Error M2 I have problem about error M2 CODE M2
  • 1,326 Answers
You did not let us know the secret of what make and mode of machine you have..... I'm going to take a SWAG..... You have a Minolta or panasonic copier???? M2 is for a PM counter
Posted on Nov 10, 2012
  • lamjed el abed
    lamjed el abed Sep 21, 2014
    it's a konica minolta make bizhub 165
How to remove error code M2
question too vague.
make? model?
example:
Re: Konika Minolta BizHub 163 - Error Code? M2
• To display the count of the supplies life counter.
When the counter reaches "0", life 1 will be detected and maintenance call M2 will appear.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
• To clear the count, use [CLEAR DATA] of the Service Mode.
Jun 06, 2015 | Office Equipment & Supplies
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
Sep 21, 2014 | Konica Minolta bizhub Office Equipment &...
BIZHUB 164 error M2 what have I to do
replace the drum and developer and then reset the counter
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 10, 2014 | Konica Minolta PAGEPRO 1380MF All-In-One...
Stop work with error m2
clear the counters first then replace the drum and developer then run F8
Feb 22, 2014 | Konica Minolta Office Equipment & Supplies
Konika minolta bizhub 215 error code m2
You need to go into the service mode and then reset the supplies life counter.
Feb 02, 2014 | Konica Minolta Office Equipment & Supplies
MY PROBLEM IS ERROR CODE M2 PL SOLUTION
Here is a website that has a list of Sharp Error Codes
Also here is a list of the drivers and copies of the
Sharp AR-M-205 owners manual and drivers
Hope this helps
Nov 30, 2012 | Sharp AR-M205 Copier
Maintenance M2 call service
M2 Call service.Maintenance M2, M1 Call service errors.To remove this error do the following steps.1-Press utility button on panel.2-Now press these buttons one by one, Press Stop, then zero, again zero, then stop,then press zero.3-its the code to get into service mode.4-After pressing above mentioned buttons you will enter into service mode.5-Now select service choice option.select it by pressing OK button.6-In service choice option you will see Maintenance count option.7-Select it by pressing Yes or OK button.8-There will be three options 0,1,2.9-Select 1, it will show a new menu, with numbers, now press C button to clear the counter.After the counter is cleared.Select 0 and press Reset button.
Dec 17, 2010 | Minolta bizhub 180 Black and White Copier
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
236 people viewed this question
k24674
jasbo
jasbo
