Question about Borland Visual dBASE 5.5 Full Version for PC
How can i install visualdbase 5.5 in windows 7
Cannot install quickverse 5 on Windows 7
What's the error message?
Try installing it in safe mode. Restart your computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight safe mode and hit enter.
David
Jun 10, 2013 | Computers & Internet
Tip
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
729dcf7.jpg.
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
on Jan 24, 2010 | Computers & Internet
Unable to install HCL Lexmark H505 4126 printer to my laptop with windows 7 from original CD supplied with printer 5 years old
I had a similar problem with my HP 3650. I can install my printer on windows XP but not windows 7. I had to download the drivers compatible with windows 7 for the printer on the internet,
Hope this will help
Feb 29, 2012 | Lexmark X4250 All-In-One InkJet Printer
I can not install windows 7 on the dc7100
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 2GB of RAM to install windows 7
hope this helps
Dec 09, 2011 | Computers & Internet
I cannot install windows 7,no disk seen are there drivers for raid smart array 5I for windows 7? DL 740 G1 , 8 x 2700Mhz+40GB ram , 4 x 73gb Raid 5
Not quite sure what your problem is but I would recommend getting Windows Server for a server like this. The HP site recommends the following OSes: Microsoft Windows 2000,
Microsoft Windows Server 2003 (Standard, Enterprise, and Datacenter) ,
LINUX (Red Hat, SuSE) or Microsoft Windows 2000 Datacenter Edition. It is unlikely Windows 7 will install on this 5 year old server.
Jun 06, 2011 | HP Compaq ProLiant DL740 Server
Can I use my Borland Delphi 5 CD for installing Delphi 5 on my new Windows 7 computer
This is the last version of Borland dBASE for Windows (next version is Visual dBASE 5.5).
This is VERY unlikely to work as it was designed for much earlier operating systems.
Windows 7 is a very different architecture - maybe it time to upgrade.
Mar 10, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
Greeting card factory 5
Nova Development no longer supports Greeting Card Factory 5 on their website, but it looks like Greeting Card Factory 5 is only compatible with Windows versions up to Windows XP. You could try installing it in Windows 7, but it probably won't work right.
However, Greeting Card Factory 8 is fully compatible with Windows 7.
Jun 30, 2010 | Nova Development Greeting Card Factory...
Cant install windows 7? i put the cd in and go to auto boot but it gives me a code 5 error.
To resolve Windows 7 Error Code 5, all you need to do is start the installer through a different installer. Either find an old Windows XP boot disk and then direct it over to the Windows 7 installation DVD and run Setup.exe. This should kick off the installer normally and allow you to install the operating system.
Jan 10, 2010 | Asrock K7VM3 Motherboard
Cannot install Kodak AiO ESP 5 printer in Windows 7
Kindly call 1800 421 6699 and ask for a supervisor straight away.The representatives can connect you to supervisor after taking your informations.The supervisors can remotely access your computer and get the software installed on your computer.
Nov 12, 2009 | Kodak ESP 5 Printer
Borland Visual dBASE 5.5 Full Version for PC Logo
113 people viewed this question
Top Borland Computers & Internet Experts
Tony
Yoav Shilon
Yoav Shilon
Are you a Borland Computer and Internet Expert? Answer questions, earn points and help others
