Question about Bose Lifestyle V20 System - black Theater System
Bose V20 Connection via HDMI to Samsung LE46856 but no sound
I have just bought a V20 brand new in the UK and after setting up I am unable to hear any sound on the TV while connecting via a HDMI cable supplied with the Bose system unless I have the optical dable also connected. All the instructions say if the connection is via HDMI one does not need any other cables? Also on the display only PCM 2.0 is visible not 5.1 is this a problem, this remains same if I am watching a DVD or TV channel? is this a problem? I'm sure I have connected all cables as per the instructions, I did not use the scart/splitter cable supplied with the Bose as HDMI connections are available. One other thing When attempting to setup for the Bose remote to operate my Samsung TV all the codes provided in the system list do not appear to allow the Bose remote to take charge of the TV. Other items connected are Samsung DVD recorder 275 & PS3 direct to HDMI on the TV. The incoming aerial is connected directly to the DVD & then the TV. Please can anyone advise a known issue/remedy for my problems
pattersj78
  • 70 Answers
SOURCE: No sound when connecting with a fiber optic.
have you tried a new cable?
Posted on Oct 27, 2007
SOURCE: PCM 2.0
I have the Bose 3-2-1 GS Series II and initially could only get PCM audio. However, I now get Dolby Digital 2.0 and 5.1 audio through the following connections: 1) Connected a coaxial digital audio cable from Digital Audio Out (coaxial) on the HD cable box to CBL-SAT (D) on the Bose Media Center. 2) Connected a coaxial digital
audio cable from Digital Audio Out (coaxial) on my Toshiba DVD Recorder/Player to AUX (D) on the Bose Media Center. All video connections are from the cable box to the TV and from the Toshiba recorder/player to the TV. To receive Dolby Digital audio, I press either CBL-SAT or AUX on the Bose Remote Control. Good luck!
Posted on Jan 04, 2008
SOURCE: Bose Lifestyle V20 Error 180
OK talked with Bose just a minute ago and they were able to correct the issue.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Hope this helps!
Posted on Jan 26, 2009
SOURCE: How do I connect my iPod to Bose Lifestyle V20 System
You can only Connect a iPod via a iPod dock
Apple iPod Univeral Dock
and use either
Apple Composite AV Cable or Apple Component AV Cable
based on what Output you iPod Allows.
the list of which iPod that is supported is listed on each page of the AV Cables above.
You can use a IR Blaster Cable with the iPod Dock to control the iPod also.
Posted on Feb 01, 2009
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
Posted on Mar 10, 2009
Bose lifestyle v20
Make sure the HDMI device (TV, Blueray player) is set up for audio output. Usually HDMI 1 is the only connection that has audio out. Also some TVa have to be configured for HDMI audio out.
Dec 07, 2013 | Audio Players & Recorders
I just bought my V20, I plugged it using a HDMI from my dvd to my v20 for the image, and a digital cable for the sound. My image works perfectly but I have no sound. I noticed that the light under my...
Hi - Don't know about the switching LEDs but there is no reason to be using both the HDMI cable AND a digital coax cable to the V20.
You should have a single HDMI (carries video and 5.1 audio) cable from the DVD to the DVD input in the V20.
Regards,
Mikeywaf
Mar 19, 2011 | Bose Lifestyle V20 System - black Theater...
HOW TO CONNECT PS3 VIA HDMI TO BOSE V20 ? BOSE SET UP DO NOT HAVE PS3 ? PLS HELP
Como faço pra desbloquear um bose lifestyle V20???
POr favor me ajudem é urgente.
Feb 17, 2010 | Bose (321GS) System
Connection to Bose V30 System
check hdmi setting from ur tv and ur dvd connection
Nov 08, 2009 | Bose Lifestyle V30 Home Theater System -...
No sound from rear/ surround speakers on Bose V20
Yes, very easy and cheap if you get it from the right place. Fiber Optic going from the output of the device to the input of the receiver. If your lucky enough to have an input/output fiberoptic in your tv, run the fiber from the device to the tv input, fiber the output of the tv to the receiver so not only are you getting the device full surround sound, but you'll also get better TV surround sound for those that are made with Dolby pro logic II sound. (pretty much all the newer movies and shows)
Jun 13, 2009 | Bose Lifestyle 12 System
No sound from rear speakers of Bose V20
Are you useing a digital coaxil cable? or optical cable?(you will need one of these connections to get 5.1 surround!) the white /red rca jacks will not do the 5.1 surround! (back speakers)
Please rate response!
Jan 07, 2009 | Bose Lifestyle 12 System
Bose Lifestyle V20 - no video out, no response to remote control
check the voltage setting on the power supply that connects the power cord to the media center. Mine was set to 230V. Changed it to 115V and the video starting working.
Oct 05, 2008 | Bose Lifestyle V20 System - black Theater...
System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Jul 19, 2008 | Bose Lifestyle V20 System - black Theater...
Bose Lifestyle V20 System - black Theater System Logo
352 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
