Sharp 950 error "paper guide for vertical feeding is open"
3 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: paper will not feed through the insert opening
Lift up the cover for the document feeder and clean the roller and pad with alcohol.
Posted on Nov 13, 2008
SOURCE: Sharp UX-184 Paper Feed
On inside of machine it states how to:
1. Place new paper roll on the left hub while pushing it in, lowering the roll into the compartment making sure it is inserted onto the right hub.
2. Pass the leading edge of the paper through the paper cutter guide and the cutter.
3. Remove any slack in the paper.
4. Close the cover. The paper will feed out automatically.
The paper rolls over top front to back.
Posted on Mar 05, 2009
Green light flashes 7 times
LED Blinking in Orange/Green:
2 times: No paper. (ASF) [1000]; Set the paper in the ASF, and press the Resume/Cancel button.No CD-R tray. [1001]*1; Set the CD-R tray, and press the Resume/Cancel button.
No paper in the cassette. [1003]; Set the paper in the cassette, and press the Resume/Cancel button.
3 times: Paper jam. [1300]; Remove the jammed paper, and press the Resume/Cancel button.
Paper jam in the under guide. [1304]
Paper jam in the rear guide.[1303]
Front door closed. [1250]; Open the paper output tray.
4 times: No ink.[1601 / 1611 / 1612 / 1613]; Replace the empty ink tank(s), or press the Resume/Cancel button. Pressing the Resume/Cancelbutton will exit the error without ink tank replacement, however, ink may run out during printing.
5 times: The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 /1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on.
6 times: Inner cover open. [1841]*2; Close the inner cover, and press the Resume/Cancel button.
Inner cover open (during printing on paper). [1846]*2; Close the inner cover, and press the Resume/Cancel button.
CD-R tray guide closed (during CD-R printing).[1850 / 1855]*1; Open the CD-R tray guide, set the
CD-R tray properly, and press the Resume/Cancel button.
CD-R tray guide open (during printing to paper). [1851 /1856]*1; Close the CD-R tray guide, and press the Resume/Cancel button.
7 times:No CD-R or DVD-R. [1002] After setting a CD-R or DVD-R in the tray, set the tray in the tray guide, and press the Resume/Cancel button.
8 times: Warning: The waste ink absorber becomes almost full (approx. 95% of the maximum capacity). [1700]; Pressing the Resume/Cancel button will exit the error, and enable printing. The service call error, indicating the waste ink absorber is full, is likely to occur soon.
In repair servicing, replace the bottom case unit (QM2-1249), or the ink absorbers (QC1-4222 / 4223 / 4224 / 4263 / 4264 / 4864).
9 times: The connected digital camera or digital video camera does not support Camera Direct Printing. [2001]; After removing the cable between the camera and the printer, press the Resume/Cancel button, and
re-connect the cable.
10 times: Automatic duplex printing cannot be performed (paper size not supported). [1310]; Press the Resume/Cancel button to eject the paper being used at error occurrence. Printing will resume from on the front side of the next page.
11 times: Failed in automatic print head alignment. [2500]; Press the Resume/Cancel button, and after confirming the following, perform print head alignment again: - Set an appropriate type and size of paper (plain paper, A4 or letter). - Check that the nozzle check pattern is properly printed (all ink ejected, no faint printing). - Protect the paper output slot from exposure to excessive light.
Access cover open. [1200]; Close the access cover.
LED Blinking in Orange and Green Alternately, or Lit in Orange:
2 times: Carriage error [5100]
3 times: Paper feed error [6000]
4 times: Purge unit error [5C00]
5 times: ASF (cam) sensor error [5700]
6 times: Internal temperature error [5400]
7 times: Waste ink absorber full [5B00]
8 times: Print head temperature rise error [5200]
9 times: EEPROM error [6800]
11 times: Carriage lift mechanism error [5110]
12 times: AP position error [6A00]
13 times: Paper feed position error [6B00]
14 times: Paper feed cam sensor error [6B10]
15 times: USB Host VBUS overcurrent [9000]
16 times: Valve sensor error [6C00]
17 times: Motor driver error [6D00]
20 times: Other hardware error [6500]
Continuous alternate blinking: rom error
Aug 31, 2014 | Canon PIXMA iP2000
Error J1
Hello Sharon,
When a document jam occurs, "J" and "1" will display alternately on the function number display panel of the scanner.Please perform the following:
  1. Remove all documents from the ADF paper chute.
  2. Open the ADF while pressing down the ADF open lever. If you are using fi-6130 with the imprinter option attached, please open the imprinter and then open the ADF.
  3. Remove the jammed papers from the ADF.
  4. Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is
resolved.
5. Replace Pick roller or Brake roller, and see if the error is resolved.Check the consumable counter from the TWAIN driver screen or from the built-in Maintenance mode. When the counter exceeds the values, replace Pick roller or Brake roller.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
May 03, 2013 | Fujitsu Office Equipment & Supplies
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    6b10 error, meaning?
    Hi this is what i found for your problem hope it helps thanks. Paper feed cam sensor error or Error Code 6B10
    Condition: An error occurred in the paper feed cam sensor during paper feeding from the cassette, or the paper absorbing a large amount of ink jammed in the PF rear guide.
    Problems and Solutions:
    • Jammed paper in the PF rear guide (when a large amount of ink was absorbed in the paper);
      - remove the jammed paper and foreign material.
    • check for foreign material or paper debris in the cassette or in the PF rear guide;
      - remove foreign material.
    • If other solution fail, replace one off the following part
      - PF pick-up unit
      - Logic board
    Sep 21, 2011 | Canon PIXMA iP2000 InkJet Printer
    Hp psc 950 all lights blinking
    System error C00F0401
    This error message can occur if the all-in-one has been stored incorrectly.
    Unplug the power cord to the all-in-one.
    Open the rear access door of the all-in-one.
    Rotate the paper feed rollers in an upward direction.
    Reinstall the rear access door.
    Reconnect the power cord.
    If the problem reoccurs, contact HP for assistance.
    and
    Performing a Partial Reset of the All-in-Onesolves it
    go to this link
    http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&os=219&product=60259&docname=c00060793
    Jun 09, 2010 | HP PSC 950 All-In-One InkJet Printer
    Getting u6-00 on arc172 checked all conectors switched m/c off/on no joy
    the error code is for paper miss feed or tray not set properly make sure you have the paper cassette is put in properly and that the paper guide plates at the sides of the paper are set properly and the guide at the back is holding paper in tray correctly o-pen the paper tray take it out and check this and then reset open the side door and close it correctly and this should help reset youcan check the paper feed rollers as well as sometimes they get dirty and will not feed properly you can clean these with a little glass cleaner and a soft cloth good luck A
    Jun 28, 2009 | Sharp Office Equipment & Supplies
    Paper feed
    Good day Sir, If paper misfeeds or skews, or multiple sheets feed or stick together, try the following solutions.
    1. Load a smaller amount of paper into a printer and make sure you use paper designed for inkjet printers. The paper is not used or damaged.
    2. Before loading paper the first time, squeeze and slide the paper guide to the left side of the paper support. Load the paper vertically against the right side of the paper support.
    3. Adjust the paper guide until it rests against the left edge of the paper.
    note: make sure the paper does not buckle when you adjust the paper guide. to avoid paper jams.
    have a nice day!
    Nov 19, 2008 | Lexmark X2350 All-In-One InkJet Printer
    Nov 09, 2008 | Sharp UX 108 Roll paper Thermal Fax
    SHARP AL-841 Paper Misfeed Error? The little paper mis-feed symbol is flashing - though there does not seem to be a jam ANYWHERE. The copier will not re-set.  Can someone help? Thanks, Ron...
    open right door and look on top there should be a littl lever there check carefully to see if there is a paper crumbled inside.
    remove tray and look where paper feeds out.
    Nov 19, 2007 | Sharp AL 1631 Copier
    180 people viewed this question
    jasbo
    jasbo
