Question about Water Heaters
Alpha boiler - wireless programmer failing
Alpha model HE CB25 - DHW is fine, but after setting up wireless programmer to be ON and room its thermostat to 22 deg min., 25 deg max, the heating fires up but then shuts down after about 2/3 minutes, even though room temp on programmer indicates only 18 deg.
I have tried another programmer i.e. transmitter, from an identical boiler with same result.
I have not changed the receiver.
  • keithfarmer9 Jan 12, 2009
    Taking your advice, I diagnosed the fault to the receiver.
    Thanks for your help.
  • Anonymous Mar 23, 2014
    I have a used 1F90 C-S 2 thermostat and was wandering if the heating cycle can modify to achieve a 2 to 3 deg.C difference between start and stop of the stove. This is for a Piazzetta 960 pellet stove.
    Thanks,
    Jacques Goudreau
  • 700 Answers
It sounds like the problem may be in the boiler and not the controller itself. Do you kno which is are the two wores that are the r-w for the thermostat take and purt them together and see if the boiler stays on or shuts off like it does with the thermostat. If it does then replace the reciever. If it doesn't then you have another problem. Good Luck
Posted on Jan 07, 2009
I had an issue with turning off the fill valve on my alpha boiler and the pressure went to 1.5 bar when cold and rises to 2.75 when the heating comes on is this ok.
You need to check with the boiler/system specifications to discover the correct pressure.
An overpressure condition should be dealt with by a safety valve that usually vents to the outside of the building - if it is working correctly. There have been incidents of this external vent freezing causing dangerous pressure to build in the system. I understand a modification is simple and inexpensive but I don't know any details.
Our pressurised system runs at about 2.5 bar hot, or at least it used to do when it was younger...
Jan 25, 2017 | Water Water Heaters
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
Boiler not coming on, programmer constantly flickers on/off
if voltage from transformer ok check to pressure switch bad or loose wire
Aug 01, 2016 | Honeywell Water Heaters
Alpha boiler cb24
Google Alpha boiler you should be able to down load a online manual with a ff chart in it . which should have codes in there for flashing lights .
Jul 29, 2017 | Water Heaters
My Alpha 240E boiler does not heat water from the taps unless the radiators are on. I have been told this is because my boiler needs a new convertor valve, can I purchase a convertor valve and how wou
Its a diverter valve thats required not a converter as you state,it is not recomended to do it yourself ,you can get the valve easily from a reputable plumbers merchant ,alpha is a popular boiler, just supply the gas control no or boiler details to the merchant and the should be able to get the right divertor valve, then you just have to find a good plumber to fit it , it would be quicker and safer for some one qualified to change this.
May 19, 2017 | Water Heaters
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Water Heaters Logo
426 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
