No picture on main screen
I can get sound and P.I.P. but no main picture when you turn off p.i.p. just sound. please help. ps this happened after a lighting storm.please give details and picture of problem thanks ,jlynnmckenzie@gmail.com
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Sets with PIP use two tuners--one for main and one for PIP---likely the main got hit with the static discharge during the storm----Here we always disconnect both power and cable when a storm.
There is a way around this (will lose PIP) with a cable box connected to the audio and video inputs on rear of set---bypass the tuners and use the box to change channels and provide signal.
let me know if questions.
Posted on Nov 08, 2012
  • Lynn Mckenzie Nov 14, 2012
    i tried your solution with my direct tv cable still the same problem ,any certain kind of cable box? ps. sorry i was unable to try the solution right away but i just got help moving it to a cable connection.p
2 Suggested Answers
jingjao
  • 252 Answers
SOURCE: JVC AV-32D305(?) turns off sound but not picture
if you know how to solder ,resolder the amplifier your tv .or check speaker
Posted on Oct 24, 2008
TV has no picture, no sound just the VIZIO logo light is on the screen.
Did you check out the power supply for proper operation since both the audio and video are gone? If PS is good then the problem may very well be on main board.
May 03, 2016 | Vizio E421VA 42 in. LCD TV
Vizio tv sv420m need help
Sure that the other boards you used were any good? If so, then try the Power supply board since the other boards of your set other than the main board specialize in the video aspects. Since you have no audio the only two boards that could account for no audio are the main board and the PS board which powers everything in the set.
Nov 13, 2015 | Vizio SV420M LCD TV
Sound but no picture
After replacing the main board, a software update will be necessary in most cases. Check it.
Jan 08, 2013 | Vizio VW42LF 42 in. LCD HDTV
No picture on coby tv
I'm not certain but it sounds like there is a loose video cable in there...if you are able to, take the tv apart, and literally push on all of the connectors and cables to make sure they are not loose. The main video cable may not seem to be loose, but once it is making contact again, it should clear that mess up. Just look for cables running to the main screen and pull them off and put them back. Then put the tv back together again and see if it worked...it usually does. why does this happen? Some blame it on dust, others blame it on quick manufacturing processes...whatever the case, the cables become slightly seperated from the controller board and that happens...it also happens to computer monitors too...Good luck and take your time. If there are a lot of screws and things either take pictures of where they all went or write it down. I like to make a diagram on a piece of paper and tape the screws on the diagram to show where they went.
Sep 01, 2012 | Coby Televison & Video
Have a vizio vx 42l on the bench. amber light only no power up have my standby 5vdc and my 3.3vdc power button is sending a high pulse to the main mod but i dont get pson to the power supply mod suspect...
This is your mainboard needing replaced! Simple as that!
The main sends the pson signal and without it...you have a dead tv.
Please rate if this helped :)
Mar 10, 2011 | Vizio 42 in. LCD TV
Westinghouse LTV-32W1 Plays for awhile then no sound or picture
could be two thing the new ps board you put in was defective or the inverter board is failing
Dec 07, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Broken
Dear schmex,
It sounds like you have a broken LCD screen this shouldn't effect the image quality, but it might get worse over time and it will probably make it more difficult to compose the picture.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 16, 2008 | Fuji FinePix Z100fd Digital Camera
Cant see ps3 main menu
when in standby hold down the power button for over 4 seconds, it runs the optimal screen settings menu, hope this helps.
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
No picture subsequent to "tin foil experiment" on screen
Static discharge to the TV can cause lots of strange things to happen, replace the main board and your problems should be fixed
Nov 25, 2017 | Philips CCX192AT 19 in. TV/VCR Combo
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
