Question about Roland BOSS BR 600 8 track portable digital recorder
Boss Br 600 won't turn on need electronic diagram to fix
2nd one i have had that has done this, it worked fine then just turned off and never came on again. was told it wasQ47 transistor
2 Suggested Answers
  • 411 Answers
SOURCE: the boss br-8 multitrack recorder. would somebody
The possibilities are almost endless. It's going to have to go to a qualified repair shop.
Posted on Jul 05, 2011
Need schematic for Boss BR 600 digital recorder. My power input has failed. need value and direction of diode to replace Q47 chip.
To be sure you need a schematic. You can actually take a look at it to see if is labeled or check polarity with a meter.
Dec 04, 2014 | Roland BOSS BR 600 8 track portable...
My boss br 600 is accidentally dropped in the flooded street in my village, how do i fix this
Unfortunately, You buy another one. It is no different than a phone or computer. once the board is soaked it's done. Sorry. I can say put it in rice and let it dry out but that's it.
Aug 25, 2013 | Boss Music
Hi, I have a boss BR 600 and when i insert any card it checks the card and then says ' card not supported'. I t used o work fine. However i have noticed that 2 pins seem to be missing inside t
I have the exact same problem. All my flash cards worked fine, and all of the sudden, none work. Not even the one that came with it. I am still trying to fine the reason. I bought it eight years ago, that might be it.
Jan 30, 2013 | Roland BOSS BR 600 8 track portable...
Boss br-600 unsupported card
Feb 12, 2012 | Roland BOSS BR 600 8 track portable...
Hi. My boss br 1600 will n ot start. I turn on the power source and it will blink for a split second and then nothing. I checked for loose connections but everything seems ok. Any suggestions?
I have this problem with mine. I've did some research and with the boss br 600 this problem can arise quite often .it's caused by a faulty power diode apparently except in that case I've never heard ofrom the screen blinking at all (which my 1600 also does) I wonder I'd this problem can be the same for a br 600 as the br 600
Sep 08, 2011 | Boss BR 1600 Cd Br1600 Cd 16 Track Digital...
My Boss BR-1180 was working fine but said NO CD DRIVE so I replaced the cd drive and as soon as I did I turned it on it reads BOSS BR11-80 and the HD ACCESS light stays lit but nothing else happens. Did I...
hdd should not be damaged, if your hd and cd are on same ide cable it might be taking the cd as master and not the hd, ensure the jumper on the back of the new cd drive is set in the same position as the old one was, as test remove cd and boot system, hd should act again as usual. this will show that there is a ide conflict.
my assumption is that your cd jumper should be set to slave or cable select position.
you may have to try each until you find the position that works.
I hope this was useful.
regards Martin.
Mar 24, 2011 | Boss BR-600 Digital Recording Studio
My micro br got wet. when i discovered this it had fixed on hold. I dried it out for a day and it seemed to be working fine but a couple of days later now and all the displays seem to be fine but there is...
I am sure it can be repaired. Whenever ANY electronics get wet, IMMEDIATELY remove ANY pwer sources, including internal batteries.
If wetting was not pure water, flush unit with de-ionized water till absolutely clean of any residue. shake out all water and allow to dry a week before applying power.
Jan 25, 2010 | Boss Micro BR Digital Recorder
Burnt out my Boss BR 1180 How do I repair?
this is a job for an advance electronic repair tech...try the manufacturer..next a tv repair shop..then an Audio Install shop...if that doesn't work out..i'll personally try to fix it..for lest than anyone else..its probably the tranformer output circuit overrun..that part of the board or component wil have to be replaced...good luck
Jun 16, 2009 | Boss Micro BR Digital Recorder
Roland BOSS BR 600 8 track portable digital recorder Logo
79 people viewed this question
Top Roland Music Experts
Vito Vacirca Jr.
Rabbit Brains
Rabbit Brains
Matthew Spark
Matthew Spark
Are you a Roland Music Expert? Answer questions, earn points and help others
