Laptop screen messed up
My laptop screen is messed up. half the screen totally blacked out. what do i do?
    Genius:
  • 1,913 Answers
Power off the laptop when u power up the computer press F8 key then run in enable vga mode.then chagne screen resolution to 1024 *768 then apply and ok.
Posted on Jan 05, 2009
How do i fix the bottom half of my laptop screen which is all black
It is unfortunate that the bottom half of the laptop screen is black. You may try performing an LCD BIST using the below link:
http://dell.to/1irqbYp
Also try connecting an external known good monitor and check if that helps.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jul 06, 2014 | Dell InspironTM 1501 Notebook
Screensaver set
Hi, go to start- Control panel- personalization. Click here and check if the
screen saver is turned off. It is located on the lower right corner. Click on it
to turn the screen saver back on. This is for windows 7.
If you are running XP go to Start- Control panel- Display. Click on the
display icon and there is a tab that says screen saver. Click here and chose
your screen saver.
Oct 19, 2013 | Acer Aspire One PC Notebook
Computer screen messed up after connecting to a Projector.
Sounds like your screen resolution has gotten changed. Plug your VGA cable in and reset it to 1024x768. Then with the laptop on remove the VGA cable. When you connect your laptop to other devices like that, make sure you are not setting the resolution to the same as the TV.
Jan 04, 2013 | Dell Inspiron 1501 Notebook
Screen is black
The cable is dislodged or you have a failing lcd.If you want to repair this yourself.Check online for a replacement cable and a Lcd too.Then you will have to open the Lcd Bazel to remove or check the cable.Make sure when you attempt this there is no power attached ,battery and Ac Adapter.
Good luck
Nov 02, 2009 | Gateway 450ROG Notebook
Screen is half picture and half black with vertical colored lines
I had the same issue. I could get the tv to work intermittantly by pressing on the boards while playing. This points to bad solder joint, so I resoldered every molex plug connector, and it nows works like a charm.
Apr 06, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Fix Acer Aspire 5610z Laptop Screen
you need a new screen!!! www.computereworld.com I can fix this for $170 total, that is a new screen and the labor. submit a request on my site, or call me 662-549-2362
Jan 08, 2009 | Acer Aspire 5610-4648 Notebook
Display problem
you have to open the chasis of the notebook and resit the ram if the problem is not solved then your notebook needs servicing
May 28, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
484 people viewed this question
David Payne
David Payne
