Question about Nokia Cell Phones
How can i fix my cell phone battery? - Nokia Cell Phones
    Problem Solver:
  • 9 Answers
If your battery is dead you can revive it by voltage regulator to shock the battery to revive it and need to charge it to gain back its life,,, charging the dad battery cannot help to revive it, 100 percent on that,,
Posted on Nov 07, 2012
Alcatel idok 4 battery drains fast, can u suggest an app that would optimize and help with battery issue,
Get 'Battery Doctor' from the App Store Kathleen.
Batteries do age and deteriorate. Time for a new battery of a new phone. You can also get extended MilliAmpHour batteries.
Canada Cell Phone Battery Warehouse Cell Phone Battery Mobile Phone...
Dec 04, 2016 | Cell Phones
Tip
How to fix a phone that dropped into water
Hi, when ever a phone drops inside the water, First you will need to remove the battery from the cell phone.If the battery is left inside the cell phone, the water will damage the cells inside the battery, why?, because there is still Power inside the cell phone that can damage the battery cell.
To service the phone,you will need to unscrew the cell phone,because has entered into the cell phone and it can damage IC chips inside the cell phone if not attended to immediately.
Use a phone screw and unscrew the phone from the back by removing the battery and you will see some screws, unscrew possible screws and open the phone.(depends on the type of phones)
Get a methylated spirit and a small brush, remove the board of the phone and deep the brush inside the methylated spirit,brush gently on the board of the phone. After brushing, get a dryer to dry up the board of the phone and live it for a while to dry.
After some minutes,assemble the phone back and fix in the battery. Make sure during the process you are charging the battery of the phone. battery might be dead or low in power..Better you can have a spare battery around
after servicing the cell phone..
I guess that's all you need.
Note: if the battery has stayed too too long on the phone and am sorry after the water splash, it might not come on after this all process, that means you will have to flash the phone because the battery might have damaged the memory of the board of the phone and will not power up the phone because the phone is too weak to power.
Flashing of the phone will restore back the phone memory.
That's solves your problem.
on Sep 15, 2011 | Cell Phones
Phone battery strongly heated and then empties quickly how can i fix that?
Seems like a short circuit or a battery problem.Try contacting your service centre
May 29, 2015 | Nokia 2720 Fold Cell Phone
How to fix sms sending problem ? ?
follow this steps and fix it. God bless you
1. Phone's memory is full
2. Power needs to be cycled
1. Try deleting old text messages to make room for new ones.
2. Fix your phone by cycling power:
· Remove the battery while the phone is powered on.
· Leave the battery out for a few seconds.
· Replace the battery.
· Turn the phone on and try to resend the message
If your text messages still won't go through, contact your service provider.
Jul 31, 2013 | Samsung SGH-S5230 Cell Phone
Samsung touch
This Cell phone repair is rated "EASY or HARD"
Easy fix:
first check battery of the phone. If possible check the voltage of the battery it should be 3.7V but if it is less than 3.7V then you need to change battery and your phone should work fine.
Hard fix:
Your samsung might be having main board issue. in this case you will have to take it to a cell phone repair shop and get free estimate.
tech
Jan 31, 2013 | Apple Cell Phones
Ihave htc incredible was dropped in a water how to fix it ? and give me the address the shop to fix in houston.
There is no true way to fix water damage. What happens is the battery will short out some of the circuitry in the phone. You can try taking the battery out and putting the phone in a bag of dry rice to wick away the moisture.
Mar 06, 2011 | HTC Droid Incredible Cell Phone
My LG KF 750 doesn't turn on. when i press the turn on button the welcome screen of LG come and blinking..is this due to software problem.where can i fix it.please help me
Hi, There are different possible things that can cause Your LG cell phone to malfunction the way it does. Possible reasons below:
The battery,,
The Phone memory.
The battery of the phone can be the problem.How Sometimes when a phone cell phone battery is weak and It might not be able to power up the phone. You can test the battery by using another battery to test on the phone,or you can test the battery by using the battery on another phone to test if the battery is still working properly.
The phone memory might also be the problem. When an application is being downloaded on a cell phone or being Transfered to another cell phone through Data cable or Blue tooth, it is easy for VIRUS to affect the phone and when a VIRUS affects a cell phone,the cell phone will malfunction.
To fix a malfunctioning phone like a VIRUS infected phone,you will need to flash the phone memory of the phone.
When you flash a cell phones memory,it will restore back the phone to it default state.
You can use the below links to know more on how to flash a phone.
www.hubpages.com/hub/How-to-Flash-your-cell-phone.
Good luck to You.......
Feb 01, 2011 | LG Secret ? KF750 Cellular Phone
My sony ericsson k550i dosent startup ,it just show few red flashes and the its dead
Hi, There are different possible things that can cause Your Sony Erickson cell phone to malfunction he way it does. Possible reasons below:
The battery,,
The Phone memory.
Feb 01, 2011 | Sony Ericsson K550i Cellular Phone
My phone keeps shuting down and rebooting when I try to read a text. Sometimes when im sending a text it shuts down too
Dear Sir! the problem is with your cell phone's battery, you cell phone's battery is probably tripped. You need to change the battery, hope that will fix your problem.
Thank you!
Aug 02, 2010 | Motorola Mobility Rival A455 Cell Phone
My phone froze. how do i fix it?
Pull out the battery for a few seconds. Or let the battery die.
Jul 07, 2009 | LG Xenon GR500 Cell Phone
Cell Phones Logo
109 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
