Question about Dremel 10.8V Lithium-Ion Cordless Rotary Tool Kit w/ 40 Accessories - 8000-02
Dremel charger model 856 won't charge. Charging light will not come on.
Model number on Dremel tool is 800.
SOURCE: obtaining a manual
dremel manuals are found here: http://www.dremel.com/en-us/CustomerService/ManualsAndLiterature/Pages/default.aspx
enjoy.
james
Posted on Sep 23, 2008
  • 132 Answers
SOURCE: Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
Posted on Nov 16, 2008
rowdy45176
  • 2176 Answers
SOURCE: My Dremel tool has intermittent power.
You can go to any repair facility and buy a replacement cord making sure of the wire guage and conductor (2 or 3) what you can do is make a wiring diagram and remove the old cord and holding the cord about 10 inches from end pull one wire at a time and if there is a break it will pull out to confirm your suspicion. Let me know if you need any more help and if I have answered your request would you please rate this response accordingly and thank you.
Posted on Sep 02, 2009
  • 3 Answers
SOURCE: dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Posted on Sep 26, 2010
  • 157 Answers
SOURCE: Dremel 10.8V cordless model 800 (8000) The speed
You are right,it will need a slider switch replacement,But first-is it still under warranty?If it is call the costumer support on their 1-800 ...number.If not you could DIY it.Opening the drill is not that hard and as long as you observe the proper orientation and where every wire is connected to,you will be able to disassemble the unit.Inside you could see where the slider switch is connected and how it is positioned.Usually the surface of the switch is burned out and this you have to replace.The next problem is locate the part number it is usually found printed under the slider part.And the next big thing is to order the part and where to order it.Consult the user manual that came with Dremel unit and the ordering address is there.
Posted on Nov 06, 2010
How can I locate capcisator for Dremel Stylus Lithium-ion model 1100 ? It has got charging problem.The Stylus is a cordless tool.
Do you mean a capacitor? Is it the charger or is it the battery? The capacitor are plain types can be found at any electronic parts store. I think the main one is 220uf. Be sure an check each for problems.
Jan 18, 2015 | Dremel Tools & Hardware - Others
Dremel power supply won't hold charge
Your battery may be shot. Does the charger light up when you're using it? If so then it's time for a new battery.
Feb 13, 2013 | Dremel Tools & Hardware - Others
I had a similar problem. I was going to take the charger apart but I ran into triangular socket head screws so in desperation I gently bent the 5 contact wires out from the battery socket. After slipping in the battery and plugging the charger into the wall socket, the charging light returned. The charger contacts that come into contact with the battery are easily pushed back and after a few battery insertions fail to make contact with the battery.
Feb 10, 2013 | Dremel 10.8V Lithium-Ion Cordless Rotary...
Porter-Cable battery charger model #8605
go to www.dewaltservicenet.com and enter the model number of your drill. It will get you to the parts breakdown and will tell you if there is a charger available from the factory. Or call 1-800-433-9258 1-800-4DEWALT. stanley black and decker owns all of them so yes that's the right place!
Jan 02, 2013 | Porter Cable 19.2V Drill Kit
Cordless dremel
you might think im crazy but I just did this and it works so far anyway, I cut open my charger for my dremel 7300 model ,my green charging light stop working aswell , I felt naked without my dremel, so after the fourth day I cut it open and tinkered with it, I unwrapped some of that blue tape that\'s covering the copper spool , forgive my terms I don\'t know the correct name anyway I found a lil clear device connecting two silver wires, I twisted them together by grabbing the clear thing and twist until wires are connected put back together , put a batt in and green light came on and is charging, my charger looks like frankenstien but it works, how long will it last NO IDEA but if it stops ill post it, if you try this I hope it works, I should have videoed myself maybe nextime
Jan 01, 2012 | Dremel 750 02 Minimite Cordless Rotary...
Dremel Stylus only charges for 2-3 minutes then stops
This is the charger, its getting a reading from the battery that its charged when it isn't. I don't know exactly how that charger is wired but, to be suroe it is the charger, as I have had similar problems beforehand.
Jun 17, 2011 | Dremel & Stylus Lithium Ion Cordless...
Replace the docking station-charger of dremel stylus
ebay.com or www.craigslist.com
Try to find a used one maybe?
Sep 13, 2009 | Dremel Stylus Rotary Tool
Nov 16, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
Dremel 10.8V Lithium-Ion Cordless Rotary Tool Kit w/ 40 Accessories - 8000-02 Logo
411 people viewed this question
Top Dremel Drills Experts
richie46
Tom Chichester
Are you a Dremel Drill Expert? Answer questions, earn points and help others
