundai Elantra Cars & Trucks
Wiring a 230v ao smith pump : L1 and L2 connection
Hi, assuming you have 4-conductor wire, use the black and red wires for L1 and L2. It doesn't matter which goes to which. If you do not have a red wire, use black and white. The green or bare wire in a 3-wire cable goes to the ground. If you have 4-conductor wire, the ground wire is the one you used for the GFCI on the breaker--usually the white wire. Please let me know if you have more questions, and thanks for using FixYa.
Aug 08, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
Bought a used coleman 15,000 btu with heat pump.The wiring harness came seperately and I don,t see a place on the unit to wire it in. The wire diagram shows 24volt control but there is no transformer in...
You'll need the ceiling assembly and control box to operate it properly, or at the very least a ceiling assembly with mechanical controls. The ceiling assembly is where you will run your 110 volt, and depending on what set-up you choose, the wiring etc, relays and transformers will be determined by that. I assume you didn't get the ceiling assembly with it? Here's a link to wiring diagrams etc and service manuals to help you understand what and where to go with it. Model number should be on it, just go to proper info pertaining to your model.
http://www.rvcomfort.com/rvp/tech_info/manuals.php
Jun 12, 2011 | Coleman Mach III Air Conditioner
Dec 24, 2009 | Pentair Wf 6 1.5hp Whisperflo Inground...
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
Ghart106 asked:
www.cpo2go.com
Sep 06, 2009 | Pentair 1.0 Hp Whisperflo Pump
Trying to install Flotec Dual Voltage pool pump. Instructions have an addendum which instructs how to turn dial to change between 115 and 230 but does NOT show me where wires go. Refers back to owners...
The motor should have a diagram on it showing where line 1 & 2 go. It does not matter which of your two line wire goes to which post, as long as you put one wire per post and have the motor set for the correct incoming voltage, you'll be fine.
Jun 15, 2009 | Pentair Whisperflo 3/4 Hp 115/230v
Pentair Whisperflo 1 1/2 Hp Pool Pump Wfe-6 011514 (Pentair) Logo
65 people viewed this question
Top Pentair Garden Experts
Charles T Nevin
Charles T Nevin
David Burbee
David Burbee
David Spradling
David Spradling
Are you a Pentair Garden Expert? Answer questions, earn points and help others
