What does unsupported personality mean and how can I fix it?
The HDMI signal says "unsupport" What does that mean?
Normally this is a problem with the HDMI cable. It is sending a garbled signal for some reason (could be a bad end connector or a broken wire in the cable) and the TV does not recognize it. The simple way to fix this is by replacing the HDMI cable. Answered from experience as I had this happen about a month ago.
HDMI signal says unsupport Google Search
Jan 01, 2017 | Televison & Video
Unsupported video format
You would have to convert the files to a DVD / BR disc with converter and then burn as a DVD or BR.
Media files are managed by CODECS. Basically code / decode. This means your PC will manage more types of files than a player which will only do a few types if any at all. If fact the CODECS are constantly being updated. Players aren't. gl
May 02, 2013 | Toshiba BDX5300 3D Blu-ray Player
D-Link Unsupported usb
Means that the device you are trying is unsupported by your PC.Can you give more error info?
Apr 11, 2013 | D-Link Computers & Internet
Unsupported video signal. what rate should i set my desktop at?
The unsupported video signal could mean you need a video codec.
For a video codec try this WEB site.
Free Codecs
www.free-codecs.com/index.htm
Mar 14, 2013 | Computers & Internet
Unsupported card... What does this mean?
Hi.
Its either the card type is unsupported or the capacity (size) of the card is too big.
Regards.
Jun 02, 2011 | Vivitar ViviCam 3705 Digital Camera
Unsupported personality
when i print a page its shows''unsupported personality unknown'' hp printer 1320 what can i do
Jan 31, 2011 | HP LaserJet 1320 Printer
Not so much a problem but got message printed out while trying to print a document. Unsupported Personality: UNKNOWN. Does this mean something I should be concerned with ??
An error page will print with the words "Unsupported Personality: PCL " in the upper left hand corner. The printers are host-based and do not support PCL printing; therefore, installing an alternate PCL5e or PCL6 printer driver will frequently generate this error condition. NOTE: This error condition occurs by design when an attempt to print with a PCL5e or PCL6 printer driver occurs and is NOT a bug within the product software. SOLUTION: Install the correct HP LaserJet Host-Based Printer Driver or the HP LaserJet printing system software for the product. These drivers are available for download from the HP web site. Click here to go to the HP web site drivers and downloads page. NOTE: There are several programs (such as accounting, invoicing, court documentation applications) that are 16 bit (DOS) programs with a 32 bit (Windows) overlay. Due to the nature of these applications and the associated Windows overlay, the errors may continue with the correct printer drivers. These applications do not typically support a host-based output device, and as such would not be supported in these environments.
Feb 24, 2010 | HP LaserJet M1522n MultiFunction Printer
Format unsupported
Format unsupported simply means the unit can not read the disc. The problem is either the disc or the player.
Contact Bose technical support if you are sure the discs are good. 800-367-4008
Jul 31, 2008 | Bose 3 2 1 GSX System
Unsupported personality: PCL on leopard
uninstall and reinstall the printer drivers
Dec 15, 2007 | HP LaserJet 1012 Printer
56 people viewed this question
jasbo
jasbo
