Question about Reebok 8000 ES Treadmill
How to lube reebok 8000es
Lube deck
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Reebok 8000es All funtions work except the belt motor will not start.
This is a very common problem:
1) Very high belt/deck friction.
Now Watch this videos +Tip: proceed with carefully and patience
http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQ
http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
http://www.youtube.com/watch?v=CuMjcPLYehw&feature=related
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related
http://www.youtube.com/watch?v=dxpOOPetVLo
If the problem persist after you did the 1rs Step: Proceed with 2nd Step:
2) Faulty Main motor:(Open or Short in windings +Transformer or Coil Faulty+Main Controller Board Faulty.
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
http://www.youtube.com/watch?v=23ZgWaVEQjA
After You did these steps; You will have Powerful conclusion about what is exaclty your problem: 1) Mechanical 2) Electrical or 3) Electronic or combinations.
Attached you will find a Block diagram that I did for you will See how the Main Controller Board(Electronic) has aprox 90% of functions for the treadmills.
Good luck. Sincerely.
E.CUADRA
MANAGUA,NICARAGUA. C.A.
Posted on Nov 25, 2011
My tread mill belt will not run. it suddenly stopped working when i stood on it. there seems to be power to everything else
LUBE the deck belt with grease or WD-40 o any silicone lube.
try to loose the belt deck in the way that when you lift with you finger will be 2" max. See the drive belt , must have a deflection with your finger 1/4" aprox. Of course time to maintenance motor: lube the bearing or replace, and the carbon brush. Lube the deck bel 1time every week.
However you must test the voltage to the terminal to the motor from 0-180 Vdc, if NOT replace the Motor control Board
Feb 08, 2015 | Nordic Track Nordictrack 3500r Treadmill...
TRADEMILL START AFTER DISPLAY ERROR3 AND 5SEC OFF
1) LUBE the deck belt, you must do it every 1 week after use. Otherwise you will the same problem that you have right now. This is by lack of maintenance. Maybe you have WORN deck belt.
2) LubE THE rollers bearing with WD-40 NOT use for deck belt. deck belt is with 100% silicone lube.
3) Test the input voltage motor, if there are the motor need repair. see my personal TIPS for troubleshooting motor.
4) Test the output voltage board, for input voltage board, if there are NOT the board is faulty.
See the block diagram
God bless you
Nov 26, 2012 | Proform Sport 1000 Folding Treadmill...
Says to lube belt .did that but when the safety key is inserted still saying lube belt
You must LUBE the deck belt, every week, otherwise you will have a WORN deck belt and replace with the rollers bearing. Now LUBE with 100% silicones lube.
2) lube THE Rolleler bearings too.
RUN the software calibration for easy diagnose, and troubleshooting
God bless you
Nov 17, 2012 | Exercise & Fitness
My treadmill stops after run for awhile ,why is this happening?
1)Lube the deck belt,this is happening because the lack of lube produce enough friction between deck vs deck belt, and result in shut down.
2)lube The rollers bearing very well
3)measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are Not the board is faulty. see the bloc diagram
God bless you
Jun 12, 2012 | Nordic Track Exercise & Fitness
I lubed the deck. The treadmill still does not go. What should I do??
1)Lube very well the deck belt
2)lube the rollers bearing
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the block diagram
God bless you
Jun 11, 2012 | Exercise & Fitness
Why my treadmills shuts off after 30 min
1) LUbe the deck belt, the lack of lube produce Shut down, by enough friction between deck vs deck belt
2) Lube the rollers bearing very well
3) Measure the input voltage motor, if there are the motor need repair
4) Measure the output voltage board, for input voltage motor, if there are Not the board is faulty.
5) Run the software calibration, for diagnose, and troubleshooting.
God bless you
Jun 09, 2012 | Exercise & Fitness
My Sole F80 deck bounces excessivly when not at an incline.
1) Lube the deck belt, this problem is lack of maintenance, maybe the deck belt is worn.
2) You must align the deck belt see the diagram
3) Lube the rollers bearing very well very important too
see the video: God bless you
May 15, 2012 | RTO Sole F80 Treadmill
Motor makes a clicking noise
1) LUBE THE DECK BELT, MAYBE YOU HAVE DECK VS DECK BELT WORN.
2) lUBE THE ROLLERS BEARINGS
3) Lube the main motor according with the maintenance schedule.
Proceed inmediately.
May 08, 2012 | Exercise & Fitness
I replaced the belt on the Proform 530x and it still sticks. I have also tried to silicone spray the deck,. Help ?
You must LUBE very well the deck belt. 2) adjus the roller bearing and LUBE very well 3) Motor can be LUBE follow the instruction manual for LUBE. 4) Adjust the deck belt see the diagram.
sincerely. God bless you.
Apr 23, 2012 | Proform 530 Treadmill Walking Belt
Keeps shutting down after 20 minutes
hi
1 reason could be belt and deck(motor draws a lot of amps and belt and deck heats the motor up)
just try wax or libricate compatible lube and try (belt and deck lube you can buy from gympart.com
Nov 21, 2010 | Life Fitness T3 Treadmill with Advanced...
Reebok 8000 ES Treadmill Logo
43 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
