Question about Epson STYLUS R230 InkJet Photo Printer
My epson R230 sometimes takes in the paper to print then as if not sure what to do, it moves the paper back and forth and finally back out. The monitor says paper jam or paper not loaded properly.
Service required
Posted on Nov 23, 2012
SOURCE: EPSON R230 PRINTER
epson r230 printer problem
blank page out and no error
Posted on Nov 16, 2009
SOURCE: epson r230 paper jams and long beep sound
Posted on Oct 30, 2008
aicaxz
  • 511 Answers
SOURCE: can i fix by myself paper feeder of epson r230
Replace the paper feeder, or add a tape below two rubber feeder.
Posted on Apr 25, 2009
asabur
  • 102 Answers
SOURCE: Epson Photo Stylus R300 paper error
Please replace holder shaft & Roller ******
Sk. Abdus Sabur
Posted on Jan 03, 2010
Testimonial: "many thanks for your reply - looks like is could be expensive (more expensive than replacing the printer?) i'll take it to an epson repair center"
SOURCE: epson workforce 600. says it has paper jam but
FIXES FOR EPSON RX600 PAPER JAM
Posted on Jan 18, 2010
R230 epson color
The cartridge head may have gotten clogged. Take the cartridge out and clean the head with a damp cloth and print a couple of pages to set this right.
Also, print a test page to make sure the ink hasn't dried up. If it has, you will have to get a new cartridge.
Aug 12, 2014 | Epson STYLUS R230 InkJet Photo Printer
Resetter r230x
1. Make sure the printer is turned on and terkonek with a computer (printer driver already installed)
2. Install SSC Service Utility and run the program
3. Model of printer configuration settings. Select the Epson Stylus Photo R230. After the play closed
windows.
4. In the lower right corner of the taskbar (near the clock) right click the icon SSC Service Utility, select
" Protection Counter" click "Reset protection counter" select Yes on the pop up that asks
"Have you Replace waste ink pad"
5. Restart the printer, the printer is ok
That's the steps I described to my friend, so she does not go back and forth to the printer lift handyman service to reset Epson R230. May be useful.
Download SSC Service Utility
Dec 10, 2013 | Epson STYLUS R230 InkJet Photo Printer
R320 printer won't print on thick photo paper anymore. Regular copy paper works fine. Are there rollers or sensors that I can get to so I can clean and check? Is there a fix for this problem?
  • Make sure that the paper meets paper specifications of the product.
  • Spray compressed in air.
  • If it is a non-Epson brand paper, try Epson paper
  • Make sure that settings are setup properly, Some Epson products have a Thick paper and envelopes or Thick paper to allow it accommodate thick media
Feb 14, 2013 | Epson STYLUS R230 InkJet Photo Printer
Epson photo stylus R230 prints blank
I think you are in a hardware problem. In this situation you may try to set up a seringe in to a pipe that are in the back side of the printer.to find the pipe follow the mentioned procedure
1. (in off line position)open the scrue that are situated back side of a printer
2. push the cover and
3.find the plastic pipe into the blank space
4.Then set a sering in to the pipe and try to out ink by presure. 5/6 time.
if your printer stil not print, the mother bord of the printer should damage . change the mother bord and it will work fine.
Dec 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
My printer Epson Stylus PHOTO R230 does not print
The printer does not print only dragging a paper without printing.
3 option to solve
make sure your
1. heads are working
2. flex cable connecting the heads
3. main board
Most common that i found is to replaced the main board. or replace parts of other main board if you have some extra. hope it can help.
Jun 29, 2009 | Epson STYLUS R230 InkJet Photo Printer
I have 2 Epson R230. One has a bad printhead, in that the test print is messy and the black print head is badly clogged. I want to swap the printheads, so that I will at least have one working printer. The...
Befory you toss the printer, try this!
Take a syringe, 1" piece of rubber tubbing that will fit over the head input snugly, (auto parts house stocks some that works fine). Fill the syringe with a good head cleaner, slightly warm it in the microwave (try 5 seconds to start). Attach to nozzle, gently pull back just a bit, then apply a little pressure. If it accepts the fluid, STOP, You can clean the syringe, add the proper color ink, inject just a small amount. reinstall a known good cartridge, clean heads couple times checking results, if ANY streaks or color appears, clean again! Sometimes letting it sit overnight allows the head to fill with ink. I have had very good luck with this method, also some will not clean properly, just depends on how bad it is clogged.
Good luck..
May 18, 2009 | Epson STYLUS R230 InkJet Photo Printer
EPSON R230 PRINTER
ONCE PRINTE COMMAND IS GIVEN PAPER IS ROLLED IN AND THEN PAPER JAM RED LIGHT BLINKS. CAN NOT PRINT ANYTHING.BUT NOZZLE CHECK PRINT CAN BE PRINTED.
Jul 23, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson STYLUS R230 InkJet Photo Printer Logo
110 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
